    CARP + OpenVPN bridged to LAN = System freeze after a couple of minutes
    2 Posts 2 Posters 760 Views
      Mat187
      I'm using the latest version of pfSense and running in to a problem with an OpenVPN bridged interface.
      Setup:
      • Two hardware boxes
      • WAN, LAN, DMZ interface with CARP
      After adding the bridge (VPN to LAN) to the OpenVPN server, it takes about 3-4 minutes and then the master freezes completly (only reset possible), the backupsystem takes over and after some minutes it happens there too. In the logs there is nothing, because of the freeze :-( After deleting the bridge, everthing works fine again.
      Thanks in advance for any help or information about that issue
      Matt
        sachafournier
        Hi Matt,
        I have the same configuration
        … and the same problem. Did you find any workaroud or clues ?
        Sacha
