    2.2BETA: Atheros ar9227 extremely unstable wifi, plus N mode does not work.
    Scheduled Pinned Locked Moved 2.2 Snapshot Feedback and Problems - RETIRED
    26 Posts 10 Posters 10.7k Views
      darkphantom934
      I recently bought an atheros PCI (not PCI express) wireless NIC (the TP-Link TL-WN751ND) and after overcoming some problems initially with setup, fixed the setup of the card.
      Now the card works, but the wifi is extremely unstable. The most recent messages are:
      Oct 27 21:08:35 kernel: ath0_wlan0: ieee80211_new_state_locked: pending RUN -> SCAN transition lost
      Oct 27 21:08:35 kernel: ath0: ath_reset_grablock: didn't finish after 10 iterations
      Oct 27 21:08:35 kernel: ath0: ath_reset_grablock: warning, recursive reset path!
      Oct 27 21:08:35 kernel: ath0: ath_chan_set: concurrent reset! Danger!
      This results in sparse dropped connections. In addition, I cannot set the cards to n-mode or else I get a kernel panic (will post details if asked, unfortunately I don't have them right now). Any ideas? If you'd like me to help with fixing this problem code-wise, I have C experience and would love to help fix this annoying issue. Thanks!
        cmb
        What settings do you have configured on its interfaces page?
        I'm testing various things on an APU with this wireless kit.
        ath0: <atheros 9280="">ath0: AR9280 mac 128.2 RF5133 phy 13.0</atheros>
        Seems it gets stuck at "no carrier" with any mode including 11n set on interfaces.php. Set it to 11g and it works fine, and actually shows up as 11b/g/n.
        I need to do some more testing to narrow down what's happening.
        Your experiences and what you have configured (and other options tried) in the GUI would be appreciated. You can check "ifconfig ath0" and "ifconfig ath0_wlan0" to see what's actually configured in the underlying OS.
          rjcrowder
          I've now tried three pci-e cards under 2.2 with poor luck all the way around… Intel does not work in hostap mode and atheros seems to only work in 'g' mode. Even if the interface comes up and says b/g/n, it only functions at 'g' speed.
          The cards I've tried:
          Atheros 9287 - Only works in 'g' mode as you described. Must manually pick a channel.
          Atheros 9285 - Same as above
          Intel 5110 - Does not work in hostap mode.
            cmb
            That Intel card doesn't support hostap mode in the hardware, that's nothing to do with software.
            The Atheros n cards, yeah something going on there with n.
              darkphantom934
              @cmb:
              Any idea what the ath_chan_set warnings are? I'm having some issues there as well. Here's my "ifconfig ath0_wlan0" output:
              ath0_wlan0: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500
              ether e8🇩🇪27:7b:7a:f4
              inet6 fe80::eade:27ff:fe7b:7af4%ath0_wlan0 prefixlen 64 scopeid 0x8
              inet 192.168.2.1 netmask 0xffffff00 broadcast 192.168.2.255
              nd6 options=21 <performnud,auto_linklocal>media: IEEE 802.11 Wireless Ethernet autoselect mode 11g <hostap>status: running
              ssid ****** channel 7 (2442 MHz 11g) bssid e8🇩🇪27:7b:7a:f4
              regdomain FCC country US ecm authmode WPA2/802.11i privacy MIXED
              deftxkey 2 AES-CCM 2:128-bit AES-CCM 3:128-bit txpower 30 scanvalid 60
              pureg protmode OFF burst -apbridge dtimperiod 1 -dfs
              Also, a kernel panic caused by changing to N mode (also caused by changing channels):
              <118>Bootup complete
              ath0: ath_reset: concurrent reset! Danger!
              Fatal trap 12: page fault while in kernel mode
              cpuid = 3; apic id = 03
              fault virtual address = 0x378
              fault code = supervisor read data, page not present
              instruction pointer = 0x20:0xffffffff80a68541
              stack pointer         = 0x28:0xfffffe022ec318a0
              frame pointer         = 0x28:0xfffffe022ec31920
              code segment = base 0x0, limit 0xfffff, type 0x1b
              = DPL 0, pres 1, long 1, def32 0, gran 1
              processor eflags = interrupt enabled, resume, IOPL = 0
              current process = 0 (ath0 net80211 taskq)
              version.txt06000023412423767414  7624 ustarrootwheelFreeBSD 10.1-RC3 #41 e0dae58(releng/10.1)-dirty: Mon Oct 27 15:38:29 CDT 2014
                  root@pf22-amd64-snap:/usr/obj.amd64/usr/pfSensesrc/src/sys/pfSense_SMP.10</hostap></performnud,auto_linklocal></up,broadcast,running,simplex,multicast>
              • dotdashD Offline
                dotdash
                Try setting the regulatory settings. Mine was defaulting to DEBUG and when I connected it was showing g speeds. I set it to FCC, USA. indoor and the connection now shows 135.
                Technical details for those not following the other thread:
                APU with 9285/AR5B95 running 2.2B
                Interface is configured as an AP, WPA2, AES, standard set to ng, nonly.
