    Problem with network interface when connected system is down and comes back up
    3 Posts 1 Posters 1.0k Views
    • C
      CS
      Hi all!
      I recently upgraded my Soekris 6501 board to the latest version (2.3.2-RELEASE) and the following weird thing started happening some days later.
      There is a desktop PC connected directly to one of pfsense's LAN interfaces and sometimes when I turn the PC on it doesn't get an IP from the DHCP server and in general cannot communicate at all with pfsense (it doesn't receive any packets from pfsense). I tried with a laptop and I had the same issue which gets always resolved with a reboot of pfsense. By the way restarting the DHCP server doesn't help. I also assigned a static IP to the PC, which is reserved for it on the DHCP server anyway, but still it doesn't receive any packets from pfsense. I never have issues while the PC is online, so it's something that has to do with the interface changing status (DOWN - UP).
      Since I confirmed that pfsense causes the problem, let's focus on that one. First of all, when I turn the PC on the interface looks UP in pfsense, shows only 1 packet sent out with 3 out errors and 0 collisions. The interface is a LAN bridge member. The only change I did on the system after the upgrade was that I tested Snort with LOWMEM pattern match but I had changed it back to AC-BNFA.
      System logs:
      Aug 14 13:01:56 SnortStartup       8193 Snort START for WAN(28214_em3)…
      Aug 14 13:01:56 php-fpm 72011 /rc.start_packages: Restarting/Starting all packages.
      Aug 14 13:01:55 check_reload_status Starting packages
      Aug 14 13:01:55 php-fpm 88398 /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - 0.0.0.0 -> - Restarting packages.
      Aug 14 13:01:52 php-fpm 88398 /rc.newwanip: Creating rrd update script
      Aug 14 13:01:52 php-fpm 88398 /rc.newwanip: Resyncing OpenVPN instances for interface LAN1.
      Aug 14 13:01:51 xinetd 24963 Reconfigured: new=0 old=1 dropped=0 (services)
      Aug 14 13:01:51 xinetd 24963 readjusting service 6969-udp
      Aug 14 13:01:51 xinetd 24963 Swapping defaults
      Aug 14 13:01:51 xinetd 24963 Starting reconfiguration
      Aug 14 13:01:50 xinetd 24963 Reconfigured: new=0 old=1 dropped=0 (services)
      Aug 14 13:01:50 xinetd 24963 readjusting service 6969-udp
      Aug 14 13:01:50 xinetd 24963 Swapping defaults
      Aug 14 13:01:50 xinetd 24963 Starting reconfiguration
      Aug 14 13:01:50 php-fpm 88398 /rc.newwanip: IP has changed, killing states on former IP 0.0.0.0.
      Aug 14 13:01:50 php-fpm 88398 /rc.newwanip: rc.newwanip: on (IP address: ) (interface: LAN1[opt4]) (real interface: em0).
      Aug 14 13:01:50 php-fpm 88398 /rc.newwanip: rc.newwanip: Info: starting on em0.
      Aug 14 13:01:49 check_reload_status Reloading filter
      Aug 14 13:01:49 check_reload_status rc.newwanip starting em0
      Aug 14 13:01:49 php-fpm 88398 /rc.linkup: Hotplug event detected for LAN1(opt4) static IP ( )
      Aug 14 13:01:48 kernel em0: link state changed to UP
      Aug 14 13:01:48 check_reload_status Linkup starting em0
      Any ideas for troubleshooting?
      /CS
      • C
        CS
        I still have the same issue and I have to reboot pfSense every other day… :(
        It seems it also has to do with how many hours the desktop stays powered off. If I turn it on after a few hours ( less than 8 ) usually I don't have problems but when I try after 12hours or so it cannot connect to the network.
        Any ideas guys?
        • C
          CS
          That's what happens a few hours after the desktop has been turned off. I have no idea what triggers that event in PfSense, is there any way to keep the link state UP?
          Aug 25 03:10:35 xinetd 25467 Reconfigured: new=0 old=1 dropped=0 (services)
          Aug 25 03:10:35 xinetd 25467 readjusting service 6969-udp
          Aug 25 03:10:35 xinetd 25467 Swapping defaults
          Aug 25 03:10:35 xinetd 25467 Starting reconfiguration
          Aug 25 03:10:34 check_reload_status Reloading filter
          Aug 25 03:10:34 php-fpm 69603 /rc.linkup: Hotplug event detected for LAN1(opt4) static IP ( )
          Aug 25 03:10:33 check_reload_status Linkup starting em0
          Aug 25 03:10:33 kernel em0: link state changed to DOWN
          Aug 25 03:10:33 kernel em0: RX Next to Refresh = 32
          Aug 25 03:10:33 kernel em0: RX Next to Check = 33
          Aug 25 03:10:33 kernel em0: RX discarded packets = 0
          Aug 25 03:10:33 kernel em0: hw rdh = 33, hw rdt = 32
          Aug 25 03:10:33 kernel em0: RX Queue 0 –----
          Aug 25 03:10:33 kernel em0: Tx Descriptors avail failure = 16
          Aug 25 03:10:33 kernel em0: TX descriptors avail = 40
          Aug 25 03:10:33 kernel em0: Tx Queue Status = -2147483648
          Aug 25 03:10:33 kernel em0: hw tdh = 890, hw tdt = 850
          Aug 25 03:10:33 kernel em0: TX Queue 0 ------
          Aug 25 03:10:33 kernel Interface is RUNNING and ACTIVE
          Aug 25 03:10:33 kernel em0: Watchdog timeout Queue[0]– resetting
