    Problem with DHCP and a Cisco nexus 5020 10GB siwtch Not gettings ip addresses.
    31 Posts 3 Posters 2.1k Views 1 Watching
      redbaron28
      @Derelict:
      Please post a current screenshot of Interfaces > Assignments
      20180212_104550.jpg_thumb
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        Please post the switch port configuration for the port connected to cxgb0.
        Chattanooga, Tennessee, USA
          redbaron28
          @Derelict:
          interface Ethernet1/40
            switchport mode trunk
            switchport trunk allowed vlan 1-10
          • DerelictD Offline
            OK and a DHCP server is configured on the OPT1 interface in pfSense? Can you post that?
              redbaron28
              @Derelict:
              20180212_144234.jpg_thumb
              • DerelictD Offline
                OK then something connected to an access port on VLAN 10 on the switch should get an IP address.
                If not you have to figure out why not.
                I have found looking at the mac address table on the switch for that VLAN is a good place to start.
                You could also send the output of these commands entered into Diagnostics > Command Prompt (or run from the shell)
                ifconfig cxgb0
                ifconfig cxgb0.10
                  redbaron28
                  That's the funny thing. I don't a single ip address to the switch.
                  There are those commands ran.
                  @Derelict:
                  ifconfig cxgb0
                  ifconfig cxgb0.10
                  20180212_151441.jpg_thumb
                  20180212_151431.jpg_thumb
                  • DerelictD Offline
                    That looks fine.
                    You need to look closer at layer 2.
                    What mac addresses are on VLAN 10?
                    Probably something similar to show mac-address-table
                      redbaron28
                      @Derelict:
                      That looks fine.
                      Vlan 2 is vlan 10 same config. I tried to redo it again.
                      20180212_163550.jpg_thumb
                      • DerelictD Offline
                        I am pretty limited to what I can do after this. Everything looks fine on the pfSense side.
                        Maybe try to ping something on the 192.168.2.0/24 network from Diagnostics > Ping. That should put the pfSense MAC address in the switch's table. If not you need to figure out why not.
                        That switch certainly supports mirroring. Mirror that port to something else and wireshark it.
                        You are fortunately/unfortunately dealing with a 10G SFP+ port or I'd suggest putting a laptop interface on vlan 10 and plugging in directly.
                        Assign OPT1 to a gig-e port and try that?
                          redbaron28
                          @Derelict:
                          After all your help i'm just stuck. Right now I'm returning my T320 card and buying a T520 10gb card and see if that was may problem. I'm have a really good feeling it it.
                          Will post when i have tested with the new card!
                          Thanks all for your help so far!
