    Second Lan network same interface
    45 Posts 4 Posters 10.3k Views
    • JKnottJ Offline
      JKnott
      @Derelict:
      Does pfSense know that interface has that ULA subnet on it? In other words, is that ULA subnet in the routing table with a destination of that interface?
      Does it require a specific route to be added?  In Cisco & Linux routers, the interface networks are added automatically, so it's not necessary to specify the route.  The prefix is correct in RA subnets and the computer gets the correct address.
      Netstat -r doesn't show the ULA route for the LAN or LAN4.  However, the first column, showing networks, is truncated, so the full address is not shown for all networks, but I think all interfaces show the global address routes.
      UniFi AC-Lite access point
        You wouldn't need to add a route for anything directly connected via pfsense.  But pfsense has to have a ULA address in that prefix on the interface connected to the network your using the ULA on.
        If you just setup the RA to hand out the ula prefix, pfsense wouldn't have to have an actual ULA address that interface.. So yeah it  would try routing it out its default IPv6 gateway..
        • JKnottJ Offline
          JKnott
          I tried adding a virtual IPv6 address to the LAN interface and it shows in ifconfig.  I can ping it from the pfSense command shell, but not from another computer.  The RAs advertise the ULA network, but not the pfSense interface address.
          • JKnottJ Offline
            JKnott
            I tried setting up a static route, but the only choices for gateway were the WAN or loopback interfaces.  I couldn't select the actual interface.  When I select the loopback ::1, traceroute shows multiple lines of the firewall address.
            Is it not possible to get pfSense to route ULA networks?  If not, that is a serious fault, as ULAs are just like RFC1918 IPv4 addresses, in that they can be routed, but not onto the Internet.  I have no problem routing IPv4 RFC1918 addresses properly.
            • JKnottJ Offline
              JKnott
              I set up the LAN interface as a gateway for the ULA address.  I can ping the interface ULA from my notebook, but pinging the desktop ULA displays "Time Exceeded: Hop limit" and traceroute6 shows the firewall repeatedly and not going beyond it.
              • DerelictD Offline
                Derelict LAYER 8 Netgate
                Just assign an interface address to the interface. It will be connected and therefore in the routing table. No gateways or static routes necessary. pfSense doesn't care if it is routable or ULA. It's just a subnet.
                Chattanooga, Tennessee, USA
                • JKnottJ Offline
                  JKnott
                  @Derelict:
                  The LAN interface has both global and ULA addresses on it.  Global addresses work fine.  How do I assign a 2nd address?  I created the subnet on the RA page and even created an alias on the Virtual IPs page.  Ifconfig shows the virtual IP and I can ping it from the pfSense computer, but not from the desktop computer, which has both global and ULA addresses.  The virtual address on the pfSense computer is fd48:1a37:2160::1 and the desktop has fd48:1a37:2160:0:61af:b555:ad10:3fd2
                  When I ping from pfSense to the desktop, this is what I see.
                  ping6 fd48:1a37:2160:0:61af:b555:ad10:3fd2
                  PING6(56=40+8+8 bytes) fd48:1a37:2160::1 –> fd48:1a37:2160:0:61af:b555:ad10:3fd2
                  There is no response from the desktop.  If I have a static route configured, traceroute keeps cycling through the pfSense computer.  If I don't have a static route configured, it tries to go out to the 'net.
                  Also, Wireshark does not show any pings, in either direction.  However, the RA contains "ICMPv6 Option (Prefix information : fd48:1a37:2160::1/128)" and "ICMPv6 Option (Prefix information : fd48:1a37:2160::/64)" , so the router ULA address is being advertised.
                  Either I'm missing something, or ULA routing isn't working properly.  As I mentioned, IPv4 RFC1918 addresses route properly.
                  The desktop system is running openSUSE 42.3.
                  • JKnottJ Offline
                    JKnott
                    Just to update, I have 3 interfaces as follows
                    LAN global and ULA
                    VLAN3 ULA only
                    LAN4 global only.
                    From the pfSense computer or a computer on LAN4, I cannot ping the ULA on the desktop on either LAN or VLAN3.  On the pfSense computer, I can ping it's own ULA on both LAN and VLAN3.
                    • JKnottJ Offline
                      JKnott
                      Assigning a virtual IP on the LAN interface caused it to lose the global address.  There's definitely something wrong with the way pfSense handles ULA.
