    Connecting to a cisco device using serial console cable from pfsense
    8 Posts 5 Posters 3.1k Views
      Snailkhan
      hi
      I have installed pfsense on commoditiy grade pc for my home lab and it has a serial port. nowadays all new laptps and pads etc dont have this port.
      is there any possibility to establish a console connection with the switch if i connect the cable between the switch and the pfsesense serial port ?
      i couldnt find an obvious package to achieve above.
      dmesg | grep "uart"
      uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
      uart0: console (115200,n,8,1)
      • JKnottJ Offline
        JKnott
        You'd need to install some terminal app on pfSense.  I use Minicom on Linux.  However, an alternative may be to buy a USB serial port adapter.  I bought one years ago and it works fine with Linux & Windows.  Then again, you can also use ssh to access pfSense from another computer.  It does everything you can do with a serial port.
        UniFi AC-Lite access point
          I would think you should just be able to use the cu command, I just checked and pfsense has it available calling out the specific port and rate you want to use, etc.
            Snailkhan
            @johnpoz:
            Thanks for the super quick response.
            i red at this site
            https://superuser.com/questions/476580/how-to-connect-to-cisco-w3550-with-freebsd
            that command "cu -l /dev/cuau0 -s 9600" can be used to connect to cisco from freebsd . if i run it form my pfsense i get below error.
            /dev/cuau0: Device busy
            link down
            I am doing this conoluted thing as my switch blown and the only serial to usb converter at hand is not working and no pc with serial atm with me. i am locked out.  above if work is a good band aid.
            the speed is set correctly.
            • DerelictD Offline
              Derelict LAYER 8 Netgate
              The only Cisco device I have with USB console is a 2901 Router.
              It enumerates as /dev/cuaU0 and I can cu to that but it doesn't respond at -s 9600.
              I can cu to the same router just fine from a mac on /dev/cu.usbmodem141
              Not sure what's up with that.
              The same workflow works just fine from pfSense/FreeBSD to another ADI unit: cu -l /dev/cuaU0 -s 115200.
              Chattanooga, Tennessee, USA
              • JKnottJ Offline
                JKnott
                Some Cisco gear has a built in USB converter.  You connect to it with a mini USB cable.  I've never tried it, as I always had a USB serial port adapter.  If it has one, it should work like any other USB serial port.
                • GrimsonG Offline
                  Grimson Banned
                  Did you turn on the serial console in pfSense? In that case the port is already in use.
                  • DerelictD Offline
                    That is cuau0 not cuaU0 which is why he was seeing that on cuau0.
                    ls -l /dev/cu*
                    connect the USB console.
                    ls -l /dev/cu*
                    The connected console will be the new devices.
