    Scheduled blocks won't work without manual states reset
    71 Posts 25 Posters 28.2k Views 9 Watching
      Guest
      "So the logic we need to use is that the traffic of interest is normally BLOCKED by an always active rule, and during the scheduled interval a preceding rule will ALLOW the traffic."
      Yeah, but with your setup you allow each and everything within the kids hours, I allow only very specific things (http, https, smtps, imaps and very few other ports) and this setup is rather difficult to obtain with your kind of rules, as you would need a rule for every port (or some/ a lot of additional aliases for the IPs/ports allowed…).
      • F Offline
        framer99
        @chemlud:
        that's true, but you must already have the appropriate allow rules as you explain… so just make those scheduled, and follow them with a single block rule... you can block all right? not just block the ports of interest, so you only need the one block rule.
          Guest
          But I have very different blocking times for different user groups. I tried it once with your setup, but gave up after some hours and found the solution described above, which works fine for me now… ;-) I still think it'S the better option for complex situations and restrained internet access with a general block rule and isolated services allowed.
            jabbasi
            Now in my Case things are working totally differently
            An Alias called Block_Access with IPs = 192.168.0.12 and 192.168.0.13
            Schedule :  Mon to Sun 6:30 PM to 9:00PM and Mon-Sun 10:00PM to 23:59PM
            FW rule on LAN :  IPV4  block  Source= Single host or Alias = Block_Access
            I get access blocked no issue when clock hits the scheduled time my device can't do anything; but when block schedule expires my device still stays blocked and never gets access to internet.
            only way so far i have tried is simply disable the rule; as in block there is no state that i need to clear.
              thecableguy
              @jabbasi:
              I believe it works better if you create a 'PASS' rule with the scheduled time for when you want to 'ALLOW' access and also create another 'BLOCK' rule for the alias/IP.
              You also need to pay attention to the order of the rules.. the 'BLOCK' rule needs to be below the scheduled 'PASS' rule..
              • O Offline
                Overhacked
                The relevant code that kills states when a scheduled rule expires is this pfSense project patch to the FreeBSD pf code: https://github.com/pfsense/FreeBSD-src/commit/49045005c714cd18a0f844d1a70047abaab7523a
                The code keeps track of states that are part of a schedule rule by tagging them as they are created, so it is a trivial matter to remove them when the schedule expires. It seems it would be a bit more complicated to dig through all the states looking for the ones that match a scheduled block. I had hoped to tackle this with a patch; maybe some day.
                Apologies for posting an apology with no action, but I wanted to leave a lasting note here of where the relevant code is so that I or someone else can find it in the future.
                P.S. I am using the "pass rule that expires" work-around to make sure that states get killed when my scheduled reject rule begins.
                  sonidoP
                  How can I apply the patch?
                  My pfsense version is 2.3.2-RELEASE-p1  and use the web interface patches, How much do test, the result is:
                  Patch can NOT be applied cleanly (detail)
                  Patch can NOT be reverted cleanly (detail)
                  /usr/bin/patch –directory=/ -t -p1 -i /var/patches/586c4515ba093.patch --check --forward --ignore-whitespace
                  Hmm...  Looks like a unified diff to me...
                  The text leading up to this was:
                  |From 49045005c714cd18a0f844d1a70047abaab7523a Mon Sep 17 00:00:00 2001
                  |Date: Mon, 17 Aug 2015 13:52:56 -0300
                  |Subject: [PATCH] Importing pfSense patch schedule_label.RELENG_10.diff
                  | sbin/pfctl/parse.y        | 44 ++++++++++++++++++++++++++++++++++++++++++--
                  | sbin/pfctl/pfctl.c        | 32 +++++++++++++++++++++++++++++++-
                  | sys/net/pfvar.h          |  7 +++++++
                  | sys/netpfil/pf/pf_ioctl.c | 24 ++++++++++++++++++++++++
                  | 4 files changed, 104 insertions(+), 3 deletions(-)
                  |diff --git a/sbin/pfctl/parse.y b/sbin/pfctl/parse.y
                  |index 2991473..62a78d1 100644
                  |--- a/sbin/pfctl/parse.y
                  +++ b/sbin/pfctl/parse.y
                  No file to patch.  Skipping...
                  Hunk #1 ignored at 235.
                  Hunk #2 ignored at 343.
                  Hunk #3 ignored at 446.
                  Hunk #4 ignored at 491.
                  Hunk #5 ignored at 1913.
                  Hunk #6 ignored at 2371.
                  Hunk #7 ignored at 3722.
                  Hunk #8 ignored at 5123.
                  Hunk #9 ignored at 5132.
                  Hunk #10 ignored at 5185.
                  Hunk #11 ignored at 5196.
                  Hunk #12 ignored at 5459.
                  Hunk #13 ignored at 6091.
                  13 out of 13 hunks ignored while patching sbin/pfctl/parse.y
                  Hmm...  The next patch looks like a unified diff to me...
                  |diff --git a/sbin/pfctl/pfctl.c b/sbin/pfctl/pfctl.c
                  |index 64b4a05..1e957f6 100644
                  |--- a/sbin/pfctl/pfctl.c
                  +++ b/sbin/pfctl/pfctl.c
                  Hunk #1 ignored at 78.
                  Hunk #2 ignored at 118.
                  Hunk #3 ignored at 656.
                  Hunk #4 ignored at 2024.
                  Hunk #5 ignored at 2138.
                  Hunk #6 ignored at 2352.
