    Vlan problem, despert NEED HELP
    27 Posts 5 Posters 1.9k Views
      njanja
      @johnpoz:
      What exactly is not working?
      "Have 2 nics. One WAN and one LAN
      WAN connected direct to internet"
      So your original switch drawing is no longer valid.
      What exactly do you want to happen with your vmkern and pfsense vswitch for your lan?  I have been running pfsense on esxi for years..  At a loss on what your trying to do with your vmkern?  And where exactly you want to connect to it from.. Are you trying to firewall your vmkern with your virtual pfsense?  That is not going to work, and if it did you would have a nightmare if pfsense vm didn't load, etc.
      your esxi host only has 2 nics right?  If so then yes use 1 for your wan, directly connect it to your modem.. so it goes like this
      internet - modem - esxi host nic – vswitch (wan) -- vnic wan pfsense
      Then your vmkern port group would be on same vswitch.. pfsense lan (untagged)  Then what do you want to do with vlans and pfsense and tagged traffic?
      Hello
      Thanks for your reply. The error was in rules and user Steve found the error and told me that my rule was set on ip4. That was the fault.
      Njanja
      • stephenw10S Online
        OK, glad you're running.
        However I expect those clients connected to VLAN30 to get an IP in the 10.10.100.X subnet. Unless you have changed the subnet in use there.
          njanja
          @stephenw10:
          Hello again
          Now it works. I connected the second swichen. It also works.
          Right now my network looks like this:
          internet -> esxi (pfsense) -> sw1 (vlan100 and vlan200) -> sw2 (vlan300).
          This solution works when I use 2 cable, one gets in, and one gets out.
          But in my apartment I do not have 2 cable, I only have one.
          I'm looking for this solution:
          internet -> sw1 -> sw2 -> esxi (pfsense)
          sw1 port 8 interent in
          sw1 port 7 to sw2 cable between swichs
          sw1 port 1 to pc (vlan100)
          sw2 port 8 internet to esxi (pfsense)
          sw2 port 7 to sw1 cable between swichar
          sw2 port 6 cable from pfsens to sw2
          sw2 port 1 to pc 8 (vlan100)
          • DerelictD Offline
            Derelict LAYER 8 Netgate
            tag all vlans (trunk) on the ports connecting sw1 and sw2.
            Chattanooga, Tennessee, USA
              njanja
              @Derelict:
              Hello
              Thanks for the reply.
              As I understand you, you want me to use trunk between swichs.
              Clients connected to Swichen on Ports 1 and 2, should I use the trunk on them too?
                Trunk ports carry the tagged VLANs between the switches or to the router.
                Ports connected to clients do not carry tagged traffic, they should not be 'trunk'.
                • DerelictD Offline
                  No. You need to understand VLANs.
                  Edge devices get untagged, access ports in almost all cases.
                  Connections to VLAN-aware devices like other switches, pfSense with tagged ports, Access Points, etc get tagged, "trunk" ports.
                  Chapter 2: https://books.google.com/books?id=dkDsJmnsejEC&pg=PA51&source=gbs_toc_r&cad=4
