    Cannot connect to wireless printer from clients on same wlan
    4 Posts 3 Posters 1.2k Views
      scopa
      printer is connected to wireless network w/ static ip
      172.20.4.120
      255.255.255.224
      172.20.4.100
      the wireless firewall rule is wide open - Source/Port/Dest/Port/Gateway - all set to Any
      wireless client on same WLAN
      172.20.4.115
      255.255.255.224
      172.20.4.100
      I cannot connect or even ping to this printer - Any ideas? How can I get screenshots of my WLAN interface and DHCP server settings (Client gets IP from DHCP) put on this topic? Using linux and screen shots take multiple monitors and dont know how to edit them.
      Thank you,
        Guest
        You have to set your wireless configuration to allow IBSS.
        Check this box:  –-Allow intra-BSS communication---
          scopa
          that was it - thanks alot
            "Using linux and screen shots take multiple monitors and dont know how to edit them."
            What?? Are you using a desktop, console - what flavor of linux what desktop? Gnome, KDE, ?
            SG-4860 25.11 | Lab VMs 2.8.1, 25.11