                  6 out of 6 hunks ignored while patching sbin/pfctl/pfctl.c
                  |diff --git a/sys/net/pfvar.h b/sys/net/pfvar.h
                  |index 0b8f0ac..ba8b1d9 100644
                  |--- a/sys/net/pfvar.h
                  +++ b/sys/net/pfvar.h
                  Hunk #1 ignored at 488.
                  Hunk #2 ignored at 1288.
                  Hunk #3 ignored at 1373.
                  3 out of 3 hunks ignored while patching sys/net/pfvar.h
                  |diff --git a/sys/netpfil/pf/pf_ioctl.c b/sys/netpfil/pf/pf_ioctl.c
                  |index 96abf2c..23b9efc 100644
                  |--- a/sys/netpfil/pf/pf_ioctl.c
                  +++ b/sys/netpfil/pf/pf_ioctl.c
                  Hunk #1 ignored at 1709.
                  1 out of 1 hunks ignored while patching sys/netpfil/pf/pf_ioctl.c
                  done
                  /usr/bin/patch --directory=/ -f -p1 -i /var/patches/586c4515ba093.patch --check --reverse --ignore-whitespace
                  Hunk #2 ignored at 342.
                  Hunk #3 ignored at 444.
                  Hunk #4 ignored at 489.
                  Hunk #5 ignored at 1911.
                  Hunk #6 ignored at 2366.
                  Hunk #7 ignored at 3710.
                  Hunk #8 ignored at 5106.
                  Hunk #9 ignored at 5114.
                  Hunk #10 ignored at 5165.
                  Hunk #11 ignored at 5173.
                  Hunk #12 ignored at 5434.
                  Hunk #13 ignored at 6065.
                  Hunk #2 ignored at 117.
                  Hunk #3 ignored at 654.
                  Hunk #4 ignored at 2003.
                  Hunk #5 ignored at 2117.
                  Hunk #6 ignored at 2325.
                  Hunk #2 ignored at 1287.
                  Hunk #3 ignored at 1367.
                  done
                  Is this solution included in a beta version or binari files compiled?
                  Thanks for any help.
                  • O Offline
                    Overhacked
                    Sorry to mislead. The link I posted is not a patch to add this feature, it is the CURRENT pfSense code that implements state killing for expiring pass rules.
                    The code works by finding states that have been marked by the scheduled pass rule. To implement state killing for scheduled block rules, new code would be needed to find all not marked states that match the block rule, which this code doesn't do at all.
                      M_Devil
                      Searching the forum I ran into this thread. Seems my post from this morning relates to this issue.
                      In my case even a (UDP) state returns after manual kill of state enabling Skype to keep running. Please have a look at: https://forum.pfsense.org/index.php?topic=125534.0
                      Earlier in this thread I read about same issue (Skype keeps running).
                        thecableguy
                        Good luck, I have been chasing this for months..
                        I find the rules work until you modify the schedule portion of the rule.. If you manually clear states for the target IP after changing the schedule, they do re-establish, even though people on this forum swear this shouldn't happen.
                        I find the only way to fix is to try to reset all states and if that doesn't fix, reboot.
                        Seems to be something broken with the schedules and how they relate to the rules.
                        • - Offline
                          -RYknow
                          So in my hunting it would appear that setting up a schedule with pfsense isn't very likely to happen? I'm messing with this here at home first, as I have a customer with a similar request. So at home my daughters ipod has become the guinea pig.
                          Basically I have created a static mapping for her device. I've also created a schedule. I've created a block rule for the IP of the ipod, as well as an allow rule, which has the schedule selected. It appears to be working for the most part, however imessage continues to work.
                          I downloaded the cron package, and I was going to use the pfctl -F command. Is this going to work, or am I beating a dead horse here with this setup?
                          -RYknow
                            thecableguy
                            I have had hit and miss success with the cron task and filtering Steam.
                            My setup is to BLOCK the ALIAS and then place an ALLOW rule with schedule ABOVE the BLOCK rule in the LAN tab.
                            The wheels fall off if I modify a schedule. I find clearing states does not work as expected and a full reboot is required to get things back on track after adjusting the schedule.
                            • - Offline
                              -RYknow
                              I'll need to double check how I have things setup.
                              I'm wondering if my issue is IPv6 related? Does that make any sense?
                              -RYknow
                                thecableguy
                                Possibly but I have blocked IPv6 on my network.
                                • - Offline
                                  -RYknow
                                  That's my next step. I'll just block it and see if it fixes my problem.
                                  EDIT: IPv6 seems to have been the ticket. Since disabling IPv6 traffic on my network, all the devices are working correctly with the above mentioned schedule.
                                  -RYknow
                                    thecableguy
                                    @-RYknow:
                                    -RYknow
                                    Have you modified schedules, waited until the next schedule change and found the states remain on some UDP packets?
                                    • - Offline
                                      -RYknow
                                      Yes. I was never able to get it to work correctly with the ipod. I ended up just creating the schedule via the unifi software… but I would like to get it sorted at the router level instead.
                                      -RYknow
                                        thecableguy
                                        The thing that surprises me the most is how long this issue has been floating around without being addressed.. Surely there would be others who could use this feature?
                                        • - Offline
                                          -RYknow
                                          Yeah, you triggered my memory about this and I went and played with it last night… I set an ipod up with just strickly a block rule, (picked block... and chose the IP). and imessage still works... I have I have ipv6 disabled, as I was thinking maybe the traffic was using ipv6.... but imessage still works. Very strange.
                                          -RYknow
                                            thecableguy
                                            Yeah, I can get this working on a test laptop reliably with a cron task to kill off states after the schedule expires but it doesn't work on the existing rules.
                                            I will delete all the rules and start fresh.
