    WPAD questions and problems
    31 Posts 4 Posters 5.1k Views
      MrGlasspoole
      IPv6 is none in LAN and WAN.
      And the output of ps aux | grep "light" is:
      root    17216   0.0  0.3  50796   5888  -  S    12Feb15     0:25.97 /usr/local/sbin/lighttpd -f /var/etc/
      root    89081   0.0  0.2  40392   4416  -  S    12Feb15     0:21.07 /usr/local/sbin/lighttpd -f /var/etc/
      root    94646   0.0  1.5 232612  31596  -  I    10:10AM     0:00.22 php-fpm: pool lighty (php-fpm)
      root    49032   0.0  0.1  18884   2356  0  S+   10:13AM     0:00.00 grep light
      As i said i use the vHost package to host the wpad that i can run the WebGUI over HTTPS
      but don't need a certificate for the wpad.
      Tomorrow when i have time i will make some tests step by step with checking the logs after every step.
      But today i have a date and no time ;-)
      • KOMK Online
        KOM
        Good luck on your date  8)  :-*
          MrGlasspoole
          Ok time to get it working.
          Blocking https and using the proxy does not work.
          This is what happens if the browser is set to the proxy and http and https are blocked in Firewall > Rules > LAN:
          http = YES working
          https = NO does not work
          • KOMK Online
            KOM
            You have it set to standard mode (not transparent)?  You do NOT have it set to intercept SSL?  You have a wpad.dat file accessible via an HTTP server that can be found by a DNS lookup of wpad.yourdomain?
              MrGlasspoole
              I'm just looking to get https working if i block it in the firewall without looking a the wpad (proxy ip/port manually set in the browser).
              Transparent HTTP proxy = unchecked
              HTTPS/SSL interception = unchecked
              See attachment…
              ![Proxy server- General settings.png](/public/imported_attachments/1/Proxy server- General settings.png)
              ![Proxy server- General settings.png_thumb](/public/imported_attachments/1/Proxy server- General settings.png_thumb)
              ![Firewall- Rules.png](/public/imported_attachments/1/Firewall- Rules.png)
              ![Firewall- Rules.png_thumb](/public/imported_attachments/1/Firewall- Rules.png_thumb)
              • KOMK Online
                KOM
                Your settings look good but I notice that squidGuard is in the mix.  OK, sometimes these weird issues with squid can be fixed with a reboot, so I would do that first.  Next, I would look at /var/log/squid/access.log and see what's happening.  Also look at cache.log for any obvious errors.  Lastly, I would get rid of squidGuard to make sure it isn't interfering. Mare sure when you're testing to do a force refresh with ctrl-F5 or whatever your browser uses.
                  MrGlasspoole
                  Ok I first deleted the logs to get fresh ones and restarted.
                  After blocking 80/443 and accessing one http and one https site i get this:
                  /var/squid/logs/access.log
                  1430081870.198    476 192.168.0.70 TCP_MISS/200 18530 GET http://winfuture.de/ - HIER_DIRECT/212.53.132.4 text/html
