    Folks I need Help!
    33 Posts 5 Posters 4.5k Views
    • NeoDudeN Offline
      NeoDude
      Have we established that his AP is VLAN aware? and set up to use VLAN100?
      Home Server "Gandalf":  unRAID Pro 6 | MB**:**  ASUS Z9PE-D8 WS | CPU:  Dual Xeon E5-2670 | RAM:  64GB Crucial PC-1600 ECC
        jehu
        @NeoDude:
        AP is vlan aware it's a Ubiquiti UniFi AP-AC-Pro AP…but if I plug my laptop in that port I can't get and ip
        • johnpozJ Online
          He is not doing that yet - he is just connecting a device to is vlan port 10.. And its not getting an IP from pfsense, or can not talk to pfsense.  If he can not get a simple access port to work.. Then what is the point of moving to AP?
          on your pfsense box can you do a ifconfig and post the output so we can see that your nic actually supports vlan tagging..
          example
          em2: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500
                  options=9b<rxcsum,txcsum,vlan_mtu,<strong>VLAN_HWTAGGING,VLAN_HWCSUM>
                  ether 00:50:56:00:00:03
                  inet6 fe80::250:56ff:fe00:3%em2 prefixlen 64 scopeid 0x3
                  inet 192.168.2.253 netmask 0xffffff00 broadcast 192.168.2.255</rxcsum,txcsum,vlan_mtu,<strong></up,broadcast,running,promisc,simplex,multicast>
            jehu
            here you go
            em0: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500
                    options=5009b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,vlan_hwfilter,vlan_hwtso>ether 00:14:5e:77:61:9c
                    inet6 fe80::214:5eff:fe77:619c%em0 prefixlen 64 scopeid 0x1
                    inet 24.23.x.x netmask 0xfffff800 broadcast 24.239.15.255
                    nd6 options=23 <performnud,accept_rtadv,auto_linklocal>media: Ethernet autoselect (1000baseT <full-duplex>)
                    status: active
            em1: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500
                    options=5009b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,vlan_hwfilter,vlan_hwtso>ether 00:14:5e:77:61:9d
                    inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255
                    inet6 fe80::1:1%em1 prefixlen 64 scopeid 0x2
                    nd6 options=21 <performnud,auto_linklocal>media: Ethernet autoselect (1000baseT <full-duplex>)
                    status: active
            pflog0: flags=100 <promisc>metric 0 mtu 33160
            pfsync0: flags=0<> metric 0 mtu 1500
                    syncpeer: 224.0.0.240 maxupd: 128 defer: on
                    syncok: 1
            enc0: flags=0<> metric 0 mtu 1536
                    nd6 options=21 <performnud,auto_linklocal>lo0: flags=8049 <up,loopback,running,multicast>metric 0 mtu 16384
                    options=600003 <rxcsum,txcsum,rxcsum_ipv6,txcsum_ipv6>inet 127.0.0.1 netmask 0xff000000
                    inet6 ::1 prefixlen 128
                    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
                    nd6 options=21 <performnud,auto_linklocal>em1_vlan100: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500
                    options=3 <rxcsum,txcsum>ether 00:14:5e:77:61:9d
                    inet6 fe80::214:5eff:fe77:619d%em1_vlan100 prefixlen 64 scopeid 0x7
                    inet 192.168.2.1 netmask 0xffffff00 broadcast 192.168.2.255
                    status: active
                    vlan: 100 vlanpcp: 0 parent interface: em1</full-duplex></performnud,auto_linklocal></rxcsum,txcsum></up,broadcast,running,simplex,multicast></performnud,auto_linklocal></rxcsum,txcsum,rxcsum_ipv6,txcsum_ipv6></up,loopback,running,multicast></performnud,auto_linklocal></promisc></full-duplex></performnud,auto_linklocal></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,vlan_hwfilter,vlan_hwtso></up,broadcast,running,simplex,multicast></full-duplex></performnud,accept_rtadv,auto_linklocal></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,vlan_hwfilter,vlan_hwtso></up,broadcast,running,simplex,multicast>
            • NeoDudeN Offline
              NeoDude
              Your laptop won't work on port 10 because it's not a member of VLAN1 and I'm guessing the laptop isn't VLAN aware.
              • johnpozJ Online
                ^ what??  Its a native vlan.. Laptop does not have to have any clue to what vlan its on.. Its native untagged vlan..
                • NeoDudeN Offline
                  NeoDude
                  According to the listing back on the first page, his port 10 is not a member of the native VLAN (VLAN1), it is only a member of VLAN100, if this is a tagged port then the laptop won't see it.
                    hda
                    pfSense(to switch) vLAN(100);
                    switch upload(to pfSense) Tagged(100) for port(AP) /Trunk;
                    switch port(AP) Untagged;
                    AP no vLAN.
                      jehu
                      @hda:
                      AP no vLAN.
                      Sorry not sure I understood all that.
                      Is there someone with any other ideas…maybe someone with the same switch?
                      • NeoDudeN Offline
                        NeoDude
                        Ah, I gotcha now. You have port 10 set as VLAN100 untagged and it's not working? Sorry about my ramblings then, lol. I'm not familiar with Cisco switch terminology but would there not be a PVID setting to also get changed for port 10 to tag traffic from the laptop as VLAN100? Or is that all taken care of when assigning the port?
                        • johnpozJ Online
                          When you assign the port it changes the pvid.
                          Are we SURE!! that pfsense is connected to port 3 that you have set to trunk??
                          Your saying all the other ports work, ie vlan 1 but not vlan 100..  Seems like to me if you were on some other port and not 3 that is exactly what would happen.
                          Please verify that, and if in fact in 3 then lets sniff on pfsense lan interface.  You should see the tagged dhcp discover come in..
                            jehu
                            port 3 is connected to pfsense and trunk with vlan 100 allowed.
                            port 10 is set as vlan 100, is access port…not trunk.
                            if I plug into any other port which is set to vlan 1 default on the switch I get ip address and internet.
                            port 10 which is vlan 100 cannot reach the dhcp server.
                              jehu
                              OK got it all working…still not sure what it was. I reinstall Pfsense and factory reset my switch redid everything and seems to work.
                              Might have been also a problem the laptop adaptor I was connecting to the switch, one person mentioned that, so I tried my desktop and it work.
                              All is good now.
                              Thanks guys for all your help. :D
