    Help/ guide on setting up load balancer and proxy server(squid) on two box
    1 Posts 1 Posters 627 Views
    • T
      tripplex
      Help/ guide on setting up load balancer and proxy server(squid) on two different boxes.
      I want to know if i should put the load balancer (multiwan) first then the squid proxy server behind it with freeradius and captive portal on. Would triple natting be an issue here.
      so setup would be:
      [wan1, wan2, wan3, wan4 ] all have nat turned on.
      Then [load balancer] nat turned on connected to [squid proxy server] nat turned on with dhcp connected to switch.
      Is that config correct? or would the triple natting cause an issue?
      1 Reply Last reply
      Reply Quote 0
      Register Login
