    Upgrade from 2.2.6 to 2.3.1 problem - help me
    4 Posts 2 Posters 968 Views
      giuge
      hello, today i upgrade pfsense from 2.2.6 to 2.3.1 but after then i'm not able to ping external IP addresses, or navigate web, from LAN. Pfsense->Diagnostic->ping  ping 8.8.8.8 from WAN work, but ping from LAN failed. What's append? Thanks in advance
        Marlenio
        @giuge:
        Are you using a PPPoE connection with bridget modem?
        Marlenio
          giuge
          @Marlenio:
          @giuge:
          yes!
            Marlenio
            I think is the same problem happen to me: https://forum.pfsense.org/index.php?topic=112169.0
            Add "PPPoE" to the thread title, so the pfSense can collect info about this bug.
            Marlenio
