    No initial connection - no lan connection (installation)
    3 Posts 2 Posters 570 Views
    • U Offline
      username89
      Hello
      I just installed pfSense-CE-2.3.4-RELEASE-4g-amd64-nanobsd on a msata 16GB SSD.
      With this command:```
      sudo dd if=pfSense-CE-2.3.4-RELEASE-4g-amd64-nanobsd.img of=/dev/disk3 bs=1m
      My apu2 with the ssd seems to boot fine. It makes some funny noise when it seems to be finsh with the boot-process.
      **I don't have a serial-wire.**  :(
      I thought I could connect with lan.
      The RJ45 LED is on. But I can't connect to 192.168.1.1\. There is also no DHCP-Lease for my client.
      --- 192.168.1.1 ping statistics ---
      3 packets transmitted, 0 packets received, 100.0% packet loss
      Any ideas what's the problem? Is the installation not possible without the serialport-connection?
      Thanks a lot and regards
      • NogBadTheBadN Offline
        NogBadTheBad
        Does the other network port work ?
        https://forum.pfsense.org/index.php?topic=112838.msg627902#msg627902
        Andy
        • U Offline
          username89
          well, now they do  :o
          Thank you very much  :-* ;)
          solved!
