    I need help here. I am hitting the wall. Please help a noob.
    45 Posts 5 Posters 10.0k Views 1 Watching
      kejianshi
      Swatting flies with cannons?
      • F Offline
        Finger79
        @wayne622:
        I have a question because I have the same dilemma. If I am using 3 OpenVPN connections for my Outgoing DNS Resolver settings I would select all 3 for the Outgoing Interfaces.  But, when Unbound is doing the resolving will it send a query out to all 3 Interfaces or only 1?
        I also have a Gateway Group that is setup for fail-over purposes for the OpenVPN not sure if that matters as to whether or not Unbound will send a query to all interfaces or just the one that traffic is suppose to be going out at that time.
        Unbound sends DNS queries out all interfaces.  You can verify this from a DNS Leak tester such as this one:  https://www.dnsleaktest.com/ and click on "Extended Test."  You'll see the IP addresses for all 3 of your OpenVPN connections.
        • F Offline
          Finger79
          @kejianshi:
          Yes - It is very odd that netflix would work but not amazon.  Its probably a simple fix.  We can see after you post your final configuration.
          This could be a DNS issue.  You might want to find out if your VPN provider has their own dedicated reliable DNS IP and use that.
          The problem I have with 8.8.8.8 and 8.8.4.4 is those can connect you to many different servers depending on your location.
          In my laptop off the VPN from Manila when I ping 8.8.8.8, its 30ms
          When in my vpn I use my remote pfsense LAN IP as my DNS server IP.  When I ping that IP, it shows about 250ms.  Far away as it should be.
          When I ping 8.8.8.8 in the vpn, again over 250ms.  So, it is being tunneled properly.
          We might want to do that test with you to be sure that the DNS servers you are connecting to are physically in the USA and not close by.
          Could be something else though.  Not sure.  Its strange.
          He's using unbound for DNS resolution though.  The Google 8.8.8.8/8.8.4.4 settings are only used by the pfSense box if the VPN tunnel goes down.  No LAN DNS queries should be forwarded to Google DNS.
            kejianshi
            Why should netflix work and amazon not?  That is fairly backwards
            • F Offline
              Finger79
              @kejianshi:
              That's never made sense to me.  All else being equal, why would Amazon work when using the Asus router for OpenVPN but Amazon doesn't work when using pfSense for OpenVPN?  So weird.  lovan6 says the configurations are exactly the same, which means we should expect the same results.  shrug
