High latency and packet loss HELP!! [not solved]
39 Posts 5 Posters 5.0k Views
    tripplex
    RIG:
    IBM thinkcenter MT-M 6087
    core 2 duo  E4400 @ 2.00GHz
    3GB ram DDR2
    80GB HDD
    HP NC364T PCI Express Quad Port Nic
    and a Onboard intel Nic
    Packages Installed:
    freeRadius3
    pfsense fresh install and reconfigured.
    Whats causing this, I just can't figure it out. I am wondering if its the HP NC364T PCI Express Quad Port Nic, the pcie slot being too slow or ISP Buffer bloat?
    ![Screenshot-2017-10-1 Anonymous Anonymous dev - Status Dashboard.png](/public/imported_attachments/1/Screenshot-2017-10-1 Anonymous Anonymous dev - Status Dashboard.png)
    ![Screenshot-2017-10-1 Anonymous Anonymous dev - Status Dashboard.png_thumb](/public/imported_attachments/1/Screenshot-2017-10-1 Anonymous Anonymous dev - Status Dashboard.png_thumb)
      Derelict LAYER 8 Netgate
      What is going on on your network at the time?
      Chattanooga, Tennessee, USA
        tripplex
        I have load balance setup amongst the 3 wan, I did a speed test and it reported high latency. I just don't know whats wrong. I just finsh reinstalling pfsense and reconfigured captive portal and freeRadius3. also configured loadbalancing.
          With that description nobody else will either.
          All of your WANs are private addresses. What is in front of them?
            tripplex
            the ISP Modem which are arris tg862 modems  they have NAT enabled so that's the reason for the private ip addresses. I also tried setting the modems in bridge mode which changed nothing, problem still occurs. Thought it was pfsense causing the issues so a reinstalled it but to my surprise it didn't resolve anything.
              Why do they have NAT enabled?
              What does it do when you don't load balance and just use one WAN?
              What kind of speeds are you expecting on each WAN?
              Does it do that on upload or upload and download?
              It is nearly impossible to apply download shaping in that situation because it is impossible for the LAN interface (where download shaping must occur) to know which WAN is passing traffic/saturated and which one is not.
                tripplex
                Why do they have NAT enabled?  Tried it in bridge mode didn't make any difference problem still occurs.
                What does it do when you don't load balance and just use one WAN? The problem still occurs.
                What kind of speeds are you expecting on each WAN? 20mbps connection on all
                Does it do that on upload or upload and download? download only
                I can increase the latency threshold in the gateway setting to avoid it have latency issues but i feel it isn't accurate to do that to the wan interfaces.
                  I can't think of any way to shape that. Sorry.
                  All I can say is if it is the same in bridge mode and in NAT mode, I would choose bridge mode. Won't help - just sayin'.
                  Maybe go to 2.4 and put limiters on each WAN. (You have to go to 2.4 because there is a NAT+Limiter bug that isn't fixed until then).
                    "20mbps connection on all"
                    So these are the same ISP just 3 different connections via cable?  So your trying to understand when you PEG your pipe via a speed test why dpinger reports high latency to and from google dns since that is what you have for your monitoring IP and whatever that 65.183 address is..
                    If you Fill your pipe - then yes the pings used by dpinger are going to show latency and loss.. To get around that you would have to shape so you do not saturate your pipe..  And I am curious if this is the same ISP and cable you would be sharing the connection, etc.
                      tripplex
                      @johnpoz:
                      How can i shape it in 2.3.4_p1?
                        With three WANs into one LAN I don't think you can.
                        Not downloads anyway.
                        No decent ISP would buffer like that sending to you.
                          I don't use 2.3.4 any more I am on 2.4, according to Derelict there is a bug in the nat+limiter.. So go to 2.4  its going to be Release on monday or something I think ;)
                          So for example here is my gateway while running speed test..  Just using the fq_codel that is available in 2.4
                          So you notice the ping times do go up for my cable connection wan_dhcp, and the tunnel from HE response goes up as well - this is expected since its going over the same wan.. But do not see any loss and latency is only slightly increased..
