    Asterisk + Pfsense and Static port is not fixing the problem..
    34 Posts 8 Posters 17.9k Views
    • D
      dhatz
      @reh1151:
      Have done a great deal of reading and it appears that running VoIP behind pfSense is a hit or miss endeavor. While I love pfSense and have been running it since 2009, I have already begun pricing Cisco ASA units which can easily accomodate what I'm trying to do. One other curiosity I noticed: When I moved the Trixbox behind the firewall, I was IMMEDIATELY swamped with a flood of fake SIP registrations from the 220.240.0.0 subnet because I had opened up SIP port 5060. I ended up blocking the entire subnet on the Trixbox using IPChains. This confirms what dhatz points out.
      I have been running Asterisk-based PBXes behind pfSense for 2+ years and it works (however there are certain issues e.g. with multi-WAN configurations, which has been semi-solved in 2.1).
      However, successful deployments depend on many factors: the NAT traversal capabilities of the SIP stacks involved (both of your Asterisk PBX and your SIP trunk provider), their respective configurations and of course the configuration of pfSense NAT. Due to the fact that SIP wasn't originally designed for NAT traversal, if problems arise one usually needs a good knowledge of the protocol internals in order to do proper troubleshooting.
      With Cisco the main difference is that the product is typically installed by a "CCNP Voice"-certified network engineer.
      • R
        Reiner030
        perhaps a helpful hint:
        try to debug your voip traffic from/to your trunk
        on asterisk itself:
        sip set debug peer <your trunk="">or on console with wireshark/tshark
        You should get something (you set public IP for remote connects?):
        When your PBX send a request like:
        [Jun 17 20:34:28] Reliably Transmitting (NAT) to 193.47.84.4:5060:
        REGISTER sip:terrasip.net SIP/2.0
        Via: SIP/2.0/UDP <your public="" ip="">:5060;branch=z9hG4bK718a8652;rport</your>
        Max-Forwards: 70
        From: <sip:<your account="">@terrasip.net>;tag=as5fe32ab8
        To: <sip:<your account="">@terrasip.net>
        Call-ID: 3e926cdc79c80af43a9edc5323403c65@127.0.1.1
        CSeq: 9847 REGISTER
        User-Agent: Asterisk Gemeinschaft
        Authorization: Digest username="<your account="">", realm="terrasip.net", algorithm=MD5, uri="sip:terrasip.net", nonce="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", response="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        Expires: 145
        Contact: <sip:<your account="">@<your public="" ip="">>
        Content-Length: 0
        you should get something back like:
        [Jun 17 20:34:28]
        <–- SIP read from UDP:193.47.84.4:5060 --->
        SIP/2.0 200 OK
        Via: SIP/2.0/UDP <your public="" ip="">:5060;branch=z9hG4bK718a8652;rport=5060;received=</your>
        To: <sip:<your account="">@terrasip.net>;tag=598d351d4bc9e6e8e2c538995c9c64c8.a22c
        CSeq: 9847 REGISTER
        Contact: <sip:<your account="">@<your public="" ip="">>;expires=145
        Server: TerraSip Advanced Router 1.0.16
        Content-Length: 0
        if the red part is filled out and NOT your public IP/port you intend to have then you have a misconfigured firewall .
        You can take a look in Diagnose => States if the mentioned IP/Port is "open" on your firewall.
        BTW … we are still searching for a good SE VoIP provider with a 10 number block ;)
        Bests</your></sip:<your></sip:<your></sip:<your></your></sip:<your></your></sip:<your></sip:<your></your>
        • R
          reh1151
          Well, the Trixbox is still not working behind the pfSense firewall but Reiner030's post struck a chord. All this time I was assuming that the problem lay with pfSense. But everything I have read about running Asterisk behind a NAT firewall/router says that I have setup pfSense & the Trixbox properly. What I hadn't looked at was the firewall on the Trixbox itself. It's currently setup for the Trixbox sitting outside the pfSense firewall thereby acting as the sole firewall. It either (1) Should be turned off completely or (2) readjusted to send all outbound SIP/RTP traffic to the VoIP interface. The instructions I've read say the following:
