Need some help with double wan setup and rutorrent ports… can't get green led
HI all,
First of all this worked on an ubuntu 14.04 kvm setup
but i wanted to upgrade to 16.04 and now it doesn't work any morewhat i did was make a backup of the 14.04 kvm setup
upgraded to ubuntu 16.04
when i tried to open the kvm it didn't work
so i installed from scratch again
imported the backup
but can't get a greed led in Rutorrent whatever i try :(here is the setup
Wan 1: fibre 100/20
wan 2: fibre 40/5
Lanas mentioned this is running into a KVM on ubuntu 16.04 on a dual processor server with 4 nics
the ruttorent is running in a dockerthis is /etc/network/interfaces
# source /etc/network/interfaces.d/* # The loopback network interface auto lo iface lo inet loopback # The primary network interface auto eno4 #iface eno4 inet dhcp iface eno4 inet static address 192.168.1.110 netmask 255.255.255.0 gateway 192.168.1.1 dns-nameservers 8.8.8.8 8.8.4.4 #pfsense nics auto eno1 iface eno1 inet manual #iface eno1 inet static #address 192.168.10.10 #netmask 255.255.255.0 #gateway 192.168.10.1 #dns-nameservers 8.8.8.8 8.8.4.4 auto eno2 iface eno2 inet manual #iface eno2 inet static #address 192.168.20.10 #netmask 255.255.255.0 #gateway 192.168.20.1 #dns-nameservers 8.8.8.8 8.8.4.4 auto eno3 iface eno3 inet manual #iface eno3 inet static #address 192.168.1.1 #netmask 255.255.255.0 #gateway 192.168.1.1 #dns-nameservers 8.8.8.8 8.8.4.4 #pfsense bridge auto br10 #iface br10 inet manual iface br10 inet static address 192.168.10.10 # network 192.168.10.0 netmask 255.255.255.0 # broadcast 192.168.10.255 # gateway 192.168.10.1 dns-nameservers 8.8.8.8 208.67.222.222 bridge_ports eno1 bridge_stp off bridge_fd 0 bridge_maxwait 0 auto br20 #iface br20 inet manual iface br20 inet static address 192.168.20.10 # network 192.168.20.0 netmask 255.255.255.0 # broadcast 192.168.20.255 # gateway 192.168.20.1 dns-nameservers 8.8.4.4 208.67.220.220 bridge_ports eno2 bridge_stp off bridge_fd 0 bridge_maxwait 0 auto br30 iface br30 inet manual #iface br30 inet static # address 192.168.1.1 # network 192.168.1.0 # netmask 255.255.255.0 # broadcast 192.168.1.255 # gateway 192.168.1.1 # dns-nameservers 8.8.4.4 8.8.8.8 208.67.220.220 bridge_ports eno3 bridge_stp off bridge_fd 0 bridge_maxwait 0the docker is running on it's own bridge
brctl show
bridge name bridge id STP enabled interfaces br10 8000.3c4a92b25c1c no eno1 vnet1 br20 8000.3c4a92b25c1d no eno2 vnet2 br30 8000.3c4a92b25c1e no eno3 vnet0 docker0 8000.0242864e8f10 no veth1cd2731 veth21dc85b veth2d938bb veth528c62f veth64bd613 vethb254583 vethc1c87a0 vethe494834 vethe5eea20 virbr0 8000.000000000000 yesroute
Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 192.168.1.1 0.0.0.0 UG 0 0 0 eno4 link-local * 255.255.0.0 U 1000 0 0 br10 172.17.0.0 * 255.255.0.0 U 0 0 0 docker0 192.168.1.0 * 255.255.255.0 U 0 0 0 eno4 192.168.10.0 * 255.255.255.0 U 0 0 0 br10 192.168.20.0 * 255.255.255.0 U 0 0 0 br20 192.168.122.0 * 255.255.255.0 U 0 0 0 virbr0the ports that are special are portforwarded from the Fibremodem to the IP of the lan used by pfsense
it works great for Plex media server which is also running in a docker
but this ruttorrent i can't get to work with open portsi made following NAT rules
WAN1_Txx
TCP/UDP
WAN1 address
32700 - 32710
192.168.1.1xx
32700 - 32710
Torrent_Proliant_TxxWAN2_
TCP/UDP
WAN2 Txx address
32700 - 32710
192.168.1.1xx
32700 - 32710
Torrent_Proliant_TxxWhich resulted in the automated firewall rules
and like that it always worked on 14.04
now i have tried a lot of stuff as adding outgoing rules / floating rules
traffic shaper to see if i could force it over one lan to see if either of them worked
but all to no useso i am forgetting something … just no clue what for the moment and it is driving me nuts
i can not bridge the modems to rule out the double nat as we have no access to the special info needed to logon to their networks
and it works fine for PLEXand id you look at the firewall rules you see something gets logged
1 /48 KiB
IPv4 TCP/UDP
192.168.1.1xx
32700 - 32710
none
NAT Torrent_Proliant_Txxso i think there is no problem with the port forwards on the modems
i am sure rutorrent docker is listening on these portsso now i am at my wits end and come ask help from the experts
