    [solved]Problem with connection to Lan via RoadWarrior
    3 Posts 2 Posters 1.5k Views
      Coverian
      I have just started with pfsense for testing and have some problems with an RoadWarrior setup.
      The connection to the VPN-Server works just fine but the connection to the Servers in the LocalNetwork is impossible. The problem seems to be that all Servers in the LAN have a default gateway which is not the pfsense.
      I have set a Gateway for the LAN interface which faces to the Intern-Gateway
      1. Should i just add a route from the default gateway to the pfsense?
      2. And what would the route look like when my LAN is 192.1.1.0/24, WAN 192.168.0.0/24, VPN 10.0.8.0/24
      3. Is the Gateway in the pfsense enough or will i have to add a route to the Intern-Gateway
      Many thanks in advance.
      ps.: sorry for the bad englisch, not my first language.
        phil.davis
        a) For example, if your other router/default gateway LAN IP is 192.168.1.1 and the pfSense LAN IP is 192.168.1.42 then, on 192.168.1.1 add a route:
        10.0.8.0/24 -> 192.168.1.42
        192.168.1.1 might also send ICMP redirect messages back to your servers, telling them that packets to an address in 10.0.8.0 are best routed directly through 192.168.1.42 - and if the servers take notice of ICMP redirects then they will start routing more efficiently back to your VPN.
        If (a) has issues, then (b) add a static route to each server:
          Coverian
          solved my problem, many thanks  ;) .
