Problems using TuneIn.com with transparent squid + squidclamav
I'm having problems using the website TuneIn.com
Whenever I try to open a radio station stream it does not work. TuneIn just passes the connection to the right online radio station.
For instance DI Progressive goes to a stream from DI Progressive. Radio 538 goes to stream from their site.I'm getting these messages in the logs as shown below:
I have tried the following:
- Disable transparent proxy –> problem "solved"
- Disable AV scanning --> problem "solved"
- Put the machine on the "Bypass Proxy for These Source IPs" list --> problem "solved"
These are all just workarounds in my opinion.
Disabling transparent proxy is no option for me. Disabling AV protection is not something I want either.
Put the machine on the list is not something I want as well. All proxy will be disabled this way.I have tried to edit the c-icap.magic file and remove all STREAM stuff. But without luck. Doesn't solve anything for me.
Does anyone have additional tips for me? -
- Put the machine on the "Bypass Proxy for These Source IPs" list –> problem "solved"
This would be an acceptable solution for me.
Why not? You're not going to be caching a live stream, and I don't know if the AV crap (I really think AV on the firewall is a terrible idea in the first place) adds any value in this context.
If I put the machine on the bypass list, it bypasses the whole proxy server.
At the moment I'm still fiddling with this but later on I would like to use SquidGuard as well.
Won't this bypass squidguard as well? -
Sorry, I was thinking Bypass proxy for these destination IPs, not Source.
I'm not clear on whether 'bypass' means completely avoid or simple do not cache. Besides, unless you're using squidGuard to filter particular audio streams, it wouldn't really be needed here.
No no 8) not the destination address.
I have tried that, adding tunein.com, but as you can see in my first post tunein just routes the stream to the origin site.
So that would be an endless list of bypasses.Do not cache I could live with, bypass not.
I will be using squidguard to filter porn etc. More or less a "kids filter". -
It would be ok if you only had a handful of stations that you listen to. Otherwise I see your point.
squidGuard simply filters URLs. Are there porno audio-only streams out there???
Hahahahahahahaha come on guys.
I just shit my pants! LOL -
I have removed the AV scanner from the pfSense box.
So that is for now the solution. -
You'll really need to dig into the C-ICAP docs. If you figure out some working configuration, it can be put to the package, but I certainly don't have time to play with radios streaming ATM.
