    Fan Speed Control
    4 Posts 2 Posters 2.5k Views
      Kimbie
      I have a Watchguard x750e and trying to get the fan control to work
      I followed this guide https://forum.pfsense.org/index.php?topic=66129.0
      When i reboot the fans to get quieter but when you get the beeps to say system is ready the fans speed back up.  If I go into the shell and type cd /conf
      ./WGXepc -f 10 they go quiet again.
      Any idea what I am doing wrong?
      Kimbie
        DeLorean
        You must install the package "Shellcmd",
        and after installation , you add  this command in Shellcmd :
        /conf/WGXepc -f 10
        This command lower the fan speed during bootup,
        and keeps the fans at lower speed.
        Grtz
        DeLorean
          Kimbie
          @DeLorean:
          /conf/WGXepc -f 10
          Grtz
          DeLorean
          I tried that and doesn't work either.  I know that command works as if i SSH to the shell and type that it works
            DeLorean
            Do you use 32bit or 64bit ?
            If you use pfSense 64Bit, you must use the 64Bit version of WGXepc -> WGXepc64
            After installing the right version of WGXepc,
            you must change the read/write permissions with this command :
            chmod 0755 /conf/WGXepc  (for 32Bit version)
            chmod 0755 /conf/WGXepc64  (for 64bit version)
            I always add the WGXepc package and chmod command via :
            Diagnostics -> command prompt in the Web UI
            Grtz
            DeLorean