                  1430081870.327     72 192.168.0.70 TCP_MISS/200 8032 GET http://i.wfcdn.de/teaser/328/6945.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.336     73 192.168.0.70 TCP_MISS/200 5999 GET http://i.wfcdn.de/teaser/128/15219.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.341     78 192.168.0.70 TCP_MISS/200 6489 GET http://i.wfcdn.de/teaser/128/65.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.341     76 192.168.0.70 TCP_MISS/200 5749 GET http://i.wfcdn.de/teaser/128/415.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.344     64 192.168.0.70 TCP_MISS/200 2756 GET http://i.wfcdn.de/videos/128/14406.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.344     88 192.168.0.70 TCP_MISS/200 5272 GET http://i.wfcdn.de/teaser/128/12165.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.347     56 192.168.0.70 TCP_MISS/200 6398 GET http://i.wfcdn.de/teaser/210/15205.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.351     72 192.168.0.70 TCP_MISS/200 2607 GET http://i.wfcdn.de/videos/128/14411.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.351     58 192.168.0.70 TCP_MISS/200 8325 GET http://i.wfcdn.de/teaser/210/14525.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.571    310 192.168.0.70 TCP_MISS/200 2831 GET http://i.wfcdn.de/teaser/128/454.1.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.573    315 192.168.0.70 TCP_MISS/200 3785 GET http://i.wfcdn.de/teaser/128/14997.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081870.577     61 192.168.0.70 TCP_MISS/200 536 GET http://winfuture.de/ajax/now? - HIER_DIRECT/212.53.132.4 application/json
                  1430081873.324   3029 192.168.0.70 TCP_MISS/200 8941 GET http://i.wfcdn.de/teaser/210/15209.jpg - HIER_DIRECT/162.159.246.58 image/jpeg
                  1430081873.355   3057 192.168.0.70 TCP_MISS/200 14746 GET http://i.wfcdn.de/teaser/210/15196.png - HIER_DIRECT/162.159.246.58 image/png
                  1430081873.417   3122 192.168.0.70 TCP_MISS/200 23704 GET http://videos.winfuture.de/14408.jpg - HIER_DIRECT/212.53.132.3 image/jpeg
                  1430081883.494     51 192.168.0.70 TCP_MISS/200 575 GET http://winfuture.de/ajax/ca/1/6801 - HIER_DIRECT/212.53.132.4 text/html
                  1430081893.581     69 192.168.0.70 TCP_MISS/200 575 GET http://winfuture.de/ajax/ca/2/5891 - HIER_DIRECT/212.53.132.4 text/html
                  1430081894.166     25 192.168.0.70 TCP_MISS/200 1460 GET http://i.wfcdn.de/5/favicon.ico - HIER_DIRECT/162.159.246.58 image/x-icon
                  1430081903.665     60 192.168.0.70 TCP_MISS/200 575 GET http://winfuture.de/ajax/ca/3/2270 - HIER_DIRECT/212.53.132.4 text/html
                  1430081913.751     68 192.168.0.70 TCP_MISS/200 575 GET http://winfuture.de/ajax/ca/4/0245 - HIER_DIRECT/212.53.132.4 text/html
                  1430081923.810     45 192.168.0.70 TCP_MISS/200 575 GET http://winfuture.de/ajax/ca/5/2352 - HIER_DIRECT/212.53.132.4 text/html
                  1430081933.875     53 192.168.0.70 TCP_MISS/200 575 GET http://winfuture.de/ajax/ca/6/8629 - HIER_DIRECT/212.53.132.4 text/html
                  1430081943.944     57 192.168.0.70 TCP_MISS/200 575 GET http://winfuture.de/ajax/ca/7/9718 - HIER_DIRECT/212.53.132.4 text/html
                  /var/squid/logs/cache.log
                  2015/04/26 22:57:14 kid1| Starting Squid Cache version 3.4.10 for amd64-portbld-freebsd10.1...
