    [Solved] Problem with SIGUSR1[soft,connection-reset] received,process restarting
    3 Posts 2 Posters 8.9k Views
    • Y Offline
      yetix
      Since the passage on my pfsense 2.2 openvpn client disconnects all the time. Here the mistake on client side:
      Mon Feb 09 10:07:36 2015 Initialization Sequence Completed
      Mon Feb 09 10:07:53 2015 Connection reset, restarting [0]
      Mon Feb 09 10:07:53 2015 SIGUSR1[soft,connection-reset] received, process restarting
      Mon Feb 09 10:07:58 2015 Attempting to establish TCP connection with [AF_INET]109.223.155.229:443 [nonblock]
      Mon Feb 09 10:07:59 2015 TCP connection established with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:07:59 2015 TCPv4_CLIENT link local (bound): [undef]
      Mon Feb 09 10:07:59 2015 TCPv4_CLIENT link remote: [AF_INET]109.223.155.229:443
      Mon Feb 09 10:08:00 2015 [VPN_Yetix_Externe] Peer Connection Initiated with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:08:02 2015 Preserving previous TUN/TAP instance: Ethernet 3
      Mon Feb 09 10:08:02 2015 Initialization Sequence Completed
      Mon Feb 09 10:08:43 2015 Connection reset, restarting [0]
      Mon Feb 09 10:08:43 2015 SIGUSR1[soft,connection-reset] received, process restarting
      Mon Feb 09 10:08:49 2015 Attempting to establish TCP connection with [AF_INET]109.223.155.229:443 [nonblock]
      Mon Feb 09 10:08:50 2015 TCP connection established with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:08:50 2015 TCPv4_CLIENT link local (bound): [undef]
      Mon Feb 09 10:08:50 2015 TCPv4_CLIENT link remote: [AF_INET]109.223.155.229:443
      Mon Feb 09 10:08:51 2015 [VPN_Yetix_Externe] Peer Connection Initiated with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:08:53 2015 Preserving previous TUN/TAP instance: Ethernet 3
      Mon Feb 09 10:08:53 2015 Initialization Sequence Completed
      Mon Feb 09 10:09:33 2015 Connection reset, restarting [0]
      Mon Feb 09 10:09:33 2015 SIGUSR1[soft,connection-reset] received, process restarting
      Mon Feb 09 10:09:38 2015 Attempting to establish TCP connection with [AF_INET]109.223.155.229:443 [nonblock]
      Mon Feb 09 10:09:39 2015 TCP connection established with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:09:39 2015 TCPv4_CLIENT link local (bound): [undef]
      Mon Feb 09 10:09:39 2015 TCPv4_CLIENT link remote: [AF_INET]109.223.155.229:443
      Mon Feb 09 10:09:41 2015 [VPN_Yetix_Externe] Peer Connection Initiated with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:09:43 2015 Preserving previous TUN/TAP instance: Ethernet 3
      Mon Feb 09 10:09:43 2015 Initialization Sequence Completed
      Mon Feb 09 10:10:23 2015 Connection reset, restarting [0]
      Mon Feb 09 10:10:23 2015 SIGUSR1[soft,connection-reset] received, process restarting
      Mon Feb 09 10:10:28 2015 Attempting to establish TCP connection with [AF_INET]109.223.155.229:443 [nonblock]
      Mon Feb 09 10:10:29 2015 TCP connection established with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:10:29 2015 TCPv4_CLIENT link local (bound): [undef]
      Mon Feb 09 10:10:29 2015 TCPv4_CLIENT link remote: [AF_INET]109.223.155.229:443
      Mon Feb 09 10:10:30 2015 [VPN_Yetix_Externe] Peer Connection Initiated with [AF_INET]109.223.155.229:443
      Mon Feb 09 10:10:32 2015 Preserving previous TUN/TAP instance: Ethernet 3
      Mon Feb 09 10:10:32 2015 Initialization Sequence Completed
      I had no problem before switching on 2.2.
      • Y Offline
        yetix
        The problem came from the modem. I changed it and everything works fine.
          mashiahd
          Can u please specify the changes you made?
          i have the same problem.
