• GUI issues after upgrade? Clear your browser cache
    Pinned
  • HEADS UP: Default config.xml NICs changed from vr(4) to em(4)
    Pinned
  • 2.2 now Release Candidate
    Pinned Locked
    20
    18k Views
    jimpJ
    It would be best to split off issues into their own threads rather than piling on the announcement thread. Locking this for now. If you posted an issue here that hasn't already been solved, feel free to start a fresh thread here on the 2.2 board.
  • 2.2-BETA snapshots now available
    Pinned
    14
    14k Views
    jimpJ
    They are not signed on purpose. See my response on your other thread.
  • DNS Resolver
    Pinned
    186
    215k Views
    W
    @doktornotor: @dennypage: What is the advantage of putting this in the "Advanced" section instead of the "Host Overrides" section? Ever tried to put hundreds/thousands entries in there (like, ad blocking)? :D Something like 45,618? Wouldn't it be nice to have a package that put's it all together? Ad blocking, is that really politically correct?  :P [image: DNSResolver.JPG] [image: DNSResolver.JPG_thumb] [image: Alerts.JPG] [image: Alerts.JPG_thumb]
    11k Views
    jimpJ
    @athurdent: Sadly it seems that the maintainer of freeradius2 won't be able to do any more work on that package. https://forum.pfsense.org/index.php?topic=43675.msg432223#msg432223 That package does not appear to be affected by the problem for which this thread is intended. If it is broken in some other way on 2.2, post a new thread on the 2.2 board and someone may be able to look at the package if there enough detail on how to reproduce the issue.
  • Strongswan smp plugin is deprecated
    8k Views
    This has been fixed for 2.2.5 (and 2.3). We have a VICI interface now. You're welcome.  (Well, not you Ermal, you refused to fix it.)
  • MOVED: All logging has stopped
    Locked
  • MOVED: help with iOS mobile IPsec
    Locked
    41k Views
    Interestingly, this isn't a em driver bug (as upthread wanted to pursue), but rather a PCI bus issue.
  • Vnstat2 problems
    6k Views
    jimpJ
    vnstat2 should be working fine now on 2.2, reinstall it and give it another try.
  • Comments/Description field for interface
    F
    Maybe a text field called Notes or Comments would help avoid confusion in the XML backups? Would be useful though so +1.
  • RFC 2136 Dynamic DNS support for Gateway Groups
    I had done a pull request a while ago during RELENG 2.1. Only one of my clients uses it. And I haven't heard of a lot of people interested in it here on the forums either. Doesn't look like the code for RFC2136 has changed any. Will see if I can create a pull request. It was all but 10 or so lines of code.
  • Another IPSEC issue
    17
    34k Views
    IKE: AES 256 encryption with SHA1 auth, 7800 SA lifetime, IKE DH group : Group 5, MODP 1536 IPSEC:  AES 256 encryption with SHA1 auth, 3600 SA lifetime, IPsec PFS group: Group 5, MODP 1536 Line is very stable (DSL 30Mbit) and has not changed since the upgrade from pfsense 2.1.x to latest 2.2-RC. Everything remained quite stable the last 2-3 days, with only an issue this afternoon, which disappeared as usual after a complete stop + start of the ipsec service.
  • IPSEC ECP DH key groups
    dennypageD
    Many thanks Chris @cmb: hasn't been added yet. https://redmine.pfsense.org/issues/4260
    6k Views
    ClouseauC
    @phil.davis: Diagnostics->Backup/Restore, there should be a Clear Package Lock button. Press that to get rid of the "Packages are currently being reinstalled in the background". Then go looking in logs to try and see what died that prevented a clean package install and unlock. Note to other readers: Do not clear the package lock until it has been stuck "a long time" - it might just be taking a while to download, unpack and install stuff (e.g. on nanoBSD with a slow CF card, on a slow link...) Thx - worked out. This Tinc package just wont install. Is there any other ipsec/vpn which can greate full mesh vpn automatically?
    8k Views
    @Topper727: I am having same issue.. You're not having the same issue. This thread was about a long-ago fixed issue with SSH host key generation in some circumstances. There are no known issues along these lines since, and any that do exist wouldn't be relevant to this thread. Please start a new thread with specifics of what you're seeing, as it's definitely completely unrelated to this thread.
  • Add easy install of tools for Citrix XenServer
    6k Views
    Upgraded XenServer to 6.5 yesterday. PfSense doesn't route packets at more than 64kB/s … I had to roll back an Hypervisor to use it again Now it works at 3~4Gb/s . I've tried with and without all the offload mecanisms. With or without to tools (which may be not fully optimized for 6.5) Do you guys have similar issues ?
