    UPnP will not start on 2.2.3 Dev. Anyone know what these errors mean?
    Scheduled Pinned Locked Moved 2.2.3 Snapshots Problems and Feedback - ARCHIVED
    4 Posts 3 Posters 2.7k Views
    • Z
      zerodamage
      These are the errors being generated. Anyone seen this before and know how to fix it?
      http://i.imgur.com/293SZFC.png
      Also, I use UPnP for my PS4, Xbox1, and Wii-U. Nothing else uses it so nothing is critical on this but would like to figure out what these errors mean.
      Here are my settings: http://i.imgur.com/QKYOCOi.png
      • H
        heper
        better move this to the snapshot subsection
        • C
          cmb
          Works here, with the exact same config you showed, and different ones.
          The telling log there is "address already in use" - something is bound to UDP port 1900 already, that's why it's failing to start. You have OpenVPN or something else configured on port 1900? Check the output of "sockstat -4" for 1900.
          • Z
            zerodamage
            @cmb:
            Yeah, it's me. I had a feeling it was Java or Mombo. I am running those to run the Ubiquiti Unifi controller software on my home router. I need to figure out how to change the port on one of the two and restart.  Thanks for the help. This was useful!