          1. Disable the firewall on the Asterisk server (Not done!!!)
          2. Set a static IP address on the Asterisk server (Done. Created alias Trixbox on pfSense)
          3. On firewall, forward SIP ports (UDP) 5060 and RTP ports (UDP) 8000 - 20000 to Trixbox IP address (Done on pfSense)
          4. On Trixbox, edit the "rtpstart" value in rtp.conf to rtpstart=10000 (Done on Trixbox)
          5. On Trixbox, enter the same externip=xxx.xxx.xxx.xxx and localnet=xxx.xxx.xxx.xxx/xxx.xxx.xxx.xxx info from your sip.conf general settings into sip_nat.conf (Done on Trixbox)
          6. On Trixbox, in sip.conf under the account authentication settings for each remote extension add nat=yes, and canreinvite=no (Done on Trixbox)
          7. Reload or restart Asterisk using the CLI
          And that's all that is needed to get Asterisk working behind a NAT firewall like pfSense. I plan to try again only this time, I will shut off the firewall on the Trixbox first. As I posted before, once I moved the Trixbox behind the pfSense firewall, I was able to get incoming calls just fine. It was outgoing calls that did not work. Since the Trixbox is NAT aware, this will hopefully solve my problem.
          • R
            Reiner030
            ah ok… thats often the problem thats all assumed "as expected" ;)
            Has the PBX surely own firewall rules ?
            Or you can set static IP on DHCPd so that the PBX gets a "static" IP ;)
            Yes but they mus fit the RTP ports used on PBX... this is in this case not the case:
            [general]
            ; RTP start and RTP end configure start and end addresses
            ; Defaults are rtpstart=5000 and rtpend=31000
            rtpstart=10000
            rtpend=20000
            is in my case… you should set ports as needed both on PBX and firewall same range.
            Yes, this is set automatically in my pbx, too.
            BTW. You can also set hostname on externip then it's resolved fixed at pbx start.
            There is also an option externhost so you can use a pbx behind a dynamic IP ;)
            ;externhost=foo.dyndns.net      ; Alternatively you can specify an
                                            ; external host, and Asterisk will
                                            ; environments!  Use externip instead
            ;externrefresh=10              ; How often to refresh externhost if
            For our PBX trunk is configurable per WebGUI including NAT options and I tested it and with our setup it's not needed to activate this option when 1:1 incoming/outbound NAT is defined right.
            We have it only activated to get our VoIP providers happy which always claims that this must be the cause if something didn't work as expected (it's always the customer who made the errors; not the providers ^^)
            Greets
            Reiner
            • R
              reh1151
              @Reiner030:
              [general]
              rtpstart=10000
              rtpend=20000
              I did as you pointed out.
              Greets
              Reiner
              Yes. Since it is currently connected directly to its own WAN connection outside of the pfSense box, it HAS to run it's own firewall.
              Good point but I don't use the pfSense box as the primary DHCP server. I use the AD server to manage internal DNS & DHCP..
              Yes but they mus fit the RTP ports used on PBX… this is in this case not the case:
              For my environment, I had to forward SIP port UDP 5060 & RTP ports UDP 10000-20000. For the Trixbox, I also had to forward TCP ports 8000 & 9000 for the VPN to Fonality plus TCP port 5222 for HUD signalling.
              Followed 5, 6 & 7
              Well, after performing these steps, I was able to make one outgoing local call. As I pointed out before, incoming calls worked perfectly. When I tried to make a test LD call, nothing happened and from that point onward I was unable to make any outgoing calls (local & LD). So I tried setting up 1:1 NAT and resetting the state tables. No work. Then I switched over to Manual Outbound NAT AON. Still nothing. I ended up restoring the backup I took before making these changes in order to get pfSense back online. I am encouraged that I actually saw this work but I am mystified as to what caused it to stop. And that's where I left it although I plan to try again this weekend after reviewing my steps. I am missing something but cannot figure out what is lacking.
              • D
                dhatz
                I think that the fact that you keep having problems is most probably due to using Trixbox. Trixbox CE is a very old, obsolete IP-PBX distro.
