    Simple routing problem, lan <-> vpn lan
    7 Posts 2 Posters 3.0k Views
      bufflo
      Hello,
      I have a very simple question/problem, but I just couldnt figure out whats wrong. My LAN has the IP range 10.0.0.1-254, where .1 is my router with ISP access. The router connects to a OpenVPN server which has a local lan behind it with the ip range 192.168.1.1-254. The client ip of the VPN connection is 192.168.1.240.
      If connected, I can reach (ping) the IPs of the VPN LAN side on the router. But I cannot reach the 192.168.1.0 subnet from my clients behind the router (for example: ping 192.168.1.1 from 10.0.0.2). Heres my routing table from the router:
      Destination    Gateway        Genmask        Flags Metric Ref    Use Iface
      default        10.0.1.1        0.0.0.0        UG    0      0        0 eth1
      10.0.0.0        *              255.255.255.0  U    0      0        0 br-lan
      10.0.1.0        *              255.255.255.0  U    0      0        0 eth1
      172.20.16.0    *              255.255.248.0  U    0      0        0 tun0
      172.20.24.0    *              255.255.248.0  U    0      0        0 tun1
      192.168.1.0    *              255.255.255.0  U    0      0        0 tap0
      tap0 is the OpenVPN connection. Shouldnt that work already?
      vpn.gif_thumb
        Seems like you vpn network is the same as the remote network??  That doesn't work..  So you have this
        10.0.0.0/24 pfsense publicIP –- internet ---- publicIP pfsense 192.168.1.0/24
        What you want to use is a different tunnel network than what is on both sides of the vpn.. So you have something like this
        10.0.0.0/24 pfsense publicIP --- vpn 172.31.254.1 internet 172.31.254.2 vpn ---- publicIP pfsense 192.168.1.0/24
          bufflo
          Hello,
          what you mean it doesnt work? Of course does it work. The OpenVPN server is in bridge mode:
          option 'server_bridge' '192.168.1.1 255.255.255.0 192.168.1.240 192.168.1.242'
          I already can ping the OpenVPN server itself (192.168.1.1) and all clients on its lan. But just from the Router (VPN client), and not from my local lan clients (routing problem). See what I mean? I can reach all clients on the OpenVPN server side lan. But just from the machine where I initiate the connection from (my router). I cant reach the 192.168.1.0 subnet from my clients behind my router, and this is just a routing problem, but I coudlnt figure out yet what to do for solving this.
            Do a traceroute from your clients..
            Ahhh didn't see that at first – I would never do such a setup, what is the point?  I could see having to bridge if both sides where on the same network space..  Why can you just not do a normal tun connection?
            Here is thread on openvpn bridging http://forum.pfsense.org/index.php?topic=38605.0
            I just don't see the reason for it - if had to locations that needed to be connected via vpn, I would renumber 1 side before going bridge mode, etc.
              bufflo
              And why not use it this way? Whats the disadvantage of it? ALso your hint with doing a traceroute from the lan clients did the trick showing why it's not working:
              Routenverfolgung zu 192.168.1.1 über maximal 30 Hops
              1    1 ms    1 ms    <1 ms  201.lan [10.0.0.1]
                2    43 ms    19 ms    16 ms  172.20.16.1
                3    *        *        *    Zeitüberschreitung der Anforderung.
                4  ^C
              It goes the wrong direction. But why? It goes over 172.20.16.1 which is another vpn connection. But I cant see why it goes this direction. The routing table should tell it has to go through tap0:
              Kernel IP routing table
              default via 10.0.1.1 dev eth1  proto static
              10.0.0.0/24 dev br-lan  proto kernel  scope link  src 10.0.0.1
              10.0.1.0/24 dev eth1  proto kernel  scope link  src 10.0.1.1
              172.20.16.0/21 dev tun0  proto kernel  scope link  src 172.20.16.2
              172.20.24.0/21 dev tun1  proto kernel  scope link  src 172.20.24.4
              192.168.1.0/24 dev tap0  proto kernel  scope link  src 192.168.1.240
                "Whats the disadvantage of it? "
                bridge over a wan connection – all broadcast traffic is sent over a bridge, why would you want broadcast traffic over a wan based vpn?
                How are you looking at your routing table.. Can you just post up the screen shot from the gui?  Also do you have any policy based routing setup in your firewall rules to use specific gateway?  This would be used before the routing table.
                  bufflo
                  Hello,
                  sorry for my late reply, Christmas time was a bit hectic :( Thanks again and you were right again. There was a policy based routing rule I didnt thinkt about, something like this:
                  iptables -t mangle -A PREROUTING -s 10.0.0.0/24 -j MARK –set-mark 2
                  And I set anoher one which solved the issue:
                  iptables -t mangle -A PREROUTING -d 192.168.1.0/24 -j MARK --set-mark 1
                  But now I have nother problem :/ I read myself into why I should use tun instead of tap and not bridging, because like you said it would produce lots of broadcast traffic for example. So I changed my server config to this:
                  config 'openvpn' 'lan'
                  	option 'enable' '1'
                  	option 'port' '1194'
                  	option 'proto' 'udp'
                  	option 'dev' 'tun2'
                  	option 'ca' '/etc/easy-rsa/keys/ca.crt'
                  	option 'cert' '/etc/easy-rsa/keys/server.crt'
                  	option 'key' '/etc/easy-rsa/keys/server.key'
                  	option 'dh' '/etc/easy-rsa/keys/dh2048.pem'
                  	#option 'ifconfig_pool_persist' '/tmp/ipp.txt'
                  	#option 'ifconfig-pool' '10.8.0.2 10.8.0.10 255.255.255.0'
                  	option 'keepalive' '10 120'
                  	option 'comp_lzo' '0'
                  	option 'persist_key' '1'
                  	option 'persist_tun' '1'
                  	option 'status' '/tmp/openvpn-status.log'
                  	option 'verb' '3'
                  	#option 'server_bridge' '192.168.1.1 255.255.255.0 192.168.1.200 192.168.1.205'
                  	option server "10.8.0.0 255.255.255.0"
                  	list push "route 192.168.1.0 255.255.255.0"
                  But again I cant get it to work, and it's even worse now than before with the bridging, where in the end I got it to work.
                  First confusing thing is that it shows this on the client:
                  tun2      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                            inet addr:10.8.0.6  P-t-P:10.8.0.5  Mask:255.255.255.255
                  And on the server:
                            inet addr:10.8.0.1  P-t-P:10.8.0.2  Mask:255.255.255.255
                  Why two adresses for each? and why does the client get 6 (and 5?) and not 2? Also I cant even ping from side to side from the client to the server. My routing table looks a little bit weird too:
                  10.8.0.1        10.8.0.5        255.255.255.255 UGH  0      0        0 tun2
                  10.8.0.5        *              255.255.255.255 UH    0      0        0 tun2
                  192.168.1.0    10.8.0.5        255.255.255.0  UG    0      0        0 tun2
                  And on the server:
                  default        188-194-- 0.0.0.0        UG    0      0        0 eth1
                  10.8.0.0        10.8.0.2        255.255.255.0  UG    0      0        0 tun2
                  10.8.0.2        *              255.255.255.255 UH    0      0        0 tun2
                  172.20.24.0    *              255.255.248.0  U    0      0        0 tun0
                  188.194.*.0  *              255.255.255.0  U    0      0        0 eth1
                  192.168.1.0    *              255.255.255.0  U    0      0        0 br-lan
