    Problem with bridged mode and VDS (virtual distributed switch)
    1 Posts 1 Posters 2.2k Views
    • S
      seanlee
      For some reason, I cannot get pfsense to operate in a bridged mode in a vsphere 5 environment using a VDS. I've followed all the documentation at http://tinyurl.com/pf202-bridge, enabled promiscuous mode on the port groups, enabled net.link.bridge.pfil_bridge (1), etc. Has anyone had any luck with this? Here's my details:
      • pfsense 2.0.3 x64 VM, 4CPU, 4GB mem
      • Followed this guide: http://tinyurl.com/pf202-bridge (by William Tarrh)
      • vSphere 5.1 using vDS (virtual distributed switch)
      • Promiscuous mode enabled on LAN and WAN port groups
      • 3 virtual NICs (WAN, LAN, MGMT)
      • 4 pfsense interfaces (WAN, LAN, MGMT, and BRIDGE)
      • BRIDGE interface includes WAN and LAN
      Misc:
      • My centos VM on the LAN has a public IP address, but cannot even ping the WAN gateway
      • When I put the centos VM on the WAN port, it can ping the WAN gateway just fine
      • Both VMs are on the same ESX host (shouldn't matter though with VDS)
      • Everything else on the VDS works just fine (hardware is Cisco 5548 10G switch)
      • NAT mode works just fine
      • All interface FW rules set to "ALLOW ALL"
      • Changed NAT to manual (no NAT rules)
      EDIT: I also tried pfsense 2.0.2 and got the same results.
      All comments appreciated.
      -Sean
