    Multi-WAN, High Availability, policy routing. Failover breaks connections
    28 Posts 4 Posters 6.3k Views
      dayer
      Hi ZsZs,
      I've read your description with attention and I think it could be the same problem. Although I'll wait to Derelict point of view.
      I know this part is the key:
      I also saw in tcpdump, that when the ssh session freezes, the traffic leaves the firewall on wrong WAN interface with the other WAN interface's source IP address.
      However, according to the last Derelict suggestion, I must repeat the test with the simplest scenario.
      • Z Offline
        ZsZs
        Hi again,
        I've just spotted that 2.3.5 is out, so I've done a fresh install again and tried to simplify the setup as much as possible to reproduce this issue.
        I omitted a few irrelevant steps (DNS config, setting up GW groups, etc) from the procedure described in my previous post which resulted this:
        • the two VMs running on the same ESXi 6.0U3 host (for testing purpose)
        • set up WAN1 and WAN2 in different subnet:
            - WAN1 public /26 (default GW)
            - WAN2 internal /24 (behind a cable modem)
        • set up WAN1 and WAN2 with following monitoring IP addresses:
            - WAN1: 8.8.8.8
            - WAN2: 208.67.220.220
        • Set up HA for syncing state and configs with relevant FW rules)
        • Set up CARP IPs (WAN1-VIP, WAN2-VIP, LAN-VIP) with appropriate netmask
        • change Outbound NAT Mode to Manual
            - remove auto-created SYNC interface related rules
            - change NAT address to WAN1-VIP on rules with interface WAN1
            - change NAT address to WAN2-VIP on rules with interface WAN2
            - the actual outbound NAT rules are (description removed)
        Intf  Source           SPrt Dst DPrt NAT Address    NATPrt  Static Port
        WAN1  127.0.0.0/8      *    *   500  WAN1 addres    *       KeepSrcStatic
        WAN1  127.0.0.0/8      *    *   *    WAN1 addres    *       RandomizeSrcPort
        WAN2  127.0.0.0/8      *    *   500  WAN2 address   *       KeepSrcStatic
        WAN2  127.0.0.0/8      *    *   *    WAN2 address   *       RandomizeSrcPort
        WAN1  192.168.25.0/24  *    *   500  WAN1 address   *       KeepSrcStatic
        WAN1  192.168.25.0/24  *    *   *    213.XX.YY.8    *       RandomizeSrcPort
        WAN2  192.168.25.0/24  *    *   500  WAN2 address   *       KeepSrcStatic
        WAN2  192.168.25.0/24  *    *   *    192.168.0.10   *       RandomizeSrcPort
        • create FW rule in LAN with routing ssh traffic via WAN2:
        Protocol    Src Prt Dst Prt Gateway     Queue
        IPv4 TCP    *   *   *   22  WAN2        none
        The result is the same as described in my previous post.
        defGW   policy route   SSH session after fail-over
        WAN1    disabled       OK
        WAN1    GW:WAN1GW      OK
        WAN1    GW:WAN2GW      Freezes
        WAN2    disabled       OK
        WAN2    GW:WAN1GW      Freezes
        WAN2    GW:WAN2GW      OK
        I've tested with opening an ssh session to an external host.
        In case the FW rule directs the outgoing LAN ssh traffic via a gateway other than the default gateway, then after the HA fails over to the secondary node the open ssh session freezes.
        I can open a new ssh session via the new master (secondary node), but moving the VIP back to the primary node this newly opened ssh session freezes and the previously opened session starts responding again.
        I still see in tcpdump, that when the ssh session freezes, the traffic leaves the firewall on default GW's WAN interface with the other WAN interface's VIP address.
        Actually I haven't found much related posts where HA, multi-WAN and policy based routing is involved.
        We might miss something obvious, but actually I haven't found much related posts/tutorials/howtos where HA, multi-WAN and policy based routing is involved.
        edit: remove duplicated part
        • DerelictD Offline
          Derelict LAYER 8 Netgate
          What is in front of that? If stateful, it will need a new state too.
          Chattanooga, Tennessee, USA
          • Z Offline
            ZsZs
            Hi Derelict,
            Tanks for your reply, but I am afraid I do not understand your question.
