    SOLUTION: apcupsd to Minisys (ProtectLI) and APC Smart Serial Interface
    1 Posts 1 Posters 967 Views
    • SammyWooS Offline
      SammyWoo
      These are the things to do to configure apcupsd to a legacy APC UPS using a 940-0024C Smart Serial Cable,
      to a MiniSys (ProtectLi) computer with a RJ45 COM port.
      1. Must install pFsense VGA, single COM port will be dedicated to UPS.
      2. Minisys BIOS = Disable COM redirection. In Addition I set mine for 2400,n,8,1 or whatever speed ur UPS is currently set.
      3. Install apcupsd pkg and configure with params below.
      4. Build and use cable as shown below.
      /usr/local/etc/apcupsd/apcupsd.conf
      This Doc created 3/14/2018. pFsense 2.4.2. FreeBSD 11.1.
      Name your UPS
      UPSNAME YOUR_UPS_NAME
      Legacy APC serial port
      UPSCABLE 940-0024C
      Smart Signalling
      UPSTYPE apcsmart
      DEVICE /dev/cuau0
      Leave the rest of params at default or customize to suit your need.
      Now you must build and use this custom cable, pinout as follows:
      Short pins 1 - 8.
      #    RJ45    DB9-M
      +– 1
      +-- 8
      #      3 ----- 1
      #      6 ----- 2
      #      5 ----- 9
      Here's one: https://www.monoprice.com/product?p_id=1151
      #END
      UPDATE: Even Simpler. Use an USB-Serial dongle like the popular Prolific PL2303 which FreeBSD 11 has built-in driver, coupled with 094-0024c will do it. Then u save the 1 com port for console use. Mine came up as port cuaU0 (uppercase U) when hooked up to the USB3. So config DEVICE /dev/cuaU0.
