    WPAD questions and problems
    31 Posts 4 Posters 6.4k Views
      MrGlasspoole
      I have the problem that i can't get autodiscover to work.
      But now i wonder if it makes sense to use wpad cause you still have to configure
      the browser or devices cause autodiscover is not on by default.
      I think it does not make a difference if i go to the browser settings to select
      autodiscover or to put a ip and port in there?
      Then i was reading you can port forward any traffic directed at port 80 to the proxy (Squid).
      So why should i use wpad (which does not work) - i'm missing something?
      • KOMK Offline
        KOM
        But now i wonder if it makes sense to use wpad cause you still have to configure the browser or devices cause autodiscover is not on by default.
        All major browsers have shipped with auto-discovery enabled for several years now.  Mobile devices may vary, but the trend is to enable auto-discovery.
        I think it does not make a difference if i go to the browser settings to select autodiscover or to put a ip and port in there?
        Sure, if you only have a tiny number of devices to worry about.  Get back to me on your method when you have a LAN with a couple of hundred/thousand clients.
        Then i was reading you can port forward any traffic directed at port 80 to the proxy (Squid). So why should i use wpad (which does not work) - i'm missing something?
        What you're describing is called Transparent Mode.  It's great until you need to intercept HTTPS traffic, which involves installing a trusted certificate on every client and then doing what's essentially a Man in the Middle attack.
        Trust me, WPAD is the way to go.  How is it not working for you?
          MrGlasspoole
          @KOM:
          All tutorials say the opposite.
          @KOM:
          This tut about wpad still says NAT redirect at the bottom: http://irj972.co.uk/articles/pfSense-WPAD-PAC-configuration
          I did setup the vHosts package with:
          wpad.mydomain.net
          I have:
          wpad.pfsense.mydomain.net
          wpad.mydomain.net
          in the DNS resolver.
          In the DHCP server LAN i have:
          252 txt http://wpad.mydomain.net/wpad.dat
          252 txt http://wpad.mydomain.net/proxy.pac
          I can download the files if i point the browser to:
          But Firefox and IE do not use the file with auto-discovery.
          • KOMK Offline
            KOM
            I'm not really looking to argue.  I'm trying to help you with knowledge that I have which I know works for a fact and is recommended by every other volunteer here.
            All of the major browsers most certainly do work with WPAD.  I have seen a few instances where a user's browser had to be manually set from auto-detect to specified server and port, but this is rare in my experience.  I don't know why you went wandering off with some random tutorial when pfSense already has a full document on how to get it working which I know works because I used it myself.
            WPAD Autoconfigure for Squid
            It is idiotic to have a proxy server online but leave ports 80 and 443 open.  If users can go around the proxy then what is the point of having it in the first place?
              MrGlasspoole
              @KOM:
              The pfSense docu was the first thing i was looking at.
              But it was not working and for a newbie allot of the docu is not clear/specific enough.
              I'm not the only one who has problems get it running and after searching the forum i found
              out that it is recommended to use a second webserver and lighttpd because if not you have
              to use a certificate.
              The tutorial i linked is just something i found when i was searching the web to find out
              why i can't get it running.
              As i wrote i can download the file with
              but auto-discovery is not using it.
              Why is that?
              How can i figure out what the problem is?
              How do i make sure clients do not bypass the proxy?
              • KOMK Offline
                KOM
                Create a Ports Alias (Firewall - Aliases - Ports) called WebPorts or WWW_Ports and set it to 80,443.  Create a firewall rule on LAN that blocks Source Any, Destination Any, Destination port range (Other) and then put your alias in the red box beside the (Other) combobox.  See attached.
                but auto-discovery is not using it.  Why is that?  How can i figure out what the problem is?
                First block off the ports as shown above.  Then manually set your browser to the proxy to ensure the proxy is working by going to a few sites.  Can you show me your wpad.dat file?  Loading the file and processing the file are two different things.  If you have a bug in your code, then it won't work.
                pf1.png_thumb
                pf2.png_thumb
                  MrGlasspoole
                  Thanks KOM
                  The proxy is working if i use
                  in Firefox "Automatic proxy configuration URL"
                  and test it with http://www.lagado.com/proxy-test
                  wpad.dat:
                  function FindProxyForURL(url,host)
                  return "PROXY 192.168.0.1:3128";
                  • KOMK Offline
                    KOM
                    The auto-discovery should work if you have a DNS entry for the host WPAD on your local domain, or a DHCP 252 entry in DHCP.  On your DNS server, create a WPAD host entry and point it to your pfSense LAN IP address.  Then every browser set to automatic discovery should be able to find it since they do a DNS lookup on wpad.YourDomain.foo and then load the wpad.dat file via HTTP from that host.