            192.168.25.0/24 is my LAN subnet.
            I've opened the ssh session from this subnet to an external host.
            The quoted NAT rule supposed to do the outbound NAT on WAN2 arriving from my LAN.
            I'm attaching the actual config.
            HTH,
            Zsolt
            config-pfs1.hq.example.com-20171113205101.xml.gz
            • DerelictD Offline
              Outbound NAT has nothing to do with routing traffic.
              It determines what NAT happens when traffic is already routed that way.
              Every time I test this it works fine. Not sure what you guys are doing wrong.
              I was probably misreading your problem description.
              I have already shown how to see the states, the sync of the same, and the fact that traffic goes over the synced state after failover.
              Anything that doesn't do that properly is likely an issue at layer 2 having to do with the CARP MAC address changing switch ports.
              This stuff works and works well.
              • Z Offline
                ZsZs
                Ok, let me try to describe it with the actual states after each test step.
                I have a fresh CARP-HA setup with Dual-WAN connection.
                WAN1-CARP: 213.ss.tt.8
                WAN2-CARP: 192.168.0.10
                WANs are connected to different ISPs.
                Outbound NAT on both WAN interfaces: NAT with CARP IP instead of interface ip.
                External host with sshd: 212.xx.yy.193
                Test case 1
                **- default GW: WAN1
                • no policy routing is in place**
                • initial CARP master: primary node
                Step 1
                Open an ssh connection from a PC on LAN to an external host.
                states (filter: external host's ip, interfaces: all)
                primary```
                Intf Prot Src (Orig Src) -> Dst (Orig Dest)                              State                    Packets  Bytes
                LAN  tcp  192.168.25.199:45762 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED  16 / 20  4 KiB / 4 KiB
                WAN1 tcp  213.ss.tt.8:55665 (192.168.25.199:45762) -> 212.xx.yy.193:22    ESTABLISHED:ESTABLISHED  16 / 20  4 KiB / 4 KiB
                secondary```
                LAN  tcp  192.168.25.199:45762 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED   0 / 0     0 B / 0 B
                WAN1 tcp  213.ss.tt.8:55665 (192.168.25.199:45762) -> 212.xx.yy.193:22    ESTABLISHED:ESTABLISHED   0 / 0     0 B / 0 B
                Step 2
                Enter persistent CARP maintenance mode (new master: secondary node):
                states (filter: external host's ip, interfaces: all) packet counter increasing on secondary
                primary```
                LAN  tcp  192.168.25.199:45762 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED  31 / 32  5 KiB / 5 KiB
                WAN1 tcp  213.ss.tt.8:55665 (192.168.25.199:45762) -> 212.xx.yy.193:22    ESTABLISHED:ESTABLISHED  31 / 32  5 KiB / 5 KiB
                secondary```
                LAN  tcp  192.168.25.199:45762 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED   90 / 65   6 KiB / 8 KiB
                WAN1 tcp  213.ss.tt.8:55665 (192.168.25.199:45762) -> 212.xx.yy.193:22    ESTABLISHED:ESTABLISHED   90 / 65   6 KiB / 8 KiB
                Ssh connection remains responsive.
                Step 3
                Exit persistent CARP maintenance mode (new master: primary node):
                states (filter: external host's ip, interfaces: all) packet counter increasing on primary
                primary```
                LAN  tcp  192.168.25.199:45762 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED  51 / 53  6 KiB / 9 KiB
                WAN1 tcp  213.ss.tt.8:55665 (192.168.25.199:45762) -> 212.xx.yy.193:22    ESTABLISHED:ESTABLISHED  51 / 53  6 KiB / 9 KiB
                secondary```
                Ssh connection remains responsive. All good, so far
                Test case 2
                • Create a LAN FW rule to policy route ssh traffic via WAN2.**
                IPv4 TCP    *   *   *   22  WAN2GW      none
                Step 1
                primary```
                LAN  tcp  192.168.25.199:45774 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED  19 / 23  4 KiB / 4 KiB
                WAN2 tcp  192.168.0.10:42115 (192.168.25.199:45774) -> 212.xx.yy.193:22  ESTABLISHED:ESTABLISHED  19 / 23  4 KiB / 4 KiB
                secondary```
                LAN  tcp  192.168.25.199:45774 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED   0 / 0    0 B / 0 B
                WAN2 tcp  192.168.0.10:42115 (192.168.25.199:45774) -> 212.xx.yy.193:22   ESTABLISHED:ESTABLISHED   0 / 0    0 B / 0 B
                Step 2
                states (filter: external host's ip, interfaces: all) packet counter increasing on secondary very slowly (on tcp retransmission only?)
