    Dual Wan FTP weird connection problem
    1 Posts 1 Posters 2.1k Views
      jtpagaran
      Im configuring my Dual wan pfsense 1.2.1RC1 and almost everything is working… except my outgoing ftp connections. What I encounter was whenever I disable my OPT1 interface I can connect to outside ftp site but when i enable it again (OPT1) my ftp connections seems not responding.
      my hardware is a p4 Asus mobo w/ builtin A/V/L
      rl2 -Lan side  (w/ private IP 192.168.1.0/24)
      rl0-Wan side  (w/ public IP from ISP1)
      rl1-opt1 wan2  (w/ public IP from ISP2)
      I also added the suggested rules in for ftp from this site http://devwiki.pfsense.org/FTPTroubleShooting
      _Outgoing FTP (LAN -> Internet) UPDATED PORTS, please check!
      1. Ensure that the FTP helper is not disabled on Interfaces, LAN
      2. If you have a restrictive ruleset or are utilizing policy based routing for multiple-wans then ensure that you have permitted traffic to 127.0.0.1 / ports 8000-8030. IE: allow LAN subnet to 127.0.0.1 8000-8030. This rule should be on top of all other LAN rules that utilize policy based routing.
      3. If you are running windows try turning off the windows firewall_
      Are there any other setting that I might need?
      Thanks In Advance!!!
      More power to Pfsense Dev Team
