    2.3 Quality monitoring not working
    32 Posts 4 Posters 7.5k Views
      cmb
      Thanks for the correction, Denny.
      So that screenshot of the status screen confirms it's working fine. What does a screenshot of the graph look like?
        Apathia
        This
        screencapture-10-10-10-1-status_monitoring-php-1461711282614.png_thumb
          cmb
          Are all your other monitoring graphs fine? Any gateway names in the Graphs drop down other than those two? Seem to match up to the status page.
            Apathia
            Everything else works fine (except for Queues/Queuedrops but I don't have any traffic shaping so it's not broken). Nothing else in the drop down menu.
              cmb
              Could you send me copies of your /var/db/rrd/WAN_DHCP-quality.rrd and WAN_DHCP6-quality.rrd files? Can download them under Diag>Command, or via scp.
                Apathia
                I also reboot the system to see if it had any effect. It did not :(
                  cmb
                  Thanks, you can remove those now if you'd like. Files are sane, but their contents stop on April 12.
                  Try moving those two files to a different filename, and reboot afterwards. Give it 5 minutes post-reboot to gather data. Does it work then?
                    Apathia
                    Omg, I think that actually fixed it. It seems to actually be recording it now.
                    Between 2.2 and 2.3, are there differences in how it records the info? The reason why the logs stop is because I updated while trying to keep the RRD data.
                      cmb
                      Glad that worked. Maybe the conversion on upgrade failed on your system. That RRD file is updated during upgrade since it had standard deviation now as well. Did you have any rrdtool logs in your system log?
                        Apathia
                        What's weird is I first upgraded the system and then followed it up with a fresh install after a few days of it not working. When I did the fresh install, I didn't import anything and just set up the basic things and still no go for the quality monitor. I did eventually end up importing my old config to get a few other things back to what I had.
                        As far as anything in the system logs, well I'll have to check later when I have access to it.
                        EDIT: Nothing in the logs as far as I can see, anything specific I can search for or just rrdtool?
                          cmb
                          @Apathia:
                          huh, yeah that's odd. The reinstall would have started with fresh rrd data files as long as the config you restored didn't include RRD data. So it shouldn't have happened in that case. Sure you didn't have RRD data in the restored config maybe?
                          @Apathia:
                          Just rrdtool would suffice. 'clog /var/log/system.log | grep rrdtool'
                            Apathia
                            @cmb:
                            @Apathia:
                            @Apathia:
                            No results when searching for rrdtool.
                            I did have the data in my old config, but I didn't restore it right away. After the upgrade I backed it up then did a factory reset but that still didn't work so I did a fresh install. After waiting a day or two with it still not working, I did finally restore it to get the misc settings that I hadn't bothered to go through initially.