                  2015-04-26 22:57:14 [26308] /usr/local/bin/squidGuard: can't write to logfile /var/log/squidGuard/squidGuard.log
                  2015-04-26 22:57:14 [26308] New setting: logdir: /var/squidGuard/log
                  2015-04-26 22:57:14 [26308] New setting: dbhome: /var/db/squidGuard
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_ads/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_ads/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_blasphemy/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_blasphemy/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_chanology/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_chanology/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_cp/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_cp/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_dating/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_dating/domains.db
                  2015-04-26 22:57:14 [24879] /usr/local/bin/squidGuard: can't write to logfile /var/log/squidGuard/squidGuard.log
                  2015-04-26 22:57:14 [24879] New setting: logdir: /var/squidGuard/log
                  2015-04-26 22:57:14 [24879] New setting: dbhome: /var/db/squidGuard
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_ads/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_ads/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_blasphemy/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_blasphemy/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_chanology/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_chanology/domains.db
                  2015-04-26 22:57:14 [26572] /usr/local/bin/squidGuard: can't write to logfile /var/log/squidGuard/squidGuard.log
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_cp/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_cp/domains.db
                  2015-04-26 22:57:14 [26572] New setting: logdir: /var/squidGuard/log
                  2015-04-26 22:57:14 [26572] New setting: dbhome: /var/db/squidGuard
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_ads/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_ads/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_dating/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_dating/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_dyn/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_dyn/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_file/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_file/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_freeWeb/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_freeWeb/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_gambling/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_gambling/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_gaming/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_gaming/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_image/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_image/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_malicious/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_malicious/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_pharmaRX/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_pharmaRX/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_blasphemy/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_blasphemy/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_chanology/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_chanology/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_cp/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_cp/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_dating/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_dating/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_dyn/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_dyn/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_file/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_file/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_dyn/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_dyn/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_file/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_file/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_freeWeb/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_freeWeb/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_gambling/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_gambling/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_gaming/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_gaming/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_piracy/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_piracy/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_porn/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_porn/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_prime/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_prime/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_proxies/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_proxies/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_freeWeb/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_freeWeb/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_gambling/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_gambling/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_gaming/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_gaming/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_image/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_image/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_malicious/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_malicious/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_smedia/domains
                  2015-04-26 22:57:14 [24879] loading dbfile /var/db/squidGuard/blk_smedia/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_pharmaRX/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_pharmaRX/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_piracy/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_piracy/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_porn/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_porn/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_prime/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_prime/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_proxies/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_proxies/domains.db
                  2015-04-26 22:57:14 [26572] init domainlist /var/db/squidGuard/blk_smedia/domains
                  2015-04-26 22:57:14 [26572] loading dbfile /var/db/squidGuard/blk_smedia/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_image/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_image/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_malicious/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_malicious/domains.db
