    WLAN - LAN bridge problem
    Scheduled Pinned Locked Moved 1.2.1-RC Snapshot Feedback and Problems-RETIRED
    4 Posts 3 Posters 7.7k Views
      ChillyWilly
      When I bridge my WLAN to my LAN, clients can connect fine, but only for a few days. After that my clients can't connect and can't get past "validating authentication".
        techie_g33k
        I am also having problems with 1.2.1-RC2 and 1.2.1-RC4 in relation to WLAN - LAN bridging.  If my wireless client has never connected it will connect, but can't route correctly (will explain further down).  If it has connected before and then I try to connect it again (example is my work laptop I bring home on the weekends and some weeknights) it will never get an IP address.
        If a devices on my WLAN gets an IP address then it can not resolve any DNS because when I ping my DNS server (which is my Default Gateway also) it tries to route the ping out through my Default Gateway as if it was pinging an IP that was on the internet vs. inside my network.
        All my LAN clients work just fine.  If they ping the DNS IP it pings correctly; ie inside the network.
        I have worked on this with my work laptop, my friends laptop and my Wii which all connect via WLAN and they all have the exact same problem.  I didn't notice this occurring until I upgraded to 1.2.1-RC2 and have since tried RC4 hoping it would be fixed, but it isn't.
        Deja Vu
        Logan Rogers-Follis
          peter.riche
          look at that topic http://forum.pfsense.org/index.php/topic,12336.0.html
            techie_g33k
            Thanks!  For now I have just downgraded back to 1.2 RELEASE and will upgrade again when this problem has been fixed.
            Deja Vu
            Logan Rogers-Follis
