    Setting up a WLAN using Linksys (DD-WRT) on OPT1 - stuck for 3 days!
    24 Posts 7 Posters 4.7k Views
      doktornotor Banned
      There's no need for the DHCP rule you put there in the first place. Also, there's DHCP log and there's firewall log. Look there.
        cs1212
        I decided to REBOOT pfSense and ALL fixed.
        also removed the 0.0.0.0 FW rule and still works.
        So.. sometimes its a simple Reboot.
        thanks to everyone who helped.
          doktornotor Banned
          Hmmmm, the mighty Redmond method…  ;D :D
            Gertjan
            I'm using 3 Linksys routers (as dumb AP devices) loaded with DD-WRT for the last …. many years !
            Version : Firmware: DD-WRT v24-sp2 (10/10/09) std
            My wifi network is hooked up to pfSense, OPT2, using 192.168.2.1/24.
            AP1 has IP 1912.168.2.2
            AP2 has IP 1912.168.2.3
            AP3 has IP 1912.168.2.4
            For all AP's :
            Subnet Mask : 255.255.255.0
            Gateway : 192.168.2.1
            Local DNS : 192.168.2.1
            Local DHCP server : disabled.
            WAN Connection Type : disabled.
            All my AP's are hooked up to pfSense using a central switch, but daisy chaining from OPT1 to AP1 to AP2 etc is also possible (I never use the WAN port, even when it is declared as another LAN port).
