    Need help getting pfsense to work properly
    31 Posts 4 Posters 2.1k Views
      Guest
      Just got a bootloop when i tryed to reboot the pfsense… So back to 2.3 but this time i'll try to use the 32bit version.
        Guest
        Okay, same behaviour with 32bit version… download speeds locked at 2mb/s and cpu usage locked at 3%...
        I think the only thing left is to sell the hardware...
        • GertjanG Online
          Gertjan
          Don't know why YOU are locked on the fact that the CPU only uses 3 %.
          Look at mine : https://www.test-domaine.fr/munin/brit-hotel-fumel.net/pfsense.brit-hotel-fumel.net/processes.html - the green part (approx. 3 %) is the same and everything works fine - ISP gives me about 25 Mbit, and that comes through.
          Don't tell us you have problems, tell about the problem, describe it. Copy past settings, screen, your findings.
          Don't tell us that you can't find your IP "Internet", that's like saying that you driving a car, but are not aware that some where i the same car an engin must be running …
          Check out other forum threads about how to question and ask so feedback can be given that can help you.
          Btw : pfSense 2.3.4 is not buggy, very stable and work great for years now for me
            Chrismallia
            Dude it has something to do with your Hardware or setup, look at my results pfsense 2.3.4
            speedtest{pfsense.PNG_thumb
              Guest
              I tried different NICs, even Intel ones and always the same results: download speed locked at 2mb/s and upload speed is random but between 1.5 and 3.5mb/s.
              While on my 3usd cheap router i get 10.5mb/s download and 5mb/s upload easyly…
              No idea what the problem is...
                Guest
                Is that possible that i have to change some buffer sizes or something? Because RAM usage never exceed 7% and CPU usage is hardlocked at 3%.
                The HDD is 80Gb if i remember correctly…
                Maybe i should install windows and test it there too... hmm... i remember using this PC on windows 8.1 64bit and i got correct speeds... so definitelly pfsense issue...
                  Chrismallia
                  @speter2:
                  " I have a cheap 2usd router laying around and using that i get 75mbps download speed while on pfsense it is hardlocked at 20mbp"
                  Am I missing something? speeds have changed since your first post.
                  You might have some driveR problems, just cos windows plays nice does not mean BSD will, try a different machine
                    Guest
                    I tried… pfSense only runs on this machine, it fails to boot or hangs at bootloader on all 4 other machines i tried...
                      Guest
                      Update: Tried in virtual machine; and i got the same results… donload speed capped at 2mb/s around 20-250mbps/s it deppends... I am clueless...
                      • johnpozJ Online
                        Dude this has ZERO to do with pfsense.. You stated your connection is PPPoE right.. Did you contact your ISP about this when you change the device doing the pppoe connection..
                        If your cpu was maxing out or something.. Then ok you might say pfsense can't handle the speed, etc.
                        When you connect these cheap routers, your setting them up for pppoe - or your just doing dhcp on them?
