    After power outage, settings not quite right - 2 bugs
    Scheduled Pinned Locked Moved 2.1.1 Snapshot Feedback and Problems - RETIRED
    6 Posts 4 Posters 3.4k Views
      Keljian
      Hi all,
      I am running pre2.1.1, and found the following bug:
      After a power outage, I noticed my pfsense box didn't come back up properly. Dhcp wasn't working nor was the network bridge I had set up. I couldn't get back to the GUI so first tried a restore from backup at the console, but that didn't change anything, so did a default settings reset, followed by a restore from backup XML.
      This seemed to fix the issue, however I lost my snort rules settings, despite flagging in the backup restore module that I wanted settings from packages stored.
      Guessing there are two bugs here.
      Cheers
      • jimpJ Offline
        Not likely a 2.1.1 bug. Power outage might have caused some filesystem corruption but that's not something we can avoid in every possible case.
        Do not Chat/PM for help!
          Keljian
          (dumb question) Would turning off write cache help?
            maverick_slo
            Not a dumb question.
            Yes it would help if you have write cache without battery :)
              Keljian
              Well could it please be implemented as a gui option then? - because it could save a few people some issues.
              • E Offline
                eri--
                It is alredy is.
                Just use the system tuning page.