                      • DerelictD Offline
                        IDK, man. I just did it and it worked fine.
                        DHCP WAN, Track Interface LAN, ULA IP Alias VIP /64 on LAN, Added ULA /64 as a subnet for RA on LAN, firewall rule passing all traffic from ULA::/64 on LAN, booted test VM:
                        pfSense LAN:
                        re0: flags=8843 <up,broadcast,running,simplex,multicast>metric 0 mtu 1500
                        options=80098 <vlan_mtu,vlan_hwtagging,vlan_hwcsum,linkstate>ether fe:e0:54:6e:79:49
                        hwaddr fe:e0:54:6e:79:49
                        inet 172.25.233.1 netmask 0xffffff00 broadcast 172.25.233.255
                        inet6 2001:dead:beef:fd01:fce0:54ff:fe6e:7949 prefixlen 64
                        inet6 fe80::1:1%re0 prefixlen 64 scopeid 0x1
                        inet6 fd08:1e26:8fea:525b::1 prefixlen 64
                        nd6 options=21 <performnud,auto_linklocal>media: Ethernet autoselect (100baseTX <full-duplex>)
                        status: active
                        Test host interface:
                        derelict@Host-B1:~$ ifconfig
                        eth0      Link encap:Ethernet  HWaddr 9a:b3:de:87:fa:4b
                                  inet addr:172.25.233.100  Bcast:172.25.233.255  Mask:255.255.255.0
                                  inet6 addr: fd08:1e26:8fea:525b:98b3:deff:fe87:fa4b/64 Scope:Global
                                  inet6 addr: fe80::98b3:deff:fe87:fa4b/64 Scope:Link
                                  inet6 addr: 2001:dead:beef:fd01:98b3:deff:fe87:fa4b/64 Scope:Global
                                  UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                                  RX packets:205 errors:0 dropped:0 overruns:0 frame:0
                                  TX packets:122 errors:0 dropped:0 overruns:0 carrier:0
                                  collisions:0 txqueuelen:1000
                                  RX bytes:34081 (34.0 KB)  TX bytes:15844 (15.8 KB)
                        To pfSense LAN VIP:
                        derelict@Host-B1:~$ ping6 -c 3 -I fd08:1e26:8fea:525b:98b3:deff:fe87:fa4b fd08:1e26:8fea:525b::1
                        PING fd08:1e26:8fea:525b::1(fd08:1e26:8fea:525b::1) from fd08:1e26:8fea:525b:98b3:deff:fe87:fa4b : 56 data bytes
                        64 bytes from fd08:1e26:8fea:525b::1: icmp_seq=1 ttl=64 time=0.518 ms
                        64 bytes from fd08:1e26:8fea:525b::1: icmp_seq=2 ttl=64 time=0.294 ms
                        64 bytes from fd08:1e26:8fea:525b::1: icmp_seq=3 ttl=64 time=0.684 ms
                        –- fd08:1e26:8fea:525b::1 ping statistics ---
                        3 packets transmitted, 3 received, 0% packet loss, time 1998ms
                        rtt min/avg/max/mdev = 0.294/0.498/0.684/0.161 ms
                        To the WAN address of upstream pfSense:
                        derelict@Host-B1:~$ ping6 -c 3 -I fd08:1e26:8fea:525b:98b3:deff:fe87:fa4b 2001:dead:beef:7fff::ed96:eec5
                        PING 2001:dead:beef:7fff::ed96:eec5(2001:dead:beef:7fff::ed96:eec5) from fd08:1e26:8fea:525b:98b3:deff:fe87:fa4b : 56 data bytes
                        64 bytes from 2001:dead:beef:7fff::ed96:eec5: icmp_seq=1 ttl=64 time=0.524 ms
                        64 bytes from 2001:dead:beef:7fff::ed96:eec5: icmp_seq=2 ttl=64 time=0.287 ms
                        64 bytes from 2001:dead:beef:7fff::ed96:eec5: icmp_seq=3 ttl=64 time=0.320 ms
                        –- 2001:dead:beef:7fff::ed96:eec5 ping statistics ---
                        3 packets transmitted, 3 received, 0% packet loss, time 2000ms
                        rtt min/avg/max/mdev = 0.287/0.377/0.524/0.104 ms
                        I don't have routing for that ULA from anything else.
