    [HOWTO] Multi WAN Traffic shaper with bandwidth limits per interface
    29 Posts 14 Posters 23.5k Views 1 Watching
      tho
      Hello,
      I am trying to make my shaper working. I have only one WAN and one LAN (simple case :)), I would like to limit HTTP download and reserve bandwidth for VOIP, RDP and PCOIP. I followed approximately the howto, but it seems that download traffic is stuck in default download queue (except for voip, I don't understand why).
      In the howto it is written
      • Action: Match
      • Interface: WANx where x is the WAN number
      • Direction: out (yes, it is outgoing direction !)
      • Address Familiy: IPv4 and IPv6
      • Protocol: Any
      • Gateway: default
      • Ackqueue / Queue: none / qDownloadLowWANx
      Why for download the direction is out from the WAN ?
      In my floating rules I set out on WAN interface for upload (and it seems to work) and out from LAN interface for download.
      Another question : If a connection (for example HTTP) is established by a user and used to download, will TCP packets be queued in download or upload queue ?
      So I'm quite lost about these traffic directions, and how I must write my floating rules to match traffic. You can find attached my floating rules and queues.
      Thank in advance for you help.
      queue_ts.png_thumb
      traffic_shaper.png_thumb
        deajan
        @tho: I don't see any HTTP rules, so it goes to the default queue.
        I've setup a full system for hotels where I used squid in order to limit http downloads too.
        btw: Je viens de voir que tu as une règle "serveur tse", donc j'imagine pas me tromper en te parlant fr. Si tu veux j'ai écrit ma doc en FR à la base si ca peut t'aider, contacte moi par mail direct si tu veux :)
        NetPOWER.fr - some opensource stuff for IT people
          pollacomax
          First of all, thanks a lot Deajan, the way and the time you take to write this post is to thank.
          I have a problem on the upload, if i didnt misunderstood this shape limit the upload of the wans:
          Go to Firewall > Traffic Shaper
          Remove any traffic shaper queues if some are configured.
          For every WAN interface listed in the Traffic Shaper:
          • Click on "Enable/disable discipline and its children"
          • Keep the HFSC scheduler as HFSC is the only scheduler allowing children queues without any errors in pfSense 2.3-2.3.2 so far. Also, mixing different schedulers isn't working yet on pfSense. So even if you don't need any special subqueues on WAN links, you'll still need them on the LAN interface later.
          • The bandwidth parameter to set here is 95% of the measured upload speed:
              WAN1 = 9.8x0.95 = 9.3Mb
              WAN2 = 920x0.9 = 828Kb (we use a lower multiplier because the line isn't stable)
              WAN3 = 3.8x0.95 = 3.6Mb
          • Queue Limit and TBR Size are left empty unless you know exactly what you're doing
          • Click on Save
          Configuring the bandwidth parameter here is sufficient to enforce the upload speed of pfSense to the WAN modems.
          The others shapes works fine, the download are limit, but not the upload.
          The only floating rules necessary are the download ones, right?
          Does it have anything to do with the version of the pfsense?
          Thanks in advance!
            tho
            @deajan:
            Thank you for replying, the first rule sould match with HTTP and send it to DownloadLow queue, not the default LAN queue qLink. Am I right ?
              klou
              @allen34
              Do you think Policy-based routing would solve the issue of Multi-WAN/Multi-LAN?
              Assuming that we have rules on each LAN interface tagging the traffic types, they can then be classified into outgoing queues on the WAN(s) side via floating rules.
                mrmacadamia
                @deajan:
                @Ma_Fabulette: The floating rules described in the post are only matching ones. So basically you could make failover rules on the LAN side using routing groups, as long as you don't specify any queues there.
                You might also merge the LAN queues in one if all the WAN lines have the same download capacity, so you can use priority queues easily.
                How do you setup in LAN rules of firewall? Some screenshot might be help.
                Currently i'm using grouping my two WANs that i setup in system->gateway groups and name it as LoadBalancing. I use it in LAN rules as gateway.
                Thanks. Your configuration makes me want to learn this.
                  allan34
                  @klou:
                  @allen34
                  Apologies for the late reply. Unfortunately have no experience of multiwan and multi lan.
                  The approach outlined in my post works only because the WAN incoming traffic all ends up in the same queue on the same LAN interface.
                  Maybe there are possibilities
                  a) Assign multiple WANS to to each LAN
                  i.e. 2 wans for LAN1 and 2 separate wans for LAN2
                  b) Split each WAN into equal amounts for each LAN
                  e.g. if you have  2x WAN links and 2x LAN, then split bw of each WAN in half and assign a half from each WAN to each LAN.
                  But I do not see a way of balancing all LAN traffic across all WANS. This is because you will have separate queues for each LAN.
                  In the end, buy more WAN links and divvy your users up across them. Pretty sure that is what sensible people do and why I believe not so many posts about this problem is found. Simply have a "WAN budget" per employee, so if you get 100 users you pay N $$, and if you have 200 users you pay 2x N $$. Unfortunately we are in a remote location and this is not possible so we try to squeeze as much as we can out of the 2x DSL lines we have and pay a small fortune for the privilege where others buy 10x the bandwidth at 1/4 the price.
                  Cheers A
                    scatt
                    HI,
                    i'm on version 2.3.4 and upload limit seems not to work( https://forum.pfsense.org/index.php?topic=145500.0).
                    Also after create the qLink and the qDownloadWANX queues the tutorial say
                    If you only need to limit the bandwidth, we're done here.
                    to apply them i needed to create the rules on firewall/floating as described below, don't know if pfsense behavior changed or i misread the instruction ( to me is sounded like "If you only needed limiters you are done" ).
                      waldopulanco
                      how create queue for upload? I tried creating queue on wan interface like on lan interface and apply it to floating rules, direction is IN but not working.. thanks