                      MrGlasspoole
                      As you can see in my second post the DNS and DHCP entries are already there.
                      I added now the Firewall rules - if i do that my Internet stops working… (sure Firefox is set to the proxy).
                      • KOMK Offline
                        KOM
                        If you do an nslookup on WPAD, does it resolve to the proxy LAN address?
                          MrGlasspoole
                          nslookup wpad.mydomain.net:
                          Server:  pfsense.mydomain.net
                          Address:  192.168.0.1
                          nslookup wpad:
                          nslookup wpad.pfsense.mydomain.net:
                          But if something would be wrong here why is the proxy working as long as i not block http in the firewall?
                          • KOMK Offline
                            KOM
                            Because something isn't working.  If the browser is set to auto-detect, then it will try to go straight out the gateway.  If it can't, then it tries to detect the proxy using WPAD.  When you unblock LAN, it can go straight out.  When you block LAN, it can't go out so it tries to detect the proxy and use it.  This is where your problem is.  Either the browser isn't detecting the proxy at all, or it is and the proxy isn't working.  Is your WebGUI using HTTP or HTTPS?  If I remember, you can't use pfSense under HTTPS to host the WPAD file.
                            • Q Offline
                              q54e3w
                              you can't use the default lightppd intstance to serve the WPAD file, its tied up to port 80 for serving webconfigurator stuff. You need the second lightppd instance. If you webconfigurator is running on port 80 and not a custom port you won't be able to bind it so you need a custom port for the webconfiguator lightppd instance in order for the second lightppd to server the file on port 80.
                              whats the output of "ps aux | grep "light"?
                              • KOMK Offline
                                KOM
                                I'm fairly sure that you can, considering that's exactly how I'm doing it and that's how it's documented  ;D
                                From WPAD Autoconfigure for Squid
                                "Now upload that file to pfSense or another locally accessible web server with scp, or create it using the built-in file editor. The file must go in /usr/local/www/…"
                                Port 80 isn't "tied up" with WebGUI.  It will serve the GUI as the default page, but if you give it an explicit URL then it will serve anything, including wpad.dat.
                                • Q Offline
                                  q54e3w
                                  yes, you are right, sorry. I dont allow HTTP to my pfsense box. I'll keep out of it, you carry on….I suspect you are nearly there :)
                                  • KOMK Offline
                                    KOM
                                    Hey, no problem.  I've never let a lack of knowledge or incorrect information stop me from trying to help someone.  Even when I am wrong (and I've been wrong in these forums many times), I learn something.  It bruises the ego a bit, but you become better for it.  Thanks for contributing.  A community is only as strong as its members.
                                      MrGlasspoole
                                      Step by step…
                                      Forget the wpad for a while.
                                      What i was saying is:
                                      If i enable the firewall rule to block http and use 192.168.0.1:3128 (not wpad) in the browser then the internet stops working.
                                      If i disable the rule then it works again and uses the proxy.
                                      • KOMK Offline
                                        KOM
                                        If you block 80/443 and manually set your browser to use the proxy at the specified address:port and nothing works and you're positive you didn't make a typo, your Squid install is broken.  Look in your System log, as well as /var/squid/logs/access.log and cache.log.
                                        Can you please remind me as to what version of pfSense and Squid you are using?
                                          MrGlasspoole
                                          Ok, found out something.
                                          The whole time i was just using google for testing.
                                          But this time i used another site and it's just HTTPS (google) that is not working if i enable the firewall rule.
                                          HTTP works with pointing the browser to address:port.
                                          BUT if i set the browser to auto-discovery then also HTTP is not working.
                                          pfSense 2.2
                                          squid3 3.4.10_2 pkg 0.2.6
                                          • KOMK Offline
                                            KOM
                                            Do you run IPv6?
