    Routing problem on site-to-site connection
    9 Posts 3 Posters 3.2k Views
      dman
      I have two sites connected with OpeVPN below, Site A and Site B can successfully access each other internal network. Site B directly connects to Site C, and can access Site C also. Site A need to access Site C, but cannot. It seems the IP cannot be translated successfully, please see the ping results.  Do you have any ideas what's wrong? Thanks.
      Site A (192.168.0.0/24) –--- <openvpn site="" to="">------ Site B (192.168.1.0/24) ----<192.168.51.2>--<192.168.51.1>-- Site C ( 10.0.0.0/8)
      Site A:
      (Server.Advanced)
      route 10.0.0.0 255.0.0.0;
      route 192.168.0.0 255.255.248.0;
      push "route 192.168.0.0 255.255.255.0";
      (Client Specific Overrides.Advanced)
      iroute 192.168.1.0 255.255.255.0;
      iroute 10.0.0.0 255.0.0.0;
      Ping results captured on Site B port connected to Site C:
      From Site A:
      3 0.617589 192.168.0.129 10.1.8.5 ICMP 74 Echo (ping) request  id=0x0001, seq=1057/8452, ttl=126 (no response found!)
      From Site B:
      1 0.000000 192.168.51.2 10.1.8.5 ICMP 74 Echo (ping) request  id=0xe9d2, seq=24864/8289, ttl=128 (reply in 2)
      2 0.058736 10.1.8.5 192.168.51.2 ICMP 74 Echo (ping) reply    id=0xe9d2, seq=24864/8289, ttl=116 (request in 1)</openvpn>
        marvosa
        Please clarify your setup.  Your network map suggests your sites are daisy chained and Site B is the router between A and C.  Or is Site A the hub and has two separate tunnels… one to A and one to C?
        Post your server and clients config files from each site.
        You can actually do this without iroutes btw, but having not seen your configs yet there most likely are two different scenarios at play:
        • If your sites are daisy chained like your network map suggests (A<->B<->C) and you're using iroutes then your server config should be on Site B (not A) and you will need return routes on A for C and on C for A.
        • If Site A is your HUB with two separate tunnels to B and C, then most likely you have the iroute to 10.0.0.0/8 located on the wrong tunnel.
          dman
          Site A [WAN] –-<openvpn site="" to="">--- [WAN] Site B [OPT1:192.168.51.2] –-[GW192.168.51.1]–-<routers>--- Site C
                [LAN]                                                          [LAN]        [LAN]
          (192.168.0.0/24)                                        (192.168.1.0/24)        (10.0.0.0/8)
          Site A is openvpn server, connected by other client sites.
          Site B is client site, and it has a static IP to connect to Site C at OPT1.
          Site B: Static Route
                    Destination Gateway Flags Refs Use Mtu Netif
                    10.0.0.0/8 192.168.51.1 UGS 0 682310 1500 em1
          Site C is not a openvpn client site, it connects to Site B through a lan.
          Site A :
          Server1.conf:
          dev ovpns1
          verb 1
          dev-type tun
          dev-node /dev/tun1
          writepid /var/run/openvpn_server1.pid
          script-security 3
          daemon
          keepalive 10 60
          ping-timer-rem
          persist-tun
          persist-key
          proto udp
          cipher AES-128-CBC
          auth SHA1
          local 23.255.13.38
          tls-server
          server 192.168.100.0 255.255.255.0
          client-config-dir /var/etc/openvpn-csc
          tls-verify "/usr/local/sbin/ovpn_auth_verify tls 'server' 1"
          lport 1194
          management /var/etc/openvpn/server1.sock unix
          max-clients 10
          client-to-client
          ca /var/etc/openvpn/server1.ca
          cert /var/etc/openvpn/server1.cert
          key /var/etc/openvpn/server1.key
          dh /etc/dh-parameters.1024
          tls-auth /var/etc/openvpn/server1.tls-auth 0
          comp-lzo adaptive
          persist-remote-ip
          float
          push "route 192.168.0.0 255.255.248.0"
          /var/etc/openvpn-csc/client1
          Site B:
          dev-type tun
          tun-ipv6
          dev-node /dev/tun1
          writepid /var/run/openvpn_client1.pid
          #user nobody
          #group nobody
          script-security 3
          daemon
          keepalive 10 60
          ping-timer-rem
          persist-tun
          persist-key
          proto udp
          cipher AES-128-CBC
          local 118.120.180.38
          tls-client
          client
          lport 0
          management /var/etc/openvpn/client1.sock unix
          remote 23.255.13.38 1194
          ca /var/etc/openvpn/client1.ca
          cert /var/etc/openvpn/client1.cert
          key /var/etc/openvpn/client1.key
          tls-auth /var/etc/openvpn/client1.tls-auth 1
          comp-lzo</routers></openvpn>
            phil.davis
            That looks a bit odd, teling each end that 192.168.0.0/21 is reachable at the other end of the OpenVPN link. But actually pfSense routing is smart enough to to also know about and deliver directly to the local LAN at siteA and siteB, not ping-pong traffic between the 2.
            I suspect that the router at site C does not have a route back to site A LAN 192.168.0.0/24, or site C router has a firewall that is blocking that, or site B OPT1 has firewall rule/s that do not allow that…
              dman
              Thanks for all, I found the solution from below
              https://doc.pfsense.org/index.php/Routing_internet_traffic_through_a_site-to-site_OpenVPN-connection_in_PfSense_2.1
              I added a rule to translate IP (192.168.0.0/24) to 192.168.51.2, it's working well now.
              [NAT OUTBOUND Rule]
              Interface: OPT1
              Protocol: any
              Source: 192.168.0.0/24
              Destination: any
              Translation: interface address
                phil.davis
                That shows that there is a device somewhere that does not have a route back to 192.168.0.0/24 or is blocking that traffic. Hiding it behind 192.168.51.2 is one way to work around that.
                  marvosa
                  It's already been said, but yes, the edge device @ site C needs a route back to 192.168.0.0/21 thru 192.168.51.2.
                  A few things:
                  • Your iroutes are redundant as you are already routing (and pushing) the appropriate routes thru the tunnel.
                  • Remove "route 192.168.0.0 255.255.248.0" from Site A's config.  This directive is for the remote subnet, not local
                  • Your NAT works, but now removes your ability to monitor, isolate and firewall connections coming from Site A on Site C.  This may or may not be an issue depending on your priorities and security concerns
                    dman
                    The edge device is not my own equipment at Site C, so I can't change anything on it.
                    In my 1st post, you can see the source IP of ICMP has been traslated to 192.168.51.2 from Site B 192.168.1.0/24 on OPT1, but through the vpn it still kept the same to pass to Site C, therefore it can't return back from Site C. Is it a bug or nromal ?
                      phil.davis
                      It is normal - whatever address you NAT the site A subnet to, that needs to be an address that site C knows how to route back to. So you probably might want it to be some address in site B, which site C already knows how to reach.
