    Wireless ap problem with Asus RT-ac66u
    26 Posts 5 Posters 6.8k Views
      bkandor
      Yes, I understand that, both these routers have AP modes,  both say to use the wan port to connect to lan when in AP mode.  However, if I do that, I'll speed test with a 300ms ping, dl .5 mb/s and upload .8mb/s.  If I move the cable to a lan port my speedtest is 12ms ping, 28mb/s dl and 2.8mb/s upload (same speed as wired, tested on ipad).
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        Sounds like a GREAT question for the Asus guys.
        Chattanooga, Tennessee, USA
          bkandor
          True,  but either way I don't think it explains why both routers seize up with 2.2.2 and are working fine with 2.2.1 - with no other changes being made.
          • DerelictD Offline
            Time for some mirror ports and wireshark.
              hda
              Have you rebooted the Zyxel-1920 yet after pfSense 2.2.2 upgrade ?
                bkandor
                No,  I never did.  I'm at 2.2.1 now,  but I can upgrade again and try rebooting the switch.  I'm ok testing now that I now I can get it fixed easily.
                Thanks,
