    Scheduled blocks won't work without manual states reset
    71 Posts 25 Posters 29.7k Views 9 Watching
      tucansam
      I configured an alias for some devices, then a schedule for said devices.  My rules are (in order from top to bottom) block hosts access using the schedule, then pass hosts traffic using the limiter, then the two default allow and rules.
      When the schedule came today, traffic continued to pass for the blocked hosts.  Once I manually reset states, the block took effect.
      Tonight when the schedule ends, I'll see if traffic starts passing again.
      What could I be doing wrong?
        duanes
        I have asked this question many times and NEVER gotten a response.  I have been using pfSense for 5+ years and this issue has been COMPLETELY ignored.  I have a hard time even finding anyone else that has ever tried the scheduled filter changes.
        I have found that the filter reload process is very unstable.  Once you get everything set, try a reboot.  The schedules should work, but making more than one of two changes to any pfSense configs seems to cause the demise of the scheduling thread and thus, the failure to function.
        I also tried setting a manual cron script to reload the filters one minute after each of my schedule changes, but this causes all sort of issues generally resulting in 30-60 second outages every time the script runs.
        Good Luck.
          digital_janitor
          I am having this EXACT same issue.  Basically I turn the internet off for my kids at 10:30.  However, any existing connections will stay open.  For example, if my  son is skyping his girlfriend, skype will continue to work.  If he exists skype, and restarts it however, it will not work.  Would there be some way to cron something that resets the states, or something of that nature?
            duanes
            I believe that virtually all pf functions can be used by pfctl.  In fact, I think pfSense is merely a wrapper for the pf commands in BSD unix.
            You might google for pfctl command line examples as I'm pretty sure there is a way to reset the states table from the command line.  This would "clear" any active connections.
              digital_janitor
              Thank you.  pfctl -F state did in fact kill it.  I will investigate to see if there is a more granular way to do it.
                kryptos
                Please check option in setting Settings / Advanced / Miscellaneous: "Schedule States" which was set as the default "clear the states of existing connections when expiry time has come" make sure its not check.
                And do note also block rules does not relates to states. meaning the settings above does not effected if you have block rules in schedule  you just have to add scheduled alllow rule for the states to reset.
                Have mine working effectively without resetting states manually.
                Regards,
                Rocel
                  tucansam
                  kryptos,
                  That box is not checked in my config.
                  My rules are attached.  I know I probably need to post the specifics, but at least you can see the order.  Two on top for blocking based on schedule, two in the middle for allowing but with bandwidth limits, and the two default on bottom.
                  Right now for example the schedule should not be running – clients should have access.  But they do not.
                  baUntitled.png_thumb
                    tucansam
                    Despite trying many things, putting rules in various orders, etc., I am wholly unable to get this to work.
                    Can anyone offer any other solutions?
                      Guest
                      @kryptos:
                      Regards,
                      Rocel
                      But if I have to have allow rules (instead of block rules), I basically have to allow any, any, but in general I have only very few things allowed at all (most things not available from LAN). How to implement that with scheduled access for some users?
                      Edit: I have now an alias for the ports to allow and a scheduled allow rule, let's see how this works!
                      With the block rule and 3 minutes later a "pfcrtl -F state" (via Cron job) these guys managed (with an open browser…) to re-establish states and play on 2 hours after the scheduled block had started...
                      EDIT: There was a syntax error in the pfcrtl command that didn't make it work, with the correct "pfcrtl -F state" it's definitely GAME OVER; however, all other users get their states killed, too. Only killing states for the respective user(s) with "pfctl -k <ip>" doesn't do the job…
                      PS: Some general remarks by a pro, as usual that general ("You may need to use the -k twice, etc.") that the NOOB fraction can't get where they want to without 2 hours of man pages and trial and error and and and…
                      https://forum.pfsense.org/index.php?topic=76053.msg418139#msg418139</ip>
                        kryptos
                        @tucansam:
                        kryptos,
                        Your rules should be fine. what is schedule details?
                        What are your goals for this be specific.
                        Regards,
                        Rocel
                          tucansam
                          Specifically:
                          I have an alias created called "kids_devices."  This contains assigned IPs for iPods, Kindles, and other crap devices I wish the kids didn't have.  Also, the Nintendo Wii, and the family PC.
                          I want all of these devices to be limited to 300k down/250k up, except the Wii, at 500k down, 250k up.  That worked until today, when suddenly one of the Kindles was doing 20mbps downstream.  I reset the states table and it went back to being limited.  First problem: my limiter works most of the time, not always.  Why I can't get it to work 100% of the time is totally beyond me, seems simple enough.
                          Anyway, either with the limiter rules as separate rules, or adding them to schedule rules, I want to create schedule that allow "kids_devices" to access the internet from 1200-1500 and 1900-2200 hrs.  I want no internet access for and of those devices outside of these times.
                          I'm not sure how many rule sets I need to create (ie one for allow during said times, a separate one for block during opposite times, etc) and what order to put them in.  I've tried various combinations of all of it (rules for block, rules for allow, block rules on top in the stack, allow rules on top in the stack, etc) and nothing ever worked (everything was either blocked all the time or allowed all the time).  I guess maybe the simplest would be to create a block rule that blocks "kids_devices", and under that create an allow rule for the specified times?  Again I have no idea how to do it or what order to use, but everything I've tried to this point doesn't work.