                Note this is a test box, not connected to the Internet. I am basing connection speeds on what a Windows laptop tells me when I connect to the AP. No throughput tests were done.
                  darkphantom934
                  @dotdash:
                  My regulatory settings are on FCC without a difference. I tried your other settings and it still isn't working. Would you mind posting your configuration? Thanks!
                  If there's any more information you'd like me to provide, just mention it.
                    cmb
                    @dotdash:
                    Sure enough. Exact same thing here after further testing. Now set the same as yours, and I was associated at 135. Though now it's having issues in general, and I'm short on time for now. Will have to revisit later.
                    Experiences of others would be appreciated.
                      cmb
                      @darkphantom934:
                      I haven't seen that in particular, though Googling it finds people with the same on FreeBSD. I only briefly reviewed the results, didn't see an answer anywhere, but it's worth searching on to see what you can find.
                      My best guess, from experiences in earlier releases (though current wifi is vastly diff) is maybe try setting the channel differently. Don't put it on auto, try setting something specific. If it's already set to something specific, try a diff channel.
                      • dotdashD Offline
                        dotdash
                        Here is my card:
                        ath0: <atheros 9285="">at device 0.0 on pci4
                        [ath] AR9285 Main LNA config: LNA2
                        [ath] AR9285 Alt LNA config: LNA1
                        [ath] LNA diversity enabled, Diversity enabled
                        [ath] Enabling diversity for Kite
                        ath0: [HT] enabling HT modes
                        ath0: [HT] 1 stream STBC receive enabled
                        ath0: [HT] 1 RX streams; 1 TX streams
                        ath0: AR9285 mac 192.2 RF5133 phy 14.0
                        ath0: 2GHz radio: 0x0000; 5GHz radio: 0x00c0</atheros>
                        ifconfig ath0_wlan0 list caps
                        drivercaps=4f85ed01 <sta,ibss,hostap,ahdemo,txpmgt,shslot,shpreamble,monitor,mbss,wpa1,wpa2,burst,wme,wds,txfrag>cryptocaps=1f <wep,tkip,aes,aes_ccm,tkipmic>htcaps=7014e<chwidth40,shortgi40></chwidth40,shortgi40></wep,tkip,aes,aes_ccm,tkipmic></sta,ibss,hostap,ahdemo,txpmgt,shslot,shpreamble,monitor,mbss,wpa1,wpa2,burst,wme,wds,txfrag>
                        ifconfig ath0_wlan0
                                ether 0c:60:76:66:66:66
                                inet6 fe80::e60:7666:6666:2485%ath0_wlan0 prefixlen 64 scopeid 0x9
                                inet 172.22.144.1 netmask 0xffffff00 broadcast 172.22.144.255
                                nd6 options=21 <performnud,auto_linklocal>media: IEEE 802.11 Wireless Ethernet autoselect mode 11ng <hostap>status: running
                                ssid Tigerbomb channel 1 (2412 MHz 11g ht/40+) bssid 0c:60:76:66:66:66
                                regdomain FCC country US indoor ecm authmode WPA2/802.11i
                                privacy MIXED deftxkey 3 AES-CCM 2:128-bit AES-CCM 3:128-bit
                                txpower 30 scanvalid 60 protmode OFF ampdulimit 64k ampdudensity 8
                                shortgi puren burst -apbridge dtimperiod 1 -dfs</hostap></performnud,auto_linklocal></up,broadcast,running,simplex,multicast>
                        When booting I get this error. Also seems to happen every time I change settings on the interface:
                        Configuring OPT2 interface…ath0: ath_reset_grablock: didn't finish after 10 iterations
                        done.
                          darkphantom934
                          Does anyone here think that it might have something to do with the 5GHz band of these cards? This issue is becoming really annoying as it's preventing me from using n wifi…
                          • dotdashD Offline
                            dotdash
                            They have no 5Ghz band. 9287/9227 is 2.4 only. The message where it returns values for 2GHz and 5GHz radios is confusing.
                              Pertan
                              @cmb:
                              I'm not using AR9227 but a card with AR9380 and I cant get N to work either. Tried to set Regdomain to FCC, USA and indoors but still only 54M.
                              Currently running the latest snap as well( built on Thu Oct 30 08:02:16 CDT 2014 ).
