    Guide to filtering web content (http and https) with pfsense 2.3
    Scheduled Pinned Locked Moved Documentation
    190 Posts 54 Posters 248.1k Views 15 Watching
      techbee
      thanks for the reply aGeekHere.
      What is the tcp port that you used on your webconfigurator ?  If I block port 80, then, I will also be blocked opening the pfsense gui.
      Also, regarding to my question number 4, do you mean that you did not enable the http transparent proxy on port 3128 but only the HTTPS/SSL MITM on port 3129 and setup wpad. did I understood you correctly ?
        aGeekhere
        set pfsense Protocol to http (This is a MUST, it will not work if you do not do this)
        System: Advanced: Admin Access Protocol http
        No it should not (have the rule above the anti lockout rule);
        Enable squid proxy 3128
        Get WPAD working follow guide
        Enable transparent mode to forward all requests for destination port 80 to the proxy server.
        Enable SSL filtering
        Splice all
        create Certificate (for pfsense).
        Summery
        Set Advanced: Admin Access Protocol to http
        Enable squid proxy
        Follow guide on setting up WPAD
        Enable SSL filtering Splice all
        Never Fear, A Geek is Here!
          techbee
          Yep, done that all.
          I can download the wpad files from the browser. I can access the http sites but still cannot access the https sites.
            aGeekhere
            what web browser?
            Clear your cache?
            What Operating system?
            Operating system update work?
            Did you set auto configure proxy?
            Try Diagnostics States States clear?
            What sites, google?
              techbee
              @aGeekHere:
              what web browser?
              Clear your cache?
              What sites, google?
              Hi aGeekHere,
              Yes, cache is cleared,
              os=win7 pro sp1,
              I disabled the update coz I dont need it,
              autoconfigure is set,
              yes, google and yahoo https sites. facebook and youtube does not load and shows error.
              I use splice-all.  Don't I really need to install certs to client device ?
              If https site is successfully blocked, what error page do I expect to see ?  Can you show me the screenshot for the error page that will show !
                aGeekhere
                firefox ie or chrome?
                not when splice all
                The default cannot access page of the web browser.
                If you enabled squid, transparent mode and SSL filtering Splice all with a cert on pfsense and you still cannot access https sites, then something is broken.
                Try reinstall.
                If you still have the same issue post screen shots of your setup.
                  techbee
                  @aGeekHere:
                  not when splice all
                  Try reinstall.
                  I am using chrome. most of the users are chrome.
                  On the other hand, the firewall rules you shown was to block port 80 and 443 right and redirect dns resolution to pfsense dns server and no more else.  That means, I don't need to redirect traffic from port 80 to 3128 and 443 to 3129 right ?
                    aGeekhere
                    That is what the transparent proxy is doing, remove that rule, that could be what is causing the issue.
                      techbee
                      @aGeekHere:
                      Alright
                      So what I have now on my firewall rules are:
                      1. antilock rule on port 80 which says (allow all on tcp port 80)
                      2. block LAN_NET on tcp port 80 and 443
                      3. redirect rule for dns resolution
                      would that be ok ?
                      On the other hand, what is the default cannot access page of the web browser, is it the same like of that of http transparent proxy error page ?
                        techbee
                        aGeekHere,
                        My wpad now works.  I can download it from chrome browser.
                        I can ping and nslookup wpad now.
                        All squidguard group ACL and its target rules are applied to block facebook and youtube for testing purposes for now.
                        I HAVE NOT INSTALLED THE CA CERT ON CLIENT DEVICES.
                        I used http and https filtering with splice all option so that I dont need to install the cert to client devices.
                        I also cleared browser cache and history.
                        The result is I can browse http but cannot browse https.  Https sites like yahoo and google mail works though.
                        I have screenshot of the error for browsing https site.
                        error.jpg_thumb
                          aGeekhere
                          Is squidguard blocking it by mistake? is it set to deny all?
                          Try allowing all in squidguard rules to test.
                          Post screen shots of squidguard.
                          Try clearing states in pfsense.
                          Reboot.
                            techbee
                            Squidguard is not blocking by mistake.
                            I tried clearing firewall states and Rebooted, still the same situation.
                              techbee
                              I also have this wireshark done where I can see that it made a CONNECT method to facebook, then it has established connection, send client hello but later have RST and there is no SERVER HELLO thus no application data received.
                              What could I miss here.
                              Untitled.jpg_thumb
                                aGeekhere
                                lets try without the wpad and use just the transparent, set proxy direct does it work then?
                                If you still cannot access https sites then post you squid config.
                                  techbee
                                  @aGeekHere:
                                  If I use only the http proxy without the ssl mitm and set browser to auto, then the http proxy filter works.
                                  If you are saying to setup http transparent proxy and ssl mitm filtering and install cert to client device and set browser proxy, then I have not done this yet.
                                    aGeekhere
                                    Just use splice all for mitm (and use the cert created in pfsense under SSL Man In the Middle Filtering\CA).
                                    Set browser to direct.
                                    This will use transparent proxy for both http and https.
                                    If this works then there is an issue with your WPAD.
                                    If this does not work then something is broken.
                                      techbee
                                      @aGeekHere:
                                      What do you mean for "Set browser to direct", is this the automatic detect settings ?
                                      On the other hand, my wpad only have the following inside:
                                      function FindProxyForURL(url,host)
                                      return "PROXY 192.168.1.1:3128";
                                      I am not sure what you example below means so I use the example from pfsense wiki.
                                      function FindProxyForURL(url, host)
                                          if (isPlainHostName(host) ||
                                              shExpMatch(host, "*.local") ||
                                              isInNet(dnsResolve(host), "192.168.1.0",  "255.255.255.0"))
                                              return "DIRECT";
                                        aGeekhere
                                        yeah turn off automatic detect setting so the traffic goes direct and gets intercepted by the transparent proxy.
                                          techbee
                                          @aGeekHere:
                                          By turn off, you mean uncheck the automatic detect settings and others options as well ?
                                            aGeekhere
                                            yes
