Strange problem with slow download speed on WAN
Hello guys!
I want to share with you my weird problem and I hope to get some valuable hints because I tried several things without success.My DSL connection/modem status:
Download: 17.326 Mbps.
Upload: 1.149 Mbps.When I do a speedtest (speedtest.net) with my computer plugged in directly on the modem I get:
Down: 15+ Mbps
Upload: 0.95 MbpsWhen my computer is behind the pfsense box I get:
Down: 4-5 Mbps
Upload: 0.95 Mbps-
The problem started about two weeks ago.
My pfSense version: 2.0.1-RELEASE (i386).
No hardware changes the last 10 months.
I did the tests with the simplest possible topology: 1 PC on LAN -> pfSense -> DSL modem
The modem is not on bridge mode.
My ISP did some tests from their side and they confirmed everything works fine (of course it works since bypassing the pfsense box the speed is fine).
On my WAN iface I have 0 errors and 0 collisions!
Using auto-negotiation for WAN iface "100baseTX <full-duplex>" is selected.</full-duplex>
With "full" speed (5+Mbps stable),pfsense has CPU usage around 15-20% and memory usage around 15%
State table size and MBUF Usage have low values too.
It seems to affect only the download speed and not the upload.
No traffic shaping enabled.
There was no bridge between the interfaces.
Then I created a bridge for the LAN and used different ports for the tests.
I replaced the cables with new.
I haven't installed squid or squidGuard and during the speedtests I also stopped several services (snort, ntop).
I disabled/enabled the hardware checksum offload.
I checked different settings for the interface speed but since I get no errors/collisions I do not think it is related.
Nothing of the above helped! Any ideas???
Any feedback really welcome since I am running out of troubleshooting ideas… :) -
you could try this:
http://help.expedient.net/broadband/mtu_ping_test.shtml
you could try this:
I tried that and:
For packet size 1472 I get timeout.
For packet size 1462 I get normal response.
For anything above 1472 I get ICMP error for DF flag as expected.Now by default the MTU is 1500 but I will also try 1490 (1462) on my interfaces and let you know.
- UPDATE 1: I get the best results using the default settings (1500)…so the problem still exists.
- UPDATE 2: Using for all interfaces (LAN,WAN) MTU 1492 which is used by my modem I do not notice any difference on the speed but just higher CPU load on pfSense.
How long has your pfSense box ever performed well before running into problems? Have you made any recent hardware changes? You might want to try running a test directly from your firewall as described in the below thread. I've used this method via SSH to the cachefly site successfully many times.
http://forum.pfsense.org/index.php/topic,45874.0.html
This pfsense box was running without problems the last 10 months.
No hardware related to pfsense or the modem has been changed after the initial setup (10 months ago).I tried the following from the box itself:
fetch -o /dev/null http://cachefly.cachefly.net/100mb.testand I get average download speed 550kBps (4.4 Mbps).
Ok so the problem appears even when the pfSense box isn't routing at all.
Is your modem in bridge mode? I guess I really mean is your modem configured differently when connected to pfSense than connected directly to a PC?If it is then possibly your ISP has changed their setup slightly such that bridge mode is not working as it should. They may not even realise it happened, firmware update on some piece of kit between you and them for instance. Anyway you should be able to test that easily enough by leaving it in bridge mode and using the PPPoE (if that's what you're using) client in your PC.
If you are double NATing then possibly a bad NIC or cable are to blame. Try reassignng your NICs the other way around to WAN and LAN. Test again.
Hi Steve,
No my modem is not on bridge mode, so when I connect the PC network cable from pfsense directly to one of the LAN slots in the modem the speed is high as normal, when I plug it to the pfSense LAN ports again, we are back to ~5Mbps. In general any PC connected to the LAN ports of the modem has high download speed and when connected to pfSence low. That's why I don't think it's something that could be resolved if I change the modem to bridge mode.I may try to reassign the WAN to another interface. Just for information all the interfaces on the box are Gigabit ethernet.
Hmm. OK.
That certainly suggests a problem with the pfSense box and since it just happened without any hardware or software/firmware changes I would be looking at a bad NIC or cable. In the webGUI look at Status: Interfaces: Do you see any errors or collisions?
You could try and do a test though the modem/router but not via the internet. Connect a server of some type to one of the spare LAN ports on the modem and then try to tranfer a file from it through pfSense (or fetch it as before if it's a web server).Steve
Using the initial interface I had 0 errors/collisions, but anyway I assigned WAN to another interface and replaced the cable.
When Speed and Duplex is on "autoselect" I get timeouts and the link between pfsense and modem is not stable.
If I switch is manually to "100baseT full duplex" it works but I get many "errors in" for the WAN.
If I switch is manually to "100baseTX half duplex" it works but I get some collisions (no more errors). The download speed is again around 5Mbps.I noticed that sometimes a restart of the pfSense box has a real impact on issues related to the interfaces. So after a reboot, "autoselect" works fine again: full duplex, no errors, no collisions.