                          And resetting my states table has become a daily thing for any number of reasons which seem to break the network, rules are ignored, limits are ignored, etc.
                          Which is annoying.
                            Guest
                            What I learned throughout the last weeks: Nobody is interested to make something like this really work. I have a simple block rule for the time, when internet is off-limits. Doesn't work, as the states stay alive.
                            Next I tried a Cron ob to kill the states for the IPs blocked, didn't work and a Cron job to kill all states doesn't work, either. Also an eMail report (which basically works via a Cron job) is not working properly. Re-installing the Cron package didn't change anything. I could try a fresh install, but I don'T have the time.
                            Only thing that helps: Filter the states under Diagnostics -> States and kill them.
                            Block or allow rules made no difference to me. I have the block rule for the kids very high in the list of firewall rules and subsequently the "allow" rules for all LAN IPs for certain ports.
                              tucansam
                              Sad.  I continue to have problems with the limiter, rules, and I've given up on schedule times.
                              Certainly you and I are not the only ones who would like to use this feature.  Wonder why its not a priority?
                                Guest
                                Best guess: "Repressive parents" are the bad guys in this play, "little children looking for freedom" the good guys?  ;)
                                  tucansam
                                  @chemlud:
                                  Ha.  Well what about someone who wants to keep an ftp server running on his LAN, but only open it up for WAN access during certain hours?  Or shutdown the internet completely when he's not home (without powering down the cable modem) to minimize attacks?
                                  Surely there is more use for these schedules than repressive parents stealing freedom away from their young'ns.  If only the schedules worked….
                                    Guest
                                    Try this:
                                    • Have your scheduled block rule in the LAN firewall rules
                                    • Install Cron package
                                    • Create a Cron job to be run 1 minute after the block becomes effective with the command:
                                    /sbin/pfctl -k >IP on the block list<
                                    (afaik the aliases won't work for Cron, so one job for each IP)
                                    works for me now:
                                    https://forum.pfsense.org/index.php?topic=76053.msg424483#msg424483
                                    To monitor the states I also have an eMail Report for the states of the respective IPs, sending the output for the command /sbin/pfctl -ss | grep >IP on the block list<
                                    You could configure the block rule to start e.g. at 20:59
                                    At 21:00 you could run the Cron for killing the states and for reporting the states, to see how it works (I have to check if the states killer runs before the eMail Report job, I'll try this evening).
                                    Edit: Work's fine with the kill and subsequent eMail Report :-)
                                      Harvy66
                                      This is my understanding, which could be wrong.
                                      Firewall rules only apply to new connections, it would be crazy expensive to check every packet against every rule.
                                      When a packet comes in on an interface, it firsts checks to see if an existing state exists, which is fast because of hash functions for constant time look ups. If the state does not exist, it then goes to the firewall rules to decide if a state will get created, where it does a linear time check.
                                      Existing states: O(1)
                                      New states: O(n)
                                        Guest
                                        Might be correct, but me as an idi** expects a scheduled block rule to BLOCK EVERYTHING when the schedule is due. So the block rule should kill automatically the respective states (which it is supposed to do in pfSense, as there is an option NOT to kill the states for firewall block rules).
                                        To me it's a mystery why my pfSense doesn't kill the states automatically…
                                          robi
                                          Agree.
                                          Even a cheap TP-Link home router is able to block everything when the schedule is due. There's a nice option in their firmware's web interface to do that.
                                          • F Offline
                                            framer99
                                            I'm dealing with this same issue trying to shut off internet to two IPs on my lan at 11pm through 10am.
                                            The System/Advanced/Misc check box for "Schedule States" says:
                                            "By default schedules clear the states of existing connections when the expiration time has come. This option overrides that behavior by not clearing states for existing connections. "
                                            Note that what I'm describing below requires the above checkbox to be UNchecked, which is the default.
                                            The point is that there actually IS an Automatic reset of the related states from the state table like you (we ) desire, but this state reset only occurs at rule expiration time. This makes sure that any connections that are being allowed by the rule are killed when the rule goes away.
                                            So the logic we need to use is that the traffic of interest is normally BLOCKED by an always active rule, and during the scheduled interval a preceding rule will ALLOW the traffic.  When the ALLOW rule is active it will allow the packets and prevent the always active Blocking rule from being hit.
                                            When the scheduled rule expires, the states (any active connections that were being allowed) will be reset and both existing and new connections will be prevented by the always active block rule which is below the scheduled rule.
                                            When the scheduled rule goes active again at the next scheduled interval start, it will allow connections and not care about the "state of the state table".
                                            Seems logical anyway… here's a screenshot of what I'm about to try(it's outside the schedule time in this view):
                                            (Also note that I had IPv6 enabled on the kids dekstops and they could still get to google etc that had an IPv6 site... so turn of ipv6 on the hosts or add duplicate rules for ipv6)