                        Note this is a recent 2.4-RC since that's what my test environment is currently running.</full-duplex></performnud,auto_linklocal></vlan_mtu,vlan_hwtagging,vlan_hwcsum,linkstate></up,broadcast,running,simplex,multicast>
                        • DerelictD Offline
                          And with NPt to an unused /64 on pfSense WAN:
                          derelict@Host-B1:~$ ping6 -n -c 3 -I fd08:1e26:8fea:525b:98b3:deff:fe87:fa4b www.google.com
                          PING www.google.com(2607:f8b0:400e:c05::63) from fd08:1e26:8fea:525b:98b3:deff:fe87:fa4b : 56 data bytes
                          64 bytes from 2607:f8b0:400e:c05::63: icmp_seq=1 ttl=46 time=59.6 ms
                          64 bytes from 2607:f8b0:400e:c05::63: icmp_seq=2 ttl=46 time=83.8 ms
                          64 bytes from 2607:f8b0:400e:c05::63: icmp_seq=3 ttl=46 time=58.7 ms
                          –- www.google.com ping statistics ---
                          3 packets transmitted, 3 received, 0% packet loss, time 2003ms
                          rtt min/avg/max/mdev = 58.704/67.398/83.847/11.640 ms
                          • JKnottJ Offline
                            JKnott
                            I'll have to go through the stuff you provided, howerver I made some changes and did some more testing.  At the moment, the configuration is as follows:
                            LAN global & ULA
                            LAN4 ULA only
                            VLAN3 ULA only
                            The desktop computer has both LAN and VLAN3 configured and the notebook is on LAN4 only.
                            If I ping the laptop by forcing ping over VLAN3, it works.  However, when via LAN, no response.  Wireshark on the notebook shows both request and reply, but on the desktop, only the request.  From the pfSense computer, I can ping the notebook and the VLAN3 address of the desktop, but not the LAN address.  Wireshark does not show any ping requests from pfSense to the LAN interface  So, there is still something about the LAN interface that's causing problems.
                            I see you have a ULA address fd08:1e26:8fea:525b::1 on the LAN interface.  How did you put it there?  I do not have one.  I used a virtual IP last night, but this morning, the virtual IP was there, but the global address was gone.
                            The network ULA addresses are as follows:
                            LAN  fd48:1a37:2160:0::
                            VLAN3  fd48:1a37:2160:3::
                            LAN4  fd48:1a37:2160:4::
                            Netstat -r on pfSense shows:
                            fd48:1a37:2160:3:: link#8            U      bge0_vla
                            fd48:1a37:2160:3:: link#8            UHS        lo0
                            fd48:1a37:2160:4:: link#2            U          em0
                            fd48:1a37:2160:4:: link#2            UHS        lo0
                            Note there is no line for fd48:1a37:2160:0::.
                            There is also this on the WAN interface:
                            fd07:f798:3:16e::  link#3            U          re0
                            fd07:f798:3:4172:: link#3            U          re0
                            There are no other ULA addresses listed.  So, pfSense doesn't have a route to fd48:1a37:2160:0::.
                            • JKnottJ Offline
                              JKnott
                              I think I found it.  I had to set the VIP prefix to /64.  Also, curious that the pfSense graphical admin doesn't show the 2nd address on either the dashboard or interface status.  Netstat -r does though.
                                "I had to set the VIP prefix to /64"
                                what else would you have set it too?
                                • JKnottJ Offline
                                  JKnott
                                  The default is /128, so if you forget to change it…
                                  Now I can add gazillions of security cameras to that network!  ;)
                                  • JKnottJ Offline
                                    JKnott
                                    I just tried pinging ipv6.google.com from a computer with a ULA and I see the requests heading out of the WAN port.  I guess I should create a rule to block ULA addresses.
                                    • DerelictD Offline
                                      Yup. Just like RFC1918.
                                      • JKnottJ Offline
                                        JKnott
                                        I just created a floating rule to block fc::/7 in both directions, but the pings are still leaving the firewall.
                                        Screenshot_20170908_163212.png_thumb
                                        • DerelictD Offline
                                          Did you kill the existing states?
                                          Or at least stop and restart the ping?
                                          • DerelictD Offline
                                            You should also check quick there.