- UPDATE: I connected a server on a LAN port of the modem. Then I downloaded a file from that server to my client behind pfSense. The download speed was higher than 5Mbps, around 7.5-10Mbps…
The outcome till now:
Download speed behind pfsense is higher for downloading locally (through modem) than downloading from the internet…so it seems that the pfSense interface works fine.
At the same time downloading from the internet, bypassing pfSense (connected to the modem) works fine.
Does it makes sense? Anybody with a similar issue maybe?
@/CS:
If I switch is manually to "100baseTX half duplex" it works but I get some collisions (no more errors). The download speed is again around 5MbpsThis is your problem. You have a mismatch somewhere or a bad cable or socket where not all pins are connected. Hard to imagine how that just happened but I guess physical damage can 'just happen' if your box is vulnerably placed.
If you set the pfSense box to anything other than 'auto' then you MUST have the same settings at both ends of the cable. If you cannot set the speed/duplex at the router you have a problem. ;)
@/CS:
Not really. If you are only getting 7-10Mbps through a local connection then something is wrong unless your server is very slow. Or perhaps the other end is set to 10baseT.
Usually if you have a duplex mismatch the speed is very slow indeed, like <500K. Hard to say quite what's happening here. Have you tried different LAN ports on the modem?
Try setting both ends to 100TX.
So to recap, with your original WAN interface set to auto-negotiation, you experience slow speed but no errors or collisions. Using a second interface for the WAN, you get timeouts and what appears to be high-latency conditions. Adjusting the speed/duplex on the second interface introduces errors or collisions.
You've swapped out the cable and tested the modem's network interface with a directly-connected PC, so those two components are assumed good.
I agree with Steve in that it's a bad cable or interface problem, so with the cable considered good, that would lead us to the interface. But the second is experiencing issues as well? What are the hardware specs of your pfSense firewall? What type of network interfaces are you using (Intel, Broadcom, etc.)? You noted the interfaces on your firewall are all gigabit, is the interface on the PC you've directly connected to the modem gigabit as well? Sorry for all the questions, just trying to get a better feel for your setup.
Hi guys,
feel free to ask anything! :)So my pfSense box is an embedded board (net6501-50: http://soekris.com/products/net6501.html) with 4x Intel 82574L Gigabit Ethernet ports. Yes my computer connected to pfSense has also a Gigabit interface. Unfortunately I cannot define the interface speed on the specific modem but the problem is more generic affecting LAN interfaces too.
I agree that it seems to be something related to the interfaces and not the cables, since I used around 5 different cables! With the same cable connected to the modem I have normal speed. ;)
I get the same weird behavior trying 3 different LAN ports of the board! When the "autoselect" doesn't work, I need to define the speed and then I get errors. I am afraid the issue is a hardware failure of the board…but I cannot understand what happened and messed the interfaces. Right now the WAN with "autoselect" works without any errors/collisions and there is a problem with the LAN ifaces.
I do not install any updates automatically and nothing has been changed.
The condition of the interfaces/pins is perfect and the box is located in a protected area indoors. The is no physical damage and the age of the box is around 10 months.
Ah, a Soekris box. That's a pretty popular board, so certainly not an uncommon configuration by any means. I'll admit I don't have much exposure to the Soekris products, other than what I've read here and other places on the Interwebs. I do run a little Atom board with pfSense using the same Intel nics and they've performed admirably.
Are the nics on your Soekris box connected to an expansion card that perhaps needs to be reseated? If your firewall is anything like mine, then it's tucked away behind a media center collecting more than it's fair share of dust and dirt. Are you running the embedded (nanobsd) of pfSense or the full version? On a CF card or other storage device?
@/CS:
When you did the above was the speed still limited?
One thing I have seen in the past that resulted in similarly flaky network connections is a dying power supply. Especially an external power brick. Does it run hot? Do you have anything you could replace it with for a test?
As Trunix said that is a popular board. If it is a PSU failure someone will have seen that before.Oh and what modem do you have?
Yeah, after looking at the pics of your Soekris and realizing all the nics are mounted directly to the board, I was thinking psu as a possible culprit as well…but Steve beat me to it! My other thoughts were your storage device, but of the two, I think a failing psu aligns better with the problems you're experiencing.
PSU? Never thought about that but it makes sense!
Just to mention that during ALL kind of tests behind pfSense mentioned above the speed was limited. Even when I have no errors/collisions on the interfaces the speed is limited.I have installed nanobsd version of pfSense on an external 2.5" Fujitsu SATA disk.
Modem: DSL-EasyBOX 803 A by Astoria Networks/TWONKY. -
I would swap the psu and see if that fixes things. In any case, it's probably a good idea to have a spare one on-hand. Let us know if that's the solution so others can benefit!
I wonder if your external hdd is increasing your power draw enough that it's shortening your overall psu lifetime. If the psu is indeed the problem, and the replacement fails in a similar time period, you may want to consider a mSATA ssd.
Thanks for your support guys.
I will check with a new PSU and let you know. :) -
I contacted Soekris and they also suggested to use a new PSU.
I just did and … the same problem! :(
What else could be? ???