                              ifconfig ath0_wlan2
                              ath0_wlan2: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500
                                      ether e8:de:27:0c:54:96
                                      inet6 fe80::ecde:27ff:fe0c:5497%ath0_wlan2 prefixlen 64 scopeid 0x9
                                      inet 192.168.0.1 netmask 0xffffff00 broadcast 192.168.0.255
                                      ssid Gratis_Internet channel 6 (2437 MHz 11g ht/40+) bssid ee:de:27:0c:54:97
                                      privacy MIXED deftxkey 2 AES-CCM 2:128-bit txpower 30 scanvalid 60
                                      protmode OFF ampdulimit 64k ampdudensity 8 shortgi burst -apbridge
                              dmesg | grep ath
                              ath0: ath_edma_recv_tasklet: sc_inreset_cnt > 0; skipping
                              ath0: stuck beacon; resetting (bmiss count 0)
                              ath0: <atheros ar938x="">mem 0xfeae0000-0xfeafffff irq 16 at device 0.0 on pci3
                              ath0: RX status length: 48
                              ath0: RX buffer size: 4096
                              ath0: TX descriptor length: 128
                              ath0: TX status length: 36
                              ath0: TX buffers per descriptor: 4
                              ath0: ath_edma_setup_rxfifo: type=0, FIFO depth = 16 entries
                              ath0: ath_edma_setup_rxfifo: type=1, FIFO depth = 128 entries
                              ath0: [HT] enabling short-GI in 20MHz mode
                              ath0: [HT] 1 stream STBC transmit enabled
                              ath0: [HT] 3 RX streams; 3 TX streams
                              ath0: AR9380 mac 448.3 RF5110 phy 0.0
                              ath0: 2GHz radio: 0x0000; 5GHz radio: 0x0000</atheros>
                              Country: Sweden | ISP: Telia FiberLAN
                                rjcrowder
                                Same here… can't seem to get "N" speed on any settings...
                                  cmb
                                  @Pertan:
                                  How do you have the channel configured? Seems for at least one person I talked to, it did that until they changed the channel from auto to something specific.
                                    rjcrowder
                                    @cmb:
                                    @Pertan:
                                    Manually setting the channel gets "G" working… but haven't found anything that solves the problem of getting to "N" speed...
                                    Internal chuckle... reminds me of a quote from spaceballs, surely this must be the issue... "we are approaching ludicrous speed".
                                      Pertan
                                      @cmb:
                                      I have tried both NG and NA with channels 6 and 60. Auto does not work at all, interface is down if I choose auto.
                                      I get the same as "rjcrowder", setting channels manually gets G speeds working, but no N speeds.
                                      On a side note: Spaceballs is awesome!
                                      • w0wW Offline
                                        w0w
                                        Is there any chances to get working Ralink rt3072 on 2.2? I have USB edup ep-ms1532 with this chipset, but I have no luck with pfsense. It's shown and can be configured as interface once untill I apply settings… pfsense beginning to reboot itself with kernel panic.
                                        Other question is... DO you have any plans to get a new interface for wifi settings, where we can see N mode also and other settings related to new wifi standarts?  ???
                                          Criggie
                                          @Pertan:
                                          Time for a ME TOO post…
                                          I have a AR 9280 mini PCIe card in an APU.  Its detected at boot and shows up in the web GUI once I create the interface.
                                          [2.2-BETA][root@pfSense.criggie.org.nz]/root: dmesg | grep -i ath
                                          ath0: <atheros 9280="">at device 0.0 on pci4
                                          [ath] enabling AN_TOP2_FIXUP
                                          ath0: [HT] 2 RX streams; 2 TX streams
                                          wlan0: changing name to 'ath0_wlan0'
                                          ath0_wlan0: promiscuous mode enabled
                                          ath0_wlan0: promiscuous mode disabled
                                          ath0: stuck beacon; resetting (bmiss count 4)
                                          I set up an SSID and it doesn't appear visible to any client.  Even when I tell the client the name of the SSID, as though it was a hidden broadcast then its still not found.
                                          In GUI -> Interfaces -> "Wireless" -> "Common wireless configuration - Settings apply to all wireless networks on ath0."  I set the Standard  to 802.11g and it works fine.
                                          I can set the Standard to 802.11a and it also works, but I only have one A mode radio device.
                                          ath0: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 2290
                                                  ether 04:f0:21:10:c6:b7
                                                  inet6 fe80::1:1%ath0_wlan0 prefixlen 64 scopeid 0xa
                                                  inet 10.28.97.1 netmask 0xffffff00 broadcast 10.28.97.255
                                                  ssid APU channel 6 (2437 MHz 11g ht/40+) bssid 04:f0:21:10:c6:b7
                                                  regdomain APAC country NZ ecm authmode WPA1+WPA2/802.11i
                                                  privacy MIXED deftxkey 2 TKIP 2:128-bit TKIP 3:128-bit txpower 30
                                                  scanvalid 60 protmode OFF ampdulimit 64k ampdudensity 8 shortgi burst
                                                  dtimperiod 1 -dfs
                                          Also, I found multiple SSIDs… that's done in the Interfaces --> Assign area, once the wireless card is enabled as an interface.
                                          This is a total test box,  running 2.2-BETA (amd64) built on Mon Oct 27 15:31:41 CDT 2014
                                          FreeBSD 10.1-RC3</hostap></performnud,auto_linklocal></up,broadcast,running,simplex,multicast></hostap></performnud,auto_linklocal></up,broadcast,running,simplex,multicast></atheros>
                                            rjcrowder
                                            @Criggie:
                                            Can you double check if the interface comes up when you set it to "N" mode (on the interface status page - or just look at interfaces on the dashboard). For both Atheros devices I've tried, the interface will not start if I put it in "N" mode - hence no SSID showing…
