    NETASQ U70 pfsense 2.3.2 install, network interface problem
    24 Posts 5 Posters 7.9k Views 1 Watching
      Guest
      Hello there,
      I am answering on a private message, much late but I was really busy in the last month.
      If the LAN Port is an EM that is supported and the PHY behind it is perhaps let us imagine
      a (Pericom PI7C9X2G608GP Gen 2 Switch) that isn´t supported you will only see one LAN
      Port such the EM Port. If the PHY (Switch) behind is full supported by pfSense you will see
      all LAN Ports available to use. Thats it in my eyes.
      • stephenw10S Online
        Never heard back. Did you give up krystian?
        Understandable since there is other much more suitable hardware available. However you are seeing two VLANs there so the switch is configured somehow. Unless you configured those VLANs in pfSense and both are set to DHCP. Which would explain why it looks like the Netasq MAC sending.
          Potentially slightly easier to get working with today blog post announcement.
          Still coding to be done though as that switch does not appear to be one supported by etherswitch.
          https://github.com/freebsd/freebsd/tree/master/sys/dev/etherswitch
          • L Offline
            lubousa
            Suddenly view this tread. I have many of this netsq u70. There is switch witch is connect to serial port 2. use " cu -s 9600 -l ttyu1" command to configure switch. You can assign ip on the switch and configure everything thru web. You can create vlan for WAN port and use other port for lan. EM0 its connected to port 1.
