    Wep - problem on Beta2
    34 Posts 7 Posters 16.6k Views
      Always
      Is it possible to run a cvs_sync running on the embedded image for wrap systems? If not, how can I get thos latest changes to run on my wrap to test if they solve the problems with hostapd.
        sullrich
        @Always:
        No.  It's not possible.  You need to wait till rc1.
          Always
          Isn't there any way to update the file or edit the code to put in the changes you made? Maybe through the edit function on the webgui.
          If not, could you give me an idea about when the RC1 will be available?
          EDIT:Already read that RC1 will be out "very soon".
            Dr. Gno
            Updated to RC1 and brief ran the WAP to see if the card would work.  No luck, smae gross symptom.  Will try to capture on logs one night this week.
              artur_filipowicz
              I tried run wep on RC1 and it still don't work….
              Regards
              Artur
                Stiv32
                After upgrade to RC1 all wirelless stuff working worse. Now i have problem with WPA to (not only WEP) - clients cannot associate. So, in this moment i come back to version B4 despite to on this version dont working WEP  but WPA working fine. In wersion RC1 all cryptography stuff (wirrelles) not working.
                  hoba
                  I just did some extensive testing with WPA and WEP on my WRAP with CM9 in turbo A mode, dedicated subnet, non bridged:
                  • WPA always works fine in hostap and infrstructure mode
                  • changing WPA settings works fine, no need to reboot
                  • WEP only works the first few seconds after saving settings at the webgui and dies after some time though the client stays authenticated. This seems to be somehow driver related, we are still debugging. It sometimes stays up but that is not very likely from my debuging tests atm.
                  • due to a logic bug at the webgui it always generates "authentication" "shared key authentication" no matter what is entered at the webgui. Set your clients to use shared key until this bug is fixed when using WEP
                  • WEP seems to work fine when configured at bootup (this points even more into direction of driver issues)
                  • going from broken WEP config back to WPA via webgui always works fine for me without reboot
                  So what to do when trying to run WEP for the meantime:
                  • clients have to be set to "shared key"
                  • reboot the pfsense after enabling WEP
                  In case you still have issues please let us know what hardware you are running this on (system, nics, wireless driver utilized, bridged config, seperate subnet, …anything that might be special about your config).
                    hoba
                    All bugs except the probably driver related ones were just fixed by Scott. In case you have a full install run a "cvs_sync.sh RELENG_1" or manually update your files via webgui diagnostics>edit file if you are on embedded platforms:
                    http://cvstrac.pfsense.com/chngview?cn=12715
                    http://cvstrac.pfsense.com/chngview?cn=12713
                      Always
                      WPA seems to work ok, previous problems with beta4 have disappeared, haven't tried wpa+captive portal yet but I'm going to try now.
                        hoba
                        We did some extensive tests with WPA and Captive Portal and fixed a bug there. Should work.
                          Always
                          Confirmed that wpa+captive portal works, I only have problems when setting a redirect page, in that case, I authenticate and when trying to redirect I am sent to the captiveportal page again and again.
                          BTW, I could not edit any files with the "Edit file" option through web. Is this because I run on a WRAP box?
                            hoba
                            @Always:
                            I have used edit file from the webgui a lot of times on a wrap for debugging or just replacing an old file with a newer version. Works without any issues. Not sure what might be the problem here.
                              Always
                              Maybe I wasn't using the correct route to the file I wished to modify. It kept saying that the file could not be found.
                                sullrich
                                Route?  You mean path?  Unix uses /path/to/file.
