    Help with hardware build
    61 Posts 6 Posters 18.4k Views
      Runenaldo
      @pfBasic:
      Yeah I use PIA VPN, those tests are synthetic and don't necessarily represent real world performance. You can run those commands in SSH.
      But the performance you are getting is definitely a configuration issue.
      I get 160Mbps real world usage on a J3355 and PIA VPN and the CPU isn't even working hard.
      Granted, a J3355 will be faster than a J3455 with OpenVPN but you should still hey WAY faster than .5 Mbps.
      Post up your settings and we'll try to get your VPN straightened out.
      Thank you
      I made a new post here on pfsense since I didnt want to hijack this thread. https://forum.pfsense.org/index.php?topic=129193.0
      I ran the test in SSH:
      256 cbc = 11.724s = 272.9Mbps
      256 gcm = 11.329s = 282.5Mbps
      128 cbc = 11.573s = 276.5Mbps
      128 gcm = 11.094s = 288,4Mbps
      pfsense 2.4b
      Asrock J3455-ITX
      2x4GB HyperX DDR3L 1866MHz
      2x16GB SanDisk Ultra Fit