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_pharmaRX/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_pharmaRX/domains.db
                  2015-04-26 22:57:14 [24879] init domainlist /var/db/squidGuard/blk_tlds_new/domains
                  2015-04-26 22:57:14 [24666] /usr/local/bin/squidGuard: can't write to logfile /var/log/squidGuard/squidGuard.log
                  2015-04-26 22:57:14 [27008] /usr/local/bin/squidGuard: can't write to logfile /var/log/squidGuard/squidGuard.log
                  2015-04-26 22:57:14 [26308] init domainlist /var/db/squidGuard/blk_piracy/domains
                  2015-04-26 22:57:14 [26308] loading dbfile /var/db/squidGuard/blk_piracy/domains.db
                  2015-04-26 22:57:14 [24666] New setting: logdir: /var/squidGuard/log
                  2015-04-26 22:57:14 [24666] New setting: dbhome: /var/db/squidGuard
                  /var/squidGuard/log/squidGuard.log
                  2015-04-26 22:57:14 [24666] squidGuard 1.4 started (1430081834.410)
                  2015-04-26 22:57:14 [24666] squidGuard ready for requests (1430081834.439)
                  2015-04-26 22:57:14 [24879] squidGuard 1.4 started (1430081834.368)
                  2015-04-26 22:57:14 [24879] squidGuard ready for requests (1430081834.441)
                  2015-04-26 22:57:14 [26572] squidGuard 1.4 started (1430081834.370)
                  2015-04-26 22:57:14 [26572] squidGuard ready for requests (1430081834.444)
                  2015-04-26 22:57:14 [26308] squidGuard 1.4 started (1430081834.361)
                  2015-04-26 22:57:14 [26308] squidGuard ready for requests (1430081834.451)
                  2015-04-26 22:57:14 [25549] squidGuard 1.4 started (1430081834.462)
                  2015-04-26 22:57:14 [25549] squidGuard ready for requests (1430081834.473)
                  2015-04-26 22:57:14 [27008] squidGuard 1.4 started (1430081834.415)
                  2015-04-26 22:57:14 [27008] squidGuard ready for requests (1430081834.482)
                  2015-04-26 22:57:14 [28268] squidGuard 1.4 started (1430081834.462)
                  2015-04-26 22:57:14 [28268] squidGuard ready for requests (1430081834.489)
                  2015-04-26 22:57:14 [24592] squidGuard 1.4 started (1430081834.450)
                  2015-04-26 22:57:14 [24592] squidGuard ready for requests (1430081834.491)
                  2015-04-26 22:57:15 [24592] squidGuard stopped (1430081835.986)
                  2015-04-26 22:57:15 [25549] squidGuard stopped (1430081835.986)
                  2015-04-26 22:57:15 [26308] squidGuard stopped (1430081835.986)
                  2015-04-26 22:57:15 [28268] squidGuard stopped (1430081835.987)
                  2015-04-26 22:57:15 [24666] squidGuard stopped (1430081835.988)
                  2015-04-26 22:57:15 [24879] squidGuard stopped (1430081835.988)
                  2015-04-26 22:57:15 [26572] squidGuard stopped (1430081835.988)
                  2015-04-26 22:57:15 [27008] squidGuard stopped (1430081835.988)
                  2015-04-26 22:57:16 [60436] squidGuard 1.4 started (1430081836.432)
                  2015-04-26 22:57:16 [60436] squidGuard ready for requests (1430081836.447)
                  2015-04-26 22:57:16 [60750] squidGuard 1.4 started (1430081836.466)
                  2015-04-26 22:57:16 [60750] squidGuard ready for requests (1430081836.480)
                  2015-04-26 22:57:16 [62581] squidGuard 1.4 started (1430081836.476)
                  2015-04-26 22:57:16 [62581] squidGuard ready for requests (1430081836.487)
                  2015-04-26 22:57:16 [60430] squidGuard 1.4 started (1430081836.466)
                  2015-04-26 22:57:16 [60430] squidGuard ready for requests (1430081836.497)
                  2015-04-26 22:57:16 [61883] squidGuard 1.4 started (1430081836.483)
                  2015-04-26 22:57:16 [61883] squidGuard ready for requests (1430081836.498)
                  2015-04-26 22:57:16 [63879] squidGuard 1.4 started (1430081836.501)
                  2015-04-26 22:57:16 [63879] squidGuard ready for requests (1430081836.517)
                  2015-04-26 22:57:16 [61344] squidGuard 1.4 started (1430081836.502)
                  2015-04-26 22:57:16 [61344] squidGuard ready for requests (1430081836.519)
                  2015-04-26 22:57:16 [63184] squidGuard 1.4 started (1430081836.507)
                  2015-04-26 22:57:16 [63184] squidGuard ready for requests (1430081836.521)
                  I did shorten the cache.log because:
                  is repeated multiple times?
                  And no https shows up in the log.
                  Also find out that if i block port 80 that i can't access my wpad.dat
                  http://wpad.mydomain.net/wpad.dat
                    chris4916
                    @MrGlasspoole:
                    Pretty obvious  ;)
                    You must have some granularity and control in the way you allow or block prtocols, especially if you have services running at FW level (like HTTP server)
                    This can be easily achieved, e.g. by adding rule before the one denying access so that access to FW on port 80 (in order to access wpad.dat) is authorized.
                    Jah Olela Wembo: Les mots se muent en maux quand ils indisposent, agressent ou blessent.
                    • KOMK Online
                      KOM
                      Why is this happening?  Are you out of disk space?
                      Start small and build up.  Get WPAD and just Squid working, then move on to squidGuard.
                        MrGlasspoole
                        @chris4916:
                        Pretty obvious  ;)
                        Not to me cause i thought the FW just blocks stuff going out to the Internet (WAN)
                        @chris4916:
                        This can be easily achieve, e.g. by adding rule before the one denying access so that access to FW on port 80 (in order to access wpad.dat) is authorized.
                        Can you explain what to do?
                        You can see my settings in the attachment above.
                        If my thoughts are right to i need to put port 80 to the Anti-Lockout Rule?
                        @KOM:
                        No "ufs: 23% of 18G"
                        It already was pain to get it running: https://forum.pfsense.org/index.php?topic=87591.0
                        Is there a way to temporarily disable squidGuard?
                        • KOMK Online
                          KOM
                          Uncheck the Enable box?
