    Guide to filtering web content (http and https) with pfsense 2.3
    Scheduled Pinned Locked Moved Documentation
    190 Posts 54 Posters 243.4k Views 15 Watching
      aGeekhere
      Thanks huuur, that should help others.
      Though it would be good if youtube was better at filtering videos.
      Never Fear, A Geek is Here!
        aGeekhere
        Update
        You can try setting up MITM by setting the SSL/MITM Mode to splice all, that way you do not need to create a certificate for each device on the network. (you still need to create a main certificate though).
        • V Offline
          vielfede
          @aGeekHere:
          Update
          That works fine for me also setting Client proxy settings manually:
          Proxy address/PORT= SQUID_IP 3128
          And that only! Indeed if i specify different proxy settings for http/https in (client win10=> Internet Settings=>Lan settings=>Advanced=>
          • http=SQUID_IP 3128
          • https=SQUID_IP 3129
          It does not work, as in the contrary I'd excpect….  ::)
          Geek can you explain why?
            aGeekhere
            Does automatically detect settings work?
            • V Offline
              vielfede
              @aGeekHere:
              Ehmm sorry, could you explain me better what you mean? As I stated I do not use WPAD, I configure proxy manually on client see picture…
              Thanks.
              PS. Sorry to answer late
              ProxyClientSettings.JPG_thumb
                aGeekhere
                if you have the transparent proxy working then you do not need to define the proxy server.
                • V Offline
                  vielfede
                  If I use it in transparent mode, https does not work!
                  Better sometimes it works, sometimes it does not! (http works always!)
                  If anyone managed to get http+https in splice all + transparent mode work please let me know… ;)
                    aGeekhere
                    I just enabled it mitm, added a cert, set it to splice all and its working.
                      techbee
                      The guide is update but confusing.  Can you please clean up the guide and have it step by step.  Its somewhat hard to follow if you are not familiar with wpad and related firewall rules.
                      Thanks for the guide.
                        aGeekhere
                        hi techbee, yeah after discovering a few new things the guide is a little messy now.
                        The transparent proxy with MITM (splice all) vs wpad should really be divided into two different choices. When I made the guide I did not know that all you need to get transparent proxy for https working is set splice all and create a cert for the router. So in fact you can now choose either using a wpad or the transparent proxy MITM or both.
                        when i get time I will try an clean it up a bit.
                        • V Offline
                          vielfede
                          @aGeekHere:
                          Indeed I do not think MITM and splice all can work toghether, as stated on squid documentation MITM is associated to the "bump" directive that is something complety different from splice directive.
                          With MITM (bump) squid is able to decrypt traffic (and analyse it) meanwhile with splice all you can do is just "web filtering".
                          Summarizing
                          Directive          Advantages/features        Disadvantage
                          Splice (all)        No needs of certificate installation on Clients + webfiltering              No traffic analysis i.e no AntiVirus
                          Bump (MITM)    Traffic analysis i.e noYES AntiVirus    + webfiltering                              Needs to install certs on clients
                          Please take a look here and let me know if I missed something. Thanks
                          http://wiki.squid-cache.org/Features/SslPeekAndSplice#Actions
                          http://marek.helion.pl/install/squid.html
                            AR15USR
                            @vielfede:
                            @aGeekHere:
                            Summarizing
                            Bump (MITM)    Traffic analysis i.e no AntiVirus    + webfiltering                              Needs to install certs on clients
                            Shouldn't the second one not have the word "no"..
                            2.6.0-RELEASE
                            • V Offline
                              vielfede
                              @AR15USR:
                              Sorry cut & paste mistake, I fixed it.
                                mahnonsaprei
                                Hi at all,
                                I'm Marcello from italy. Nice to meet you, i'm a newbie of pfsense.
                                I have read the tutorial, but i have one problem.
                                When i try to connect to an https website in blacklist, the browser show me a generic error see the attachment: (ERR_TUNNEL_CONNECTION_FAILED) while i want to see a message of pfsense that explain the block. In http it's ok
                                I'm looking for in google but i not found the answer.
                                Please help me.
                                Thank you veeeeery much!!!
                                error.PNG_thumb
                                  aGeekhere
                                  Known issue with squid, I do not think there is a fix for it.
                                    mahnonsaprei
                                    Thank you so much. There aren't alternatives to redirect https via proxy also blank page or other?
                                    B.r.
                                      techbee
                                      hello ageekhere,
                                      can you update your guide now.
                                        aGeekhere
                                        what part are you stuck on?
                                          techbee
                                          1. I dont know what exact firewall rules to add
                                          2. I am confused if I need to install unofficial wpad package of marcelloc.
                                          3. I am confused if there is a need to have separate webserver of wpad.
                                          4. I am confused if I can enable both transparent and ssl mitm filtering on squid.
                                          5. I cant nslookup wpad on clients command prompt to resolve to my pfsense box ip.
                                            aGeekhere
                                            The firewall rules that you need are
                                            IPv4+6 TCP	*	*	*	80 (HTTP)	*	none	 	port 80 block
                                            IPv4+6 TCP	*	*	*	443 (HTTPS)	*	none	 	port 443 block
                                            This blocks access to port 80 and 443, it stops users from bypassing the proxy.
                                            Also if you want to force pfsense to be the DNS server use.
                                            In Firewall/NAT/Port forward
                                            add a new rule
                                            Interface = LAN
                                            Protocol = TCP/UDP
                                            Source ports = *
                                            Dest address = *
                                            Dest ports = 53
                                            NAT IP = 127.0.0.1
                                            NAT Ports = 53
                                            Description = Redirect DNS
                                            LAN TCP/UDP * * * 53 127.0.0.1 53 Redirect DNS
                                            Save
                                            Have a look through a few of these videos https://www.youtube.com/playlist?list=PLE726R7YUJTePGvo0Zga2juUBxxFTH4Bk
                                            There are a few really good configs he does there.
                                            2. Wait for the package to become stable and available in the package manager, in the mean time you can use the pfsense webserver, put the wpad files in /usr/local/www/ read Part 3. (all that needs to be done is add the wpad files (wpad.da, proxy.pac and wpad.dat) to /usr/local/www/).
                                            3. Just use pfsense webserver /usr/local/www/ (I have not used an external webserver)
                                            4. This is what I did, I set up a WPAD and transparent proxy with ssl mitm (splice all so you do not have to install cert on every device) and set your device to auto configure. I found that just using WPAD a lot of programs that cannot use the proxy were getting blocked so the transparent proxy catches that and something the transparent proxy ssl has issues (like windows updates) however the WPAD is used for that. Best of both worlds.
                                            5 I have had issues as well, if you put http://192.168.1.1/wpad.dat in your web browser and it downloads than it is working.
                                            This guide goes a few steps fever by forcing google and bing to be in safe mode (even youtube).
                                            So what I would do is get WPAD working then enable the transparent proxy with ssl mitm (create a cert for the router).
                                            Hope this helps
