    Routing problem between PPPoE and LAN
    4 Posts 2 Posters 913 Views
      rahul11
      Router: Bridge Mode (192.168.1.5)
      Pfsense have 3 interfaces
      1. WAN(re0) 192.168.1.119 Gw: 192.168.1.5
      2. LAN (re1) 192.168.2.1
      3. OPT1 (created using PPPs: PPPoe over re0): ISP  IP received, Ping working to websites
      Problem: Internet not accessible from LAN (re1) 192.168.2.1
      Please help me in routing
        rahul11
        SOLVED:
        Firewall->rule->LAN tab
        Rule: ip4* -> Lan net -> to any,  THEN advance setting set gateway to OPT1
        Cheers and Party TIME
        • jahonixJ Offline
          jahonix
          Basically you made Opt another WAN. What's up with your WAN on re0, why don't you use that?
            rahul11
            @jahonix:
            Its Correct, but I have 4 internet connection all via router(one in bridge mode) and all router connect to unmanaged switch, now to route through bridge router, I have to define gateway on WAN, and PPPoe over WAN, so I did that way
            if you or any one have other idea, please share, Always ready to learn new things
            Pardon my delay reply
