    Hardware for using pfsense as a managed switch?
    42 Posts 12 Posters 14.3k Views
      whosmatt
      @nktech1135:
      Curious, does pfsense have a good cli?
      It has a shell, yes.  If you log in (ssh) with "root" (using the same password you use for "admin" in the GUI) you'll get, by default, a menu.  Option 8 (IIRC) will get you a shell.  I don't believe there's a CLI as such specifically for managing pfSense, but in the shell you can do whatever you would in FreeBSD.
        Billyboy
        @jahonix:
        @Billyboy:
        We are replacing expensive company Internet lines with low cost residential VDSL lines, plus adding …
        What the hell does this have to do with "using pfsense as a managed switch"? Create a new thread for your topic.
        Because I am asking for an recomendation on a switch as in the thread discussed. Just not on the LAN side, but on the WAN side.