                          speedtest.png_thumb
                            https://redmine.pfsense.org/issues/4326
                            That generally means you can use limiters on LAN but not WAN, because there is usually NAT on WAN, and often not on LAN.
                              tripplex
                              @johnpoz:
                              What are the settings for fq_codel and where should i set it? can you send screen shot and details how to accomplish this. I am going to update to 2.4 from 2.3.4_p1 is that ok?
                                see the fq_codel thread… All the info you need is there..
                                https://forum.pfsense.org/index.php?topic=126637.0
                                But sure can send you screenshots if you want.  Also just use the cron job to put the info back in on upgrade vs the file edit mode..  See the thread all info needed is in there.
                                  tripplex
                                  can i just update to 2.4 from 2.3.4_p1? Will it cause any issues?
                                  getting this while updating to 2.4.0:
                                  pkg: cached package pear-Net_Growl-2.7.0: size mismatch, cannot continue
                                  Failed
                                    Normal advice for packages when updating is to remove them, update then put your packages back..
                                    What package is using growl?  I just looked through the package manager and do not see that listed in either the packages I have installed or available packages.
                                    Well I do see it in pfsense..
                                    [2.4.0-RC][root@pfsense.local.lan]/root: pkg info pear-Net_Growl-2.7.0
                                    Version        : 2.7.0
                                    Installed on  : Fri Mar 31 07:43:42 2017 CDT
                                    Origin        : net/pear-Net_Growl
                                    Architecture  : FreeBSD:11:amd64
                                    Prefix        : /usr/local
                                    Categories    : net pear
                                    Licenses      : BSD2CLAUSE
                                    Maintainer    : garga@FreeBSD.org
                                    WWW            : https://pear.php.net/package/Net_Growl/
                                    Comment        : Send notifications to Growl
                                    Annotations    :
                                            repo_type      : binary
                                            repository    : pfSense
                                    Flat size      : 1.03MiB
                                    Description    :
                                    Growl is a MACOSX application that listen to notifications sent by
                                    applications and displays them on the desktop using different display
                                    styles. Net_Growl offers the possibility to send notifications to Growl
                                    from your PHP application through network communication using UDP.
                                    WWW: https://pear.php.net/package/Net_Growl/
                                      Codel won't do any good if the buffering is in the ISP network, which it must be because pfSense won't buffer bloat like that without significant effort.
                                      There is no way to shape on pfSense LAN because he is trying to load balance 3 20Mbit connections into 60Mbit and there is no way for the shaper to know which WAN is saturated when sending out LAN.
                                      He needs to limit downloads on each WAN interface to something that will reduce the buffer bloat in his crappy crappy ISP network.
                                      The only way I can think of to do that on each WAN independently is a limiter on each WAN. That requires 2.4.
                                      It is unknown if 2.4 will introduce something that doesn't work for you. Probably not. 2.4.0-RELEASE should be real soon now.
                                      If you have a 2.3.4_1 installer ready and a current backup you can get back to where you are in about 10 minutes.
                                        @tripplex:
                                        Failed
                                        What, exactly, did you do there to initiate that upgrade?
                                          Yeah I fail to understand such a odd ball setup?  If you want 60mbps - why not just get a pipe that big?  So you have 3 cable providers in your area but nothing fatter than 20mbps?
                                          I just ordered 500/50 to be installed on wed! ;)  Big jump from my 75/10 connection and cheaper too.  Sad part is my pfsense VM can not route that that speed, so until I update my vm host or pull trigger on sg3100.. Which wife would kill me on cost of either option right at the moment… So I had to order a unifi usg :( cheapest option that I could find that could handle the speed.. But looks like openvpn and ipv6 tunnels going to be a PITA vs the easy clickity clickity of pfsense..  And didn't tell her about that cost, just that needed new modem to handle the new speed..  So prob in for some shit when she sees the amazon bill ;) hehehehe
                                          20 out of 39
                                            consent.not_received