                A VoIP setup primarily depends upon the capabilities and configuration of the two SIP end-points (your IP-PBX and your SIP trunk provider). If one side (or both) is "brain-dead" wrt NAT traversal, then you can only do so much by fiddling with the router / NAT gateway config.
                If you can't upgrade your IP-PBX your best alternative would be to use pfSense's 1:1 NAT.
                • R
                  reh1151
                  @dhatz:
                  Yeah, I hear you. I'm "stuck" with the Trixbox for now. It's running Trixbox Pro 12.6 which appears to be NAT compatible. I think my problem is that I don't understand how to properly setup 1:1 NAT in this instance. To the Wiki I go.
                  • R
                    Reiner030
                    @reh1151:
                    stupid question:
                    If you connected PBX parallel to firewall to WAN interface of your (leased) line, what should the firewall forward/NATting then?
                    • K
                      kejianshi
                      Working with asterisk based SIP:
                      What I have learned in my adventures with various firewalls with various DID providers using various sip clients.  This is just my experience.  Feel free to prove me wrong.
                      1.  SIP client behind a router with sip server behind same router and no NAT between them.  No issues.  It works.
                      2.  SIP client behind a router like pfsense with a client using openvpn server running either on or behind pfsense router that sip server is behind.  No issues.  Works.
                      3.  SIP server behind pfsense (NATed) and Client behind another router on a different public IP.  It registers but either 1 way audio or no audio.  (This is assuming you are using Manual outbound NAT with "static" checked.
                      4.  SIP server behind pfsense (NATed) and incoming call on port 5060 from a server that is facing a public IP with no NAT, like IPKALL for instance.  Good audio both ways.  (This is assuming you are using Manual outbound NAT with "static" checked.)
                      So, basically to get proper audio, at least one end needs to be facing a public IP directly with no NAT (like a SIP trunk provider) or you will need some NAT handling server like ICE or STUN, none of which has ever made much difference for me.  I've come to the conclusion that unless you plan to be registered with a public IP facing SIP trunk provider and keep all of your SIP clients behind the same firewall as the SIP server that you really need your SIP server to have its own seperate non-NATed public IP.
                      Only exception to this is IAX2 clients.  They always work every single time, static NAT or no, NAT or no.
                      But then again, I'm no expert.
                      • K
                        kejianshi
                        Another thing I've noticed about pfsense and SIP.
                        NAT reflection matters ALOT.
                        If you have phones that are inside the same LAN as the SIP server or are using a VPN to get inside the LAN, its best to address the server directly by the server's IP and port when entering server settings on the phone.
                        If the phone is always outside the network, its best to use either its public facing IP if thats static or to use the domain name if you are using dynamic DNS provider when entering server settings on the phone.
                        And if the phone is sometimes inside and sometimes outside the network, you may be up the creek because I have noticed that NAT reflection seems unreliable with UDP but reliable with TCP.
                        • R
                          Reiner030
                          @kejianshi:
                          thats why many SIP clients offers public/internal setup of IPs (like 3cs) to switch them easily between extern/internal network.
                          We setup our public SIP address in "DNS Forwarder" to the local IP address and let setup our handful softphones to use the name instead of IP so there is also all fine working ;)
                          • D
                            dhatz
                            @kejianshi:
                            Actually pfSense's NAT reflection doesn't work with UDP, it's a long-standing issue …
                            Check http://redmine.pfsense.org/issues/2281
                            • jimpJ
                              @dhatz:
                              @kejianshi:
                              Historically that has been true but on 2.1 with pure NAT mode, or with 1:1 NAT reflection, it might work. I haven't seen anyone try though.
                              Do not Chat/PM for help!
                              • K
                                kejianshi
                                Yeah, for me I know NAT reflection on UDP doesn't work behind pfsense, but I hated to make the blanket statement that no one could get it to work.  It would be more of an issue for me if NAT didn't break SIP all by its self thus making it a mute point.
                                If you use a portable IAX2 phone, then UDP NAT reflection is a bigger deal.
