• This board now retired
    Pinned Locked
    5k Views
  • MOVED: fw reboots 1.2.3
    Locked
    97k Views
  • SW RAID-1, gmirror, missing files …
    Locked
    10k Views
    Should be fixed in next snapshot.
    25k Views
    It's not a bug, we just don't automatically allow DHCP traffic over bridges anymore. You have to add rules to pass that traffic just as you do with any other kind of traffic. Auto added rules are bad.  And this auto added rule wasn't even intended to allow DHCP traffic over bridges, that was just a consequence. Allowing that traffic was a bug, this is a bug fix that you now have to add that rule.
  • How can I be the only one with a broken RC2?
    Locked
    17
    20k Views
    It's very, very unlikely there was a driver regression between September and December, almost nothing changed in FreeBSD 7.0 between then. It's also highly unlikely any changes in the pfSense code base would have caused anything like that, since nothing at all related to Ethernet interface code has changed in a long time, longer ago than September. Can you reliably replicate this being resolved going back to an earlier release, then breaking going back to 1.2.1 release?  If so, what date is the one that works?  Given the lack of changes in any related areas, I doubt if that's truly the case. If so, I have a bunch of 1.2.1 snapshots that I can make available to help narrow down further.
  • Wlan (opt1) drops connection and needs reboot to be restored
    Locked
    7k Views
    W
    What wireless NIC are you using? The Atheros based wireless PCI NIC I'm using as my 'production' wireless access point gives service over many days without requiring a reboot. On the other hand, a USB wireless NIC I played with only a little bit (rum driver) doesn't seem to sustain connections very long but I've not seriously investigated that yet.
  • Pfsense under MS Hyper-V - how to apply a kernel patch
    Locked
    7k Views
  • Please add feature (Gateway) like as V.2.0
    Locked
    6k Views
    dotdashD
    1.2.1 is a bugfix release. No new features. If you need the new features, use 2.0 and deal with the fact that it may not be stable.
  • Hardrive stuck in PIO
    Locked
    6k Views
    Set hw.ata.ata_dma=0 for compac flash. Refer to http://forum.pfsense.org/index.php?topic=6840.msg69524 http://devwiki.pfsense.org/BootOptions Disable DMA for IDE drives
  • Atheros wireless card issue
    Locked
    11k Views
    @n1ko: And it isnt possible to downgrade to the previous driver (from the 6.3) ? No. @n1ko: Is this a common bug in the freebsd or somekind of pfsense specific bug? Also happens with my Nokia E90 FreeBSD issue.  Install a 7.0 FreeBSD iso and report the problem to freebsd-mobile@
  • Vlans bug testing…
    Locked
    5k Views
    E
    fixed but i still have bandwith problems.
  • 1.2.1-RC ALL versions - /lib/libedit.so.6: unsupported version error
    Locked
    7k Views
    Try a different CDRom drive. And if you want to reply that you already tried a different one, well try yet another different cdrom drive.
  • FTP Problems
    Locked
    7k Views
    vsftp
  • WLAN - LAN bridge problem
    Locked
    8k Views
    Thanks!  For now I have just downgraded back to 1.2 RELEASE and will upgrade again when this problem has been fixed.
  • Can't load 'kernel' 1.2.1-RC4
    Locked
    5k Views
  • Generating RRD graphs … ERROR: Not enough arguments
    Locked
    11k Views
    W
    Any advance on this issue? Its still happening in 1.2.1-RC4.
  • Create SSL Certificate – pfsense embedded
    Locked
    8k Views
  • [Dell R200] acd0 timeout, installation impossible
    Locked
    16k Views
    With the help of Billm I solved the connection problems by turning off RIP. The missing console is still gone.. but I can live with that..
  • 1.2.1 RC Proxy ARP Bug, Loop
    Locked
    5k Views
    Solved thanks to Billm. RIP causing the problem.
  • IGMP make lots of noice, can it be killed ;)
    Locked
    7k Views
    I created a rule that blocks the traffic but doesn't log it.. that simple…