                primary```
                LAN  tcp  192.168.25.199:45774 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED  67 / 71  7 KiB / 12 KiB
                WAN2 tcp  192.168.0.10:42115 (192.168.25.199:45774) -> 212.xx.yy.193:22  ESTABLISHED:ESTABLISHED  67 / 71  7 KiB / 12 KiB
                secondary```
                LAN  tcp  192.168.25.199:45774 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED   8 / 8    500 B / 1 KiB
                WAN2 tcp  192.168.0.10:42115 (192.168.25.199:45774) -> 212.xx.yy.193:22   ESTABLISHED:ESTABLISHED   8 / 8    500 B / 1 KiB
                Ssh connection freezes.
                Ssh traffic arriving to WAN2 correctly:
                11:27:42.463760 IP 212.xx.yy.193.22 > 192.168.0.10.42115: Flags [P.], seq 8300:8408, ack 3422, win 312, options [nop,nop,TS val 4076858258 ecr 2258791998], length 108
                But the reply is leaving the firewall on WRONG interface (default GW's: WAN1) instead of WAN2 and on top of this with WRONG SRC IP address. (WAN2-CARP instead of WAN1-CARP)
                11:27:42.464087 IP 192.168.0.10.42115 > 212.xx.yy.193.22: Flags [.], ack 1, win 342, options [nop,nop,TS val 2258792365 ecr 4076858258,nop,nop,sack 1 {4294967189:1}], length 0
                I see two problems here:
                1. routing is wrong: the ssh traffic should be treated according to the policy routing.
                2. the outbound NAT is also wrong because the traffic leaves on WAN1 (for whatever reason) so WAN1's outbound NAT rule should be applied as you said: "It determines what NAT happens when traffic is already routed that way."
                If the routing were ok, that would solve the problem, but the wrong outbound NAT is also an issue and might help to determine where the wrong routing/ignoring policy routing originates.
                Step 3
                primary```
                LAN  tcp  192.168.25.199:45774 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED  75 / 80  7 KiB / 19 KiB
                WAN2 tcp  192.168.0.10:42115 (192.168.25.199:45774) -> 212.xx.yy.193:22  ESTABLISHED:ESTABLISHED  75 / 80  7 KiB / 19 KiB
                secondary```
                LAN  tcp  192.168.25.199:45774 -> 212.xx.yy.193:22                        ESTABLISHED:ESTABLISHED   9 / 9    564 B / 1 KiB
                WAN2 tcp  192.168.0.10:42115 (192.168.25.199:45774) -> 212.xx.yy.193:22   ESTABLISHED:ESTABLISHED   9 / 9    564 B / 1 KiB
                Ssh connection works again.
                My conclusions:
                It seems that the new master node does not route the failed over traffic according to the policy routing (defined in LAN FW rule), but according to the routing table.
                I can open a new ssh session vie the new master node and this will be routed according to the policy routing (defined in LAN FW rule), however it will freeze once this new master becomed backup again.
                • DerelictD Offline
                  Are you 100% certain all of your interfaces match exactly on both nodes? Both nodes should match exactly in Status > Interfaces the interface name, the wan/lan/optX name, and the physical interface name.
                  • Z Offline
                    ZsZs
                    Thank you for your reply, I really appreciate.
                    I've double/triple checked and the pfsense/os interface names are following on both nodes:
                    WAN: vmx0 (WAN1)
                    LAN: vmx2 (LAN)
                    OPT1: vmx1 (WAN2)
                    OPT2: vmx3 (SYNC)
                    OPT3: vmx4 (DMZ) not used yet
                    edit: LAN and WAN2 description swapped.
                    • C chrullrich referenced this topic on
