    Routing problems when using two or more openvpnservers
    8 Posts 4 Posters 2.0k Views
    • L Offline
      ljoergensen
      Hi
      The first site-to-site vpn connection works like a charm.
      If I add a similar openvpnserver with new certificate+key for the new clientsite, The connection is established, but….
      Pfsense uses 10.0.9.5-6 as tunneling addresses!! NOT 10.0.9.1-2 as I would expect.
      In the routing list of the Pfsense I can see the 10.0.9.1-2 NOT 10.0.9.5-6, so obviously the routing goes wrong.
      I think this is a bug, but I need others to confirm this issue. Or at least an explanation on why Pfsense use the .5-6 ipaddresses on the other servers and not .1-2 ipaddresses.
      • L Offline
        ljoergensen
        I should mention, that I need several openvpn servers, because each site2site connection is between different sites2lan's.
        E.g one site connects to one lan behind pfsense…
          cmb
          That's just how OpenVPN works, the first /30 isn't assigned to clients. The routing is handled automatically internally by OpenVPN, just needs to be configured accordingly for the scenario you have.
          • L Offline
            ljoergensen
            Hi cmb
            Well, it's not the client ip-adresses, but the tunneling ip-adresses, which is wrong…
            The first 'setup' works like a charm, but the next doesn't..
            The next openvpn servers get's the 'top' ip-addresses, but in the routing table in pfsense you can see the 'bottom' ip-addresses. So, obviously the routing doesn't work for this second openvpn 'setup'.
            I'll try to get som images...
              phil.davis
              Using certificates, you can have a single OpenVPN site-to-site server with multiple client ends connecting in. At each client end is a router with a LAN on the end. You can add client-specific overrides to tell the server which remote LAN is behind which client. I have a couple like this, with 6 small offices connecting in to 1 OpenVPN at a main office.
              Or you can make a separate server for every client.
              • L Offline
                ljoergensen
                Hi Phil
                Your last suggestion is exactly what I try to achieve.
                I've gat some pictures which might help me to explain what my problem is…..
                Br Lars
                Openvpn-status.jpg_thumb
                Pfsense-routes.jpg_thumb
                Openvpn-config.jpg_thumb
                • L Offline
                  ljoergensen
                  ….and here's the other end....
                  Where it shows, that dd-wrt is told to use 10.0.8.5-6 for the tunnel, which is wrong..
                  dd-wrt-openvpn-status.jpg_thumb
                  • jimpJ Offline
                    That is correct for an SSL-based tunnel with a tunnel network larger than /30.
                    Here is a how-to for doing a multi-site OpenVPN + certificate setup where you have one server process and multiple clients:
                    http://doc.pfsense.org/index.php/OpenVPN_Site-to-Site_PKI_%28SSL%29
                    Pay particular attention to the notes about client-specific overrides and iroutes.
                    Do not Chat/PM for help!
