    PfSense - OpenVPN - [Resolved] Routing issue between Lan clients and openvpn.
    10 Posts 4 Posters 3.5k Views
      TomatoBag
      Hi gents, I have a strange issue with my current setup.
      I have Pfsense configured as a VPN client connecting to an external VPS where other VPS also connect. This creates a "private" cloud where I can host a bunch of different services.
      Here is what I can figure out :
      1. The tunnel is up and any client in the 10.9.0.0/24 range can ping my Pfsense server on the OpenVPN interface (10.9.0.5).
      2. My pfsense server can ping any device in the 10.9.0.0/24 range.
      3. Any client in the 192.168.25.0/24 range are unable to access any device in the 10.9.0.0 range.
      4. Any client in the 192.168.25.0/24 range can ping the OpenVPN interface on the PFsense server 10.9.0.5 range.
      I've tried creating a static route from 10.9.0.0/24 GW 10.9.0.1 but that didn't seem to change anything.
      Here is the setup :
      firewall Rules :
        marvosa
        Post the configs from both sides.
        We'll know more once you post the configs, but assuming both sides have an "any/any" firewall rule, it sounds like a routing issue.
          TomatoBag
          Hi Marvosa,
          Here is as much info as I can provide! I appreciate any help on the matter.
          Running tcpdump on the tunnel interface on the VPS, I see zero traffic if I ping from a LAN host from my pfsense network. If I also run tcpdump on the openvpn interface on Pfsense, I see the ping echo request but no reply.
          Server Config
          #Management interface - For monitoring
          management 127.0.0.1 5556
          ;local a.b.c.d
          port 1195
          ;proto tcp
          proto udp
          topology subnet
          ;dev tap
          dev tun1
          ;dev-node MyTap
          ca hidden
          cert hidden
          key hidden  # This file should be kept secret
          dh hidden
          server 10.9.0.0 255.255.255.0
          ifconfig-pool-persist ipp-vps-tunnel.txt
          ;server-bridge 10.8.0.4 255.255.255.0 10.8.0.50 10.8.0.100
          ;server-bridge
          push "route 10.8.0.0 255.255.255.0"
          ;push "route 192.168.20.0 255.255.255.0"
          ;client-config-dir ccd
          ;route 192.168.40.128 255.255.255.248
          ;route 10.9.0.0 255.255.255.252
          ;learn-address ./script
          ;push "redirect-gateway def1 bypass-dhcp"
          #Static address for clients
          client-config-dir /etc/openvpn/static_clients/
          ;push "dhcp-option DNS 8.8.8.8"
          ;push "dhcp-option DNS 8.8.4.4"
          client-to-client
          ;duplicate-cn
          keepalive 10 120
          ;tls-auth ta.key 0 # This file is secret
          ;cipher BF-CBC        # Blowfish (default)
          ;cipher AES-128-CBC  # AES
          ;cipher DES-EDE3-CBC  # Triple-DES
          comp-lzo
          ;max-clients 100
          user nobody
          group nobody
          persist-key
          persist-tun
          status status-openvpn-vps-tunnel.log
          ;log        openvpn.log
          log-append  /etc/openvpn/logs/openvpn-vps-tunnel.log
          verb 3
          Silence repeating messages.  At most 20
          sequential messages of the same message
          category will be output to the log.
          ;mute 20
          Client config
          dev ovpnc1
          dev-type tun
          tun-ipv6
          dev-node /dev/tun1
          writepid /var/run/openvpn_client1.pid
          #user nobody
          #group nobody
          script-security 3
          daemon
          keepalive 10 60
          ping-timer-rem
          persist-tun
          persist-key
          proto udp
          cipher BF-CBC
          local hidden
          tls-client
          client
          lport 0
          management /var/etc/openvpn/client1.sock unix
          remote hidden.com 1195
          ifconfig 10.9.0.2 10.9.0.1
          route 10.9.0.0 255.255.255.0
          ca hidden
          cert hidden
          key hidden
          resolv-retry infinite
          comp-lzo
          • DerelictD Offline
            Derelict LAYER 8 Netgate
            Server config:
            I think you need to look at the local networks in the server config.  Something needs to:
            push "route 192.168.25.0 255.255.255.0"
            Chattanooga, Tennessee, USA
              TomatoBag
              If routing isn't a requirement, could I NAT from my local network (192.168.25.0) to the 10.9.0.x network using the ovpnc1 interface? I could use something like source=192.168.25.0/24  and destination=10.9.0.0/24 and NAT to ovpnc1 ?
              I mean, you are correct, the server itself has no knowledge of the 192.168.25.0 subnet(and doesn't really need to). That said, I never see any traffic leaving my pfsense network(I do see the packet on the ovpnc1 interface) and hitting the tun1 interface. It seems to vanish before leaving the pfsense server itself. If routing was the only issue, wouldn't I see packets exiting the ovpnc1 interface, hitting the tun1 VPS interface and only then failing to route back to the 192.168.25.0/24 network?
              • DerelictD Offline
                OVPNC1 interface?  Nothing you're saying is matching the screen shots you're posting.
                Why on Earth would you want to NAT between 192.168 and 10.?
                What are your firewall rules on LAN?  Let's stick to a consistent set of interfaces and routes please.
                  doktornotor Banned
                  Flush all the stuff down the drain and see this: https://doc.pfsense.org/index.php/OpenVPN_Site-to-Site_PKI_%28SSL%29
                  Also, really easiest done on 2.2 since you can set up everything via the GUI, incl. the local/remote networks, with routes/iroutes set up completely behind the scenes, no need for messing with custom options.
                    TomatoBag
                    @Derelict:
                    This is the interface created when the tunnel is up :
                    Unfortunately, the VPS server is running Centos. Anyway, I'll try working on this a bit more.
                      TomatoBag
                      Anyway, this is resolved. I needed "route 192.168.25.0 255.255.255.0 10.9.0.2 (ip address of the ovpn interface where the subnet is located".
                      What really threw me off is that tcpdump didn't show any traffic but logging into the management interface and using "log on" + "verb 7" showed packets being received and de-crypted.
                        marvosa
                        Yes, the routing issue was fairly evident once you posted the configs.
